Manhattan Analog 'Mix' - Build Thread
Monobass
thonk.co.uk
Post by Monobass » Wed Mar 06, 2013 7:09 am
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
renasent
Post by renasent » Wed Mar 06, 2013 2:20 pm
:tu:
Monobass
thonk.co.uk
Post by Monobass » Wed Mar 06, 2013 3:44 pm
Here we go, build doc - http://www.thonk.co.uk/Documents/MA/MA_ ... s_v1.0.pdf
I advise reading this in Adobe Reader, OSX Preview or similar, browser based PDF viewers can sometimes be unreliable.
rockwoofstone
Post by rockwoofstone » Fri Mar 08, 2013 12:53 pm
Just finished building my 3 kits, and all have the output pot acting as an attenuverter, rather than just attenuator. Not what I was expecting - is that expected behaviour, or have I managed to make the same build error on all 3?
Monobass
thonk.co.uk
Post by Monobass » Fri Mar 08, 2013 1:08 pm
Ah yeah you just need to change the jumper to UP instead of BP, I should have mentioned that in the build docs.
rockwoofstone
Post by rockwoofstone » Fri Mar 08, 2013 1:11 pm
Understood - thanks!
sync24
Post by sync24 » Fri Mar 08, 2013 4:03 pm
mine are not doing what they should.
i switched the grounding around, now they both hum.
also, one of the mixers seems to cut off below a certain frequency range.
i checked the jumper is on UP, it is.
my soldering isn't usually a problem...
so, i don't get it.
:despair:
Monobass
thonk.co.uk
Post by Monobass » Fri Mar 08, 2013 4:50 pm
Post some pics duff, or bring them over :)
sync24
Post by sync24 » Fri Mar 08, 2013 5:46 pm
cheers boss, they do look ok.
one now seems to be doing ok, the other, though, still has the cut-off issue...
i'll have a bit more of a poke about but might be round soon-ish :tu:
Monobass
thonk.co.uk
Post by Monobass » Fri Mar 08, 2013 6:07 pm
I've had weird frequency loss things where I've got a short somewhere in the past, not on the Mix... But then I don't have an experience of them going wrong :)
crossinger
Post by crossinger » Sat Apr 13, 2013 11:16 am
Ok, I finished the 2nd module (after AT-AT-AT last weekend). But this time only with partly luck. :waah:
Nothing hums and I didn't fry anything. But 1st channel refuses to work. I checked the solderings with my multimeter beep and everything seems fine: from the jacks over the pots and the resistor in the array to the chip. Everytime I got a beep. Now I'm lost :despair: Where can I check the further signal path on the PCB or is it better to attach a signal now for debugging?
Thanks for any advice!
EDIT: Request withdrawn! After another debug session and cleaning the PCB with a special brush, everything seems fine now (fingers crossed). I hope, this is not a cold solder joint.
Finally: :tu:
Monobass
thonk.co.uk
Post by Monobass » Sat Apr 13, 2013 1:03 pm
Good move, sounds like you probably just had a short caused by a solder bridge somewhere, they can be thinner than hair and have a tendency to camouflage themselves.
Next port of call would have been a wiring error, it doesn't matter how much build experience you have, wiring errors are very common.
negativspace
Manhattan Analog
Post by negativspace » Sat Apr 13, 2013 5:08 pm
With this module there is very little that happens before the channels are summed - so if there's ever a build issue that effects only one channel you need to look at the jack, pot, input resistor or wire. Anything past that will effect all 3 channels.
Funky40
Re: Manhattan Analog 'Mix' - Build Thread
Post by Funky40 » Wed Aug 28, 2013 3:32 pm
when do you expect to get mix back in stock ? so +- weeks
wanted to order some days ago.......need
Monobass
thonk.co.uk
Post by Monobass » Wed Aug 28, 2013 4:25 pm
I will restock it at some point, but not within the next two months. Negativspace has PCBs and panels in stock though I think.
Monobass
thonk.co.uk
joshuagoran
Post by joshuagoran » Wed Aug 28, 2013 5:09 pm
Synthcube definitely has PCB/panel combos!
I just ordered one a few weeks ago. :bacon:
synthcube
you will be assimilated
Post by synthcube » Wed Aug 28, 2013 5:20 pm
Not nearly as nice as thonk's kit, but at least it's a start
http://synthcube.com/cart/index.php?rou ... uct_id=212
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
jules
Post by jules » Wed Aug 28, 2013 5:45 pm
If anyone's got a couple of PCBs, I'll be glad to buy them.
Dieter: "who needs all this??!!??"
tak poo-poom
joshuagoran
Post by joshuagoran » Sat Oct 12, 2013 10:47 pm
SmallBear is out of 50k audio taper pots...anyone have another US source or a tip on whether another value will work equally well?
Monobass
thonk.co.uk
Post by Monobass » Sun Oct 13, 2013 1:31 am
With smallbear and banzai being the only stockists for these you have to cast your net further afield often .. In stock in Germany
http://www.banzaimusic.com/Alpha-9-PC-NUT-50k-log.html
The wait for restock on these can be months at a time
negativspace
Manhattan Analog
Post by negativspace » Sun Oct 13, 2013 6:03 am
According to my last status-check, the 50K audio should be back in stock any day now. Waitin' on the boat...
makers
Post by makers » Fri Oct 18, 2013 8:13 am
synthcube wrote:Not nearly as nice as thonk's kit, but at least it's a start
Is there a BOM for this PCB? I've probably not looked hard enough and I know it's only a handful of parts.
Cablebasher
Post by Cablebasher » Fri Oct 18, 2013 8:24 am
Yes, I too would like a BOM/
In fact, has anyone got a link to a shopping cart with all the components in it?
Or indeed a link to the best online store (i am UK based) to buy the bits from.
This will be my first project not from a kit with all parts and I am a little weary of ordering the wrong bits.
Thanks muchly.
negativspace
Manhattan Analog
Post by negativspace » Fri Oct 18, 2013 1:44 pm
I kinda hate to take the lazy way out... but if you check the Thonk instruction .pdf there is a BOM on the second page. :hide:
(Steve's a superhero!)
