matching transistors - DIY
Moderators: lisa, Kent, Joe.
skautkurt
Post by skautkurt » Fri Feb 15, 2019 12:51 pm
fuzzbass wrote:
You just have an unusually strong aura. :zen:
If it was your body heat, and not from contact with either transistor, it would show up in both of them at the same time. You don't need a box. A fan helps. So do plastic tweezers for handling the parts. My little matching rig (Fritz method, built on stripboard) has a ziff socket so I can drop the parts in with tweezers, and clamp them with the little lever. If you can keep your fingers off the transistors between resting and testing, things speed up a lot. I also use an hfe tester to rough sort them, which results in fewer tests per match.
Tehehehe, it indeed feels a little on the esotronic (electronics + esoteric) side :hihi: I am using a pair of ceramic tweezers (they have ceramic tips), and I am a ziff-socket aswell. So no direct contact with the transistors.
phisynth
banana nabab
Post by phisynth » Fri Feb 15, 2019 4:00 pm
emmaker wrote: The transistors are extremely sensitive to temperature changes. I wouldn't use a fan to blow air over them. Reason is that even though the volume of air going over the transistors is going to stabilize the temperature somewhat there could be changes in that air's temperature going into the fan. I think that you'd be better to insulate the transistors so you have no air movement. I have a rag or box I put over the testing circuit and let it stabilize before I take readings.
Ray Wilson from MFOS must have been wrong then :
Kevin Mitchell
Post by Kevin Mitchell » Fri Feb 15, 2019 4:53 pm
Using a fan is your best shot for consistent ambient air flow. But that should go without saying.
I'm considering boxing up the board I've posted on the previous page and somehow mount a zif socket to the enclosure. Possible update on that soon.
Gandalf
Post by Gandalf » Fri Feb 15, 2019 5:22 pm
You should really put the whole thing in a large box/container with a small heater element so that you can raise the temperature a little above ambient (25C is a good temperature). The fan, which should not be pointing at the transistors, is meant to circulate the air around the box to 'mix it' and remove any thermal hotspots.
Place untested transistors in the box as well so that they reach the same temperature.
Wear some cotton gloves to handle the transistors (easier than tweezers if using regular ic or transistor sockets for mounting).
A large box will allow you to open it, get your hand in and out with minimal disruption to the temperature, but will take long to get up to operating temperature.
All the above is a bit clumsy. I have a smaller container with the test boards in it, heater element and fan (not pointing at the transistors) and I an get stable readings within 30 seconds
Kevin Mitchell
Post by Kevin Mitchell » Mon Feb 18, 2019 2:01 pm
That's another reason why I very much prefer the GO-NOGO circuit. Since the transistors under test are next to each other, once they stabilize you wont be getting any bad data. Less variables to worry about since your testing 2 transistors back-to-back instead a load of them individually.
It's more fast to test a load of transistors this way as well. You can record the voltage difference with a fixed transistor (only swapping one transistor out to test) and see about matching the ones that are close in measurement.
I think you all are missing out :hihi:
existenz81
Pcboards for sell?
Post by existenz81 » Sat Mar 23, 2019 8:24 am
Who sells the Ian fritz pcbs? I’m interested in acquiring one if it’s possible!
TOPLEL
Post by TOPLEL » Sat Mar 23, 2019 9:33 am
Did the Fritz "two transistor difference method" on a recent (bought in the last 3 years) batch of 2N3906 and the largest difference between the two outliers was 0,3mV but generally it was between 0,0 and 0,1mV.
existenz81
Post by existenz81 » Sat Mar 23, 2019 10:20 am
TOPLEL wrote:Did the Fritz "two transistor difference method" on a recent (bought in the last 3 years) batch of 2N3906 and the largest difference between the two outliers was 0,3mV but generally it was between 0,0 and 0,1mV.
So you are saying that once I use 2 Transistors from the same ammo belt stock, I can go without matching them, they’re quite already matched?
existenz81
Post by existenz81 » Sat Mar 23, 2019 10:42 am
wackelpeter
Post by wackelpeter » Sat Mar 23, 2019 11:20 am
seems unlikely, These would be a Batch of super matched trannies…
Guess it's more pointing towards a mistake in the measurement process… less than 2mV is very often and also smaller differencies, but 0,0 and 0,1mV difference and 0,3mV at worst looks a bit suspicious to me...
And well let's assume that this is correct, you can't expect all Batches and those of the different manufacturers to be of the same Quality and thus a Transistor matcher is always the way to make sure that they are really matched...
TOPLEL
Post by TOPLEL » Sun Mar 24, 2019 11:56 am
wackelpeter wrote:seems unlikely, These would be a Batch of super matched trannies…
I matched BC547C NPNs before the 2N3906s (i changed the circuit between them) and there were bigger differences there, i only found two pairs within 0,1mV and the biggest diference was around 2,3mV.
Since my DMMs resolution is only 0,1mV there can be some errors in the measurement.
On the other hand on the good pairs the individual Vbe measurements were equal.
bootsy52
Post by bootsy52 » Sat May 25, 2019 7:55 pm
whoop_john wrote: If there is a demand for these I could post PCBs out to people at modest cost. Speak up if you are interested and I'll do a batch to cover everyone's needs. Failing that I will get about ten PCBs made and sell on 9.
Do you still got a PCB? I would like to get one
bootsy52
Post by bootsy52 » Sat May 25, 2019 8:09 pm
Kevin Mitchell wrote:I've designed my own layout for the MFOS circuit. Works like a charm. Let me know if you build your own! You could translate the layout for vero board if that's your style.
Do you have also Gerber files (or .brd, .sch) for it, so that we can fabricate a PCB?
Altitude909
Post by Altitude909 » Sun May 26, 2019 8:18 am
About the cooling/heating etc thing: It makes no difference how its done as long as it's consistent. You're measuring relative values to compare to other relative values. As long as the VBE stablizes, that's all that matters. I use the MFOS circuit and a little rig I used with an old computer fan. They will flatten out after about 30sec but more importantly, I can get consistent results with same part where I can take it out, put it back in and get to almost the exact same value
Europa313
Post by Europa313 » Mon Jun 17, 2019 3:47 pm
I got 10 "Ian Fritz" transistormatcher made at pcbway as I couldn't find any online.
If anyone's interested please pm, I'd check shipping cost if worthwhile
synthcube
you will be assimilated
Post by synthcube » Sun Jun 30, 2019 1:17 pm
friends and current/future tranny matchers-- with thanks to ian fritz and fonik for their permission, we're happy to make the pcbs and full kits available now in the store.
https://synthcube.com/cart/ian-fritz-fo ... -match-pcb
our kits include the pcb, power cable and right angle header, 0.1% tolerance 100K resistors, 3-pin inline sockets, compact test points for DVM probes, etc.
rolfdegen
Post by rolfdegen » Tue Aug 20, 2019 3:15 pm
Hallo
This is my matching tester. The 100K resistors R1 + R2 in the circuit have 0.1%. A small fan cools the transistors very fast. After 2 minutes, the values on the multimeter are stable.
Matching Circuit
Hardware
Results in mV
Greetings from germany. Rolf
Gandalf
Post by Gandalf » Tue Aug 20, 2019 4:49 pm
Having a fan blow directly across the transistors is not a great idea. Any thermal transients on the input side of the fan will be sent straight across the transistors.
The better solution is to build a large box, thermally stabilised and heat that up. Build up internal walls from polystyrene foam that will allow air to be moved around yet create minimal drafts. A fan (or fans) is used to raise the temperature above ambient (25C is perfect) and provide a draft area in which the tester sits.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Aug 20, 2019 7:06 pm
heat the clean room to 98.6F body temp. that way you can handle them without robots.
emmaker
Post by emmaker » Tue Aug 20, 2019 10:15 pm
rolfdegen wrote:Hallo
Results in mV
If you just picked a transistor at random and keep that transistor as the test reverence for the testing you've done I'd use one of the -0.4 mv as the reference. In your sample selection that seems to be the normalized value. Better yet sample a large number of transistors and the value that comes in with the most transistors use one of those for the reference transistor.
rolfdegen
Post by rolfdegen » Wed Aug 21, 2019 2:21 am
Thanks for your tips :)
consumer
Anything to this idea?
Post by consumer » Tue Dec 03, 2019 12:22 am
ejr27233 wrote:As I've only got a 3.5 digit multimeter is there any point in using a x100 gain op amp in the circuit to measure the offset mV?.
I read through this post, but never saw anyone respond to this idea: Is there any merit to multiplying the gain in order to exaggerate the offset?
Or would that just introduce more uncertainty?
jakobprogsch
Re: Anything to this idea?
Post by jakobprogsch » Tue Dec 03, 2019 7:02 am
consumer wrote: I read through this post, but never saw anyone respond to this idea: Is there any merit to multiplying the gain in order to exaggerate the offset?
I'd say no merit since at least the garden variety opamps that aren't specifically marketed as low offset probably have input offset specs in the mV range themselves.
I have to admit all this talk about the DMM digits in this thread has me confused anyway. Isn't the whole point of these "differential" circuits that you don't have to measure absolute voltage but only relative one? How many digits the DMM has is pretty irrelevant as long as it has a mV range setting.
Revok
Post by Revok » Tue Dec 03, 2019 7:15 pm
I'm possibly wrong but I think the 4.5 digit meter is only specified for matching the resistors by hand.
jakobprogsch
Post by jakobprogsch » Wed Dec 04, 2019 10:04 am
Revok wrote:I'm possibly wrong but I think the 4.5 digit meter is only specified for matching the resistors by hand.
Right, which really makes this a non issue though? You can trim out the difference by adjusting the trimmer until swapping two transistors only changes the sign of the measurement. It's slightly more work than just measuring lots of resistors with an expensive DMM but you only have to do it once.
