[BUILD] SEM VCF
synthcube
you will be assimilated
Post by synthcube » Wed Sep 21, 2016 12:26 pm
with much gratitude to barcode for the panel pcb daughterboard-- now available as a panel+pcb set, with full kits coming soon.
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
Barcode
Post by Barcode » Wed Sep 21, 2016 2:07 pm
synthcube wrote:with much gratitude to barcode for the panel pcb daughterboard-- now available as a panel+pcb set, with full kits coming soon.
Pots 5 and 7 are pretty close to Pots 4 and 6, so placing a piece of electrical tape on the side of the Pots 4 and 6 is a good idea.
Also, mount the jacks to the board before the pots. This will give the proper height for the pot pins.
sammy123
Post by sammy123 » Wed Sep 21, 2016 2:59 pm
Synthcube, will just the panel PCB be available soon?
synthcube
Post by synthcube » Thu Sep 22, 2016 9:12 am
yes its listed as 'pcb- panel daughterboard'
http://synthcube.com/cart/moogah-sem-vc ... ption=true
sammy123
Post by sammy123 » Thu Sep 22, 2016 10:45 am
Ah got it. Thanks. Sorry if I missed that.
And nice work Matt!! I have had this one in the backlog for quite some time.
babysealclub
Post by babysealclub » Sun Oct 30, 2016 9:08 am
If anybody is having an issue getting theirs to work, double check the board mounted pots. The board has five holes to accommodate different types of pots. It is really easy for the standard alpha (16mm?) Pot's middle pin to short to one of the adjacent pins.
Signature:
This is a block of text that can be added to posts you make. There is a 510 character limit. Think about it.
fuzzbass
Post by fuzzbass » Wed Nov 02, 2016 2:11 pm
If I was doing this, I would bend those pins clear on the pot, and then connect them with some insulated hook up wire. Also, I strongly recommend using lock washers between the panel and 17mm pots. These pots are not anchored to the board, and will otherwise spin when you tighten the panel screws (this might be your problem).
Wired for weird
Mr_Mojo_Risin
Excellent Module!
Post by Mr_Mojo_Risin » Wed Nov 30, 2016 12:40 am
Success! Such a great sounding module from synthCube!! This one really provides a broad spectrum of sounds.
As others have mentioned, the key to making this one work is carefully reading the build docs.
I used Module Build Document v7.0 and the single PCB version.
I was a little disappointed to find it was too deep for Pittsburgh Modular Cell[48] and Cell[90] cases.
However, with a couple of easy mods, I was able to turn it parallel to the panel and make it fit.
It was working at the first power on. Love it when that happens. :yay:
synthcube
Post by synthcube » Wed Nov 30, 2016 7:20 am
great news! thanks for posting!!
Flareless
Re: Excellent Module!
Post by Flareless » Wed Nov 30, 2016 7:48 am
Mr_Mojo_Risin wrote:Success! ...
I used Module Build Document v7.0 and the single PCB version....
Glad to hear of your successful build. I really love the module and just used it in a patch last night.
I was wondering where you obtained version 7.0 of the build document?
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
Mr_Mojo_Risin
Post by Mr_Mojo_Risin » Wed Nov 30, 2016 9:49 am
It's been more than one week so I can't remember where I got it :hmm:
I'm fairly certain synthCube sent me the v7 manual and BOM docs attached in an email.
synthcube
Post by synthcube » Wed Nov 30, 2016 1:03 pm
attached here as well
tekzon
Post by tekzon » Sun Jan 08, 2017 9:27 am
Hey wigglers!
Back on this shitty pcb for the third time without any success...
Is there a doc with the right PCD's labels? All I have for sure is FREQ, RESO and NOTCH.
Rev7 of synthcube's build doc is not helping for this.
Like: "26. Next, solder the ‘Audio 2’ input jacks and pots." Ok..
Any help on right labels would be appreciated!
Cheers!
Solved, I've been a dick!
woodster
Post by woodster » Sun Jan 08, 2017 9:49 am
Whats wrong with the pictures on page 11-12 ?
They show you all the wiring and pcb info
tekzon
Post by tekzon » Sun Jan 08, 2017 11:51 am
woodster wrote:Whats wrong with the pictures on page 11-12 ?
Hooo my!.. Page 12, you're right, I was so pistoff, I did not turn the page!
Ok, my bad, thanks woobster.
tekzon
Post by tekzon » Sun Jan 08, 2017 1:03 pm
OK, I'm stuck.
Do you see any obvious mistake?
I'm a beginner and I don't know how to test a circuit nor read a schematic, best you know that...
Thanks for your help.
Mr_Mojo_Risin
Post by Mr_Mojo_Risin » Sat Jan 14, 2017 6:42 am
tekzon wrote:OK, I'm stuck.
It's always difficult to tell without having the PCB in-hand but here are some potential problems I see from those images;
1) Solder bridge?
2) Short between resistor and nut?
3) Any insulation or gap between the aluminum sheeting?
Supervillain
Post by Supervillain » Tue Feb 07, 2017 6:01 am
Hi,
Just got my kit from synthcube!!!
Any build documentation for the "2 pcb" version?
I can't fugure out how to connect control board and main pcb (total noob here!)
coldvvvave
Post by coldvvvave » Mon Feb 20, 2017 5:39 am
Supervillain wrote:Hi,
I've just assembled mine (I'm new to DIY too but it works).
Here are pics for reference if you still need it.
I haven't calibrated it yet but it already sounds very nice.
synthcube
Post by synthcube » Mon Feb 20, 2017 9:09 am
great pictures and it looks like a very clean build. thanks for sharing them here!
tito_tunes
Post by tito_tunes » Fri Mar 24, 2017 5:39 pm
Just bought one of these second hand. Is it possible to adjust the amount of resonance? Mine doesn't go into self-resonance.
danielriera.bandcamp.com
Emalot
Post by Emalot » Fri Apr 14, 2017 12:52 pm
tito_tunes wrote:Just bought one of these second hand. Is it possible to adjust the amount of resonance? Mine doesn't go into self-resonance.
I think SEM VCF never self oscillate.
Mine is really strange, i have the first version, Blue PCB.
It's workoing only when i put out the TL074, and Offset 1 and Offset 2 doesn't change nothing.
Somebody have idea??
Emalot
Post by Emalot » Tue Jun 20, 2017 6:07 am
Please somebody can help me?
I don't understand why Offset don't change anything to my filter.
THe filter works, i can't have a real Hipass and real Lopass, it is like the filter works in really short range.
Emalot
Post by Emalot » Tue Jun 20, 2017 6:42 am
If somebody can send audio recording with sweep in HP mode and in LP mode to verify it's my freq range is normal....
Supervillain
Post by Supervillain » Mon Jul 24, 2017 7:14 am
I think i have the same issue...
Cutoff knob don't sweep filter frequency...
Anyone can help?
