Thanks, I ordered them a month ago when they also showed two in stock, and then I got an estimated shipment update for mid March. I think their stock status is not represented truthfully, or in the best way they couldjersupereq wrote: ↑Thu Jan 28, 2021 2:31 pmLast 2 available: https://www.newark.com/that-corporation ... dp/50M5189
Those things are pretty much sold out everywhere
DIY Trade Thread [ Parts, PCBs, Panels ]
Re: DIY Trade Thread [ Parts, PCBs, Panels ]
- synth.void
- Common Wiggler
Lookin for the monsoon LEDs (common cathode r/g, like https://www.mouser.de/ProductDetail/Kin ... WP115VEGW/). Anyone in EU/Berlin?
- cackland
- Super Deluxe Wiggler
Where did you order from? Direct from THAT?B0bcat wrote: ↑Thu Jan 28, 2021 2:35 pmThanks, I ordered them a month ago when they also showed two in stock, and then I got an estimated shipment update for mid March. I think their stock status is not represented truthfully, or in the best way they couldjersupereq wrote: ↑Thu Jan 28, 2021 2:31 pmLast 2 available: https://www.newark.com/that-corporation ... dp/50M5189
I tried ordering from Newarkcackland wrote: ↑Sat Jan 30, 2021 5:16 pmWhere did you order from? Direct from THAT?B0bcat wrote: ↑Thu Jan 28, 2021 2:35 pmThanks, I ordered them a month ago when they also showed two in stock, and then I got an estimated shipment update for mid March. I think their stock status is not represented truthfully, or in the best way they couldjersupereq wrote: ↑Thu Jan 28, 2021 2:31 pmLast 2 available: https://www.newark.com/that-corporation ... dp/50M5189
- cackland
I would always go direct
- synth.void
- Common Wiggler
Well, I've ordered the much needed LEDs and some extra. Now I need the square flat bipolar leds for the sliders, does anyone have 4 of them? The part is most likely some variation of Bivar 749-R3BC, but Lumex and Kingbright might have them also.synth.void wrote: ↑Sat Jan 30, 2021 7:17 amLookin for the monsoon LEDs (common cathode r/g, like https://www.mouser.de/ProductDetail/Kin ... WP115VEGW/). Anyone in EU/Berlin?
I need a STM32F103CB chip. Mouser and Digikey are OOS.
- Common Wiggler
Yeah, expected around the time COVID-19 is resolved and the global economy picks up again...
(serious answer: have a look at this thread)
hi, would like to trade ?Bamboombaps wrote: ↑Tue Dec 08, 2020 8:52 amSome blanks I have posted here before and some new ones
Looking for PCB panel sets
what are you looking for ?
Looking for
x2 SSI2164 SMD
x1 bournes fader
I will put the list this evening of component i had to trade.
Chip, pot, switches...
x2 SSI2164 SMD
x1 bournes fader
- Common Wiggler
Stop the press!
STM32F103CBT6 back in stock at Farnell.
Just ordered some.
Just ordered some.
- synth.void
- Common Wiggler
jonnyjupiter wrote: ↑Mon Feb 08, 2021 10:53 amStop the press!
Just ordered some.
Now I'm looking for 2x, or even 4x AD5687RBRUZ. That's the internal Vref ADC for teletype - I've mistakenly purchased a bunch of AD5687BRUZ.
Also, looking for black panels for the TM pulses expander and varigate 4+. Anyone?
I recently completed the TSynth_Teensy 4.1 and had the side cheeks and side panel column parts 3D printed. I was able to have extra parts printed at no additional cost so I have the following parts left over
End Cheek (in black) - 4 off
Side Panel Column - 90 off
- Common Wiggler
False alarm with Farnell.
I ordered 10 chips when they said they had 248 in stock but received an email today saying they were out of stock and expecting a delivery 24th April.
Great.
Great.
- Reality Checkpoint
- Confused By Electricity
I have been through my stash and have found the following that I will never use:
1 x THAT 2180 A,
20 x THAT 2180 B
2 x THAT 2181 LA
2 x THAT 2181 LB
I searched for ages to see if I had another A version to no avail.
I think the THD is a nominally higher on the B versions, but not sure of other differences.
Let me know if you would like them.
Last edited by Reality Checkpoint on Wed Feb 10, 2021 8:59 am, edited 1 time in total.
Anyone have a black monsoon panel they'd trade for my white one? It's the Magpie panel.
Now found, thank you!
I have for trade:
Quadtec 101 dual OSC, Panel+PCB
Norns Shield, PCB
Kinks, Panel+PCB
Pique (4hp peaks), Panel+PCB
4hp Wasp Filter by forestcaver, Panel+PCB
Intellijel 1u Ornament & Crime w/ VOR (better voltage ranges), Panel + PCBs
Benjolin, Aluminum Panel Black from CCTV
NLC Phase/Flange 329, Panel+PCB - Traded
NLC Choral Generator, Panel+PCB - Traded
Terminal Tedium, Panel+PCB
Little Traverse Bay (2x screen expander for Terminal Tedium), Panel+PCB
I'm Interested in/looking for:
Eurorack PCB/Panel sets for almost anything, let me know what you have to offer, would love to find some RYO pcb/panel sets, also interested in any black panels, BKM, Oscillosaurus..
Norns Shield, PCB
Kinks, Panel+PCB
- Bamboombaps
- Wiggling with Experience
Here's my latest list
A load of new blank designs
Erica oscillator
Erica envelope
Erica swamp
Erica bbd
Long Moraydular busboards
BMC panels , decaying analogue noise and FM drum
Sparkfun proto pedal
Synthsizer ruler
Oh and also a goofed up panel for the cutlasses glitch delay project which needs mounting holes drilled and is ever so slightly misaligned but useable if you don't have anything else
Interested in euro PCB panels sets or send your list
Erica oscillator
Erica envelope
Erica swamp
Erica bbd
Synthsizer ruler
Has anyone got a 47mH inductor for sale? This one in particular: https://octopart.com/search?q=RLB0812-473KL (for the CB-55 drum machine)
- synth.void
- Common Wiggler
Looking for a CS4270 cirrus codec chip for monome Norns.
I am looking for 7 mounting screws (for the modules) for a .COM mounting frame. Actually I am not sure what frame I have
Since I built quite a lot Blacet kits but have used my own IC sockets I have a load of Blacet's IC sockets spare.
I have a couple of A100 knobs.
- Altitude909
I have a original hardwood sides Jasper case (from the very first run), never ended up getting used. The sides are finished. Up for trades (its worth ~$100)
