Ribbon cables
lrclazer
Post by lrclazer » Mon Dec 02, 2013 2:01 pm
Making my own power cables for the first time, and I recently bought 25 ft of 16 conductor ribbon.
It is safe to manually peel of 6 conductors to make it 10 conductor, or should I use some other tool, or should I just buy some 10 conductor? :despair:
samuraipizzacat29
adadadadadadadsr
Post by samuraipizzacat29 » Mon Dec 02, 2013 4:24 pm
I "think" these are the kind used on the flying bus cables.
http://www.mouser.com/ProductDetail/TE- ... mkGw%3d%3d
at least they're not expensive :eek: :moneyburn:
I used stuff from marvic.com but they can be found cheaper (ebay)
"You can't rule the world by going at it all scattershot." - Pearl Forrester, "The Final Sacrifice"
Always stuff for sale. Pm me, add me on facebook. Send a carrier pigeon. Fox me.
lrclazer
Post by lrclazer » Tue Dec 03, 2013 4:45 pm
lrclazer wrote:Making my own power cables for the first time, and I recently bought 25 ft of 16 conductor ribbon.
Anyone have advice on whether or not it's safe to split ribbon cables?
latigid on
Post by latigid on » Tue Dec 03, 2013 5:18 pm
No problem, go for it.
samuraipizzacat29
adadadadadadadsr
Post by samuraipizzacat29 » Tue Dec 03, 2013 6:36 pm
^+1. I do it all the time with my teeth, a razor blade, pliers, strippers, anything at hand. A good idea, though, when you make cables is to make a little rig so you can test them before use. saves a little frustration or possibility of blowing something up. just need a pair of headers and some protoboard.
ATW
Re: Ribbon cables
Post by ATW » Fri Jun 05, 2020 3:50 pm
Is it unwise to leave an orphaned ribbon cable plugged into a bus board (and not plugged in to a module on the other end)? I'd rather not remove a bunch of modules to be able to access it easily and remove it, because I am lazy and would make music than wrangle modules.
southphillysynths
Re: Ribbon cables
Post by southphillysynths » Sat Jun 06, 2020 8:32 am
Nope, you can do that, I've done it for years with no issue.
Dcramer wrote:"Not all who wiggle are lost" :boat:
WHO IS BOZO TEXINO?!?!
ATW
Re: Ribbon cables
Post by ATW » Sat Jun 06, 2020 9:51 am
Grazie mille !
ATW
Re: Ribbon cables
Post by ATW » Mon Jun 29, 2020 1:11 pm
Has anyone tried dual chain and quad chain ribbon cables? Looks like the same principle as a flying bus board cable in a small footprint. I wonder if it introduces any of the issues w/ noise that some have cited w/ flying cables—though, it looks like a great way to distribute the cable pileup within a skiff.
latigid on
Re: Ribbon cables
Post by latigid on » Mon Jun 29, 2020 2:06 pm
