Post pics of your guitar/bass/amp/pedal setup!
AlanP
Post by AlanP » Mon Sep 24, 2018 3:08 am
What do you use the Ring Stinger for? (Does the Octave stomp on the right get much love? It is a very, very nice octave effect...)
smetak
Post by smetak » Mon Sep 24, 2018 7:14 am
Summa wrote: VOCU VTE-1600
Zvex Wooly Mammoth
Lovetone Ring Stinger
montreal assembly count to 5
Hologram Infinite Jets
Gamechanger Plus Pedal
Ezhi & Aka Moomindrone custom
Tc tuner
small live board, I tend to switch around this setup quite a bit but always in connection with my modular rig, no guitar live (yet ;) )
So, this would be your rig for modular, not for guitar? Right?
Really wonder how this would sound for guitar - seems quite up there, a very unique set.
Summa
Post by Summa » Mon Sep 24, 2018 1:46 pm
AlanP wrote:What do you use the Ring Stinger for? (Does the Octave stomp on the right get much love? It is a very, very nice octave effect...)
yeah it's a classic Ringmodulator with a lot of nice features, for a while I used the optical input jack but mostly I voltage control it from the modular and sometimes use the VCO out for other duties, one of my favourite pedals for sure!
Summa
Post by Summa » Mon Sep 24, 2018 1:48 pm
Zvex Wooly Mammoth
Tc tuner
yeah I use this rig for my modular, my guitar playing is not there yet ;) but a lot of these pedals I do use on guitar.
SlightlyNasty
Post by SlightlyNasty » Thu Nov 01, 2018 5:40 am
Here's my fine fretted friends in the studio:
Ibanez RG2228 8-string with Dimarzio D-Activators
Clapped-out Martin "Stinger" with cheap eBay PAF bridge and lipstick neck pups
Pitbull DM-1S kit guitar with Tonerider Hot 90 (my most played axe)
Ibanez SR505 bass with D'Addario ProSteels (for clanky metal bass)
Old "Cimar" (Ibanez) classical guitar
Epiphone Viola bass with LaBella flatwounds
Last edited by SlightlyNasty on Sun Feb 23, 2020 10:35 pm, edited 1 time in total.
www.slightlynasty.com - 4U DIY Modules for the Loudest Warning format
khakifridge
Post by khakifridge » Fri Nov 02, 2018 4:04 am
SlightlyNasty wrote:Pitbull DM-1S kit guitar with Tonerider Hot 90 (my most played axe)
Before I scrolled down to your comments, that was my choice for the one I'd most want to pick up. 8-) Nice collection.
SlightlyNasty
Post by SlightlyNasty » Mon Nov 05, 2018 12:56 am
Thanks! Yes, the Pitbull lives on its own little stand ready to go at a moment's notice, I often end up using it on tracks even when it's not the most sonically appropriate just because it's so damn fun to play.
The Hot 90 pickup is just a total rock machine, very compressed in a really good way. I'm not actually a big fan of hot pickups normally, but on a raunchy P90 it really works.
woVERTICES
Post by woVERTICES » Fri Feb 22, 2019 8:04 pm
Only Kleins...
Best,
John
www.johnjpotter.comImage
TranscendMoreDimensions
Post by TranscendMoreDimensions » Wed Mar 27, 2019 1:46 am
2003 Gibson Les Paul Custom w/ Tom Anderson H3+ in the bridge. [/img]
charlestobias
Post by charlestobias » Mon Apr 15, 2019 1:27 pm
Here's most of my rig.
Fender Tele Deluxe with Lollars.
Orange TH-30
Ampeg Reverberocket
And nothing too crazy going on with my papa.
Walrus Deep Six
Electro Harmonix POG
DigiTech Whammy
Earthquaker Sea Machine
Walrus Messner
JHS Ruby Red
ProCo RAT (Keeley Mod)
Strymon Timeline
Neunaber Slate
Idunno
Post by Idunno » Tue Apr 16, 2019 10:58 am
Pics of my Guitar / Bass / Amp / Pedal setup? Gosh! It wouldn't fit on the page. Or if it did, it'd be like a pointillist painting.
SlightlyNasty
Post by SlightlyNasty » Fri May 10, 2019 10:11 pm
Recent project: a rusty and clapped-out "Morris" LP clone, one of those classic 70s Japanese guitars with the weird almost semi-hollow construction and "fauxbucker" pickups that leave out one of the coils to save money.
I refretted it with stainless steel frets, cleaned it all up and fitted the IronGear Rolling Mill / Alchemist 90 set so that I'd have at least one guitar that wasn't just a high-output metal monster. Plays and sounds exactly like it should, a crunch-channel noodle machine.
Moerdertheke
Post by Moerdertheke » Thu Jun 13, 2019 8:36 am
Spend the first half of 2019 to assemble this board for a combination of mono and stereo inputs. There's a also a chunk of Eurorack for mixing different dirt layers that keep the dry stereo input alive + plus some extra noise / ring mod to top it off (the pink cables).
There's only ever one string going through this thing:
scozbor
100th Member!
Re: Post pics of your guitar/bass/amp/pedal setup!
Post by scozbor » Thu Feb 20, 2020 8:11 pm
abandonist
Post by abandonist » Tue May 05, 2020 12:09 pm
The gang.
numan7
the most autistic amongst us
Post by numan7 » Tue May 19, 2020 12:16 am
anyone else got a temple-board? here's mine (which i've had for a while but only recently got around to assembling)...
one of the big draws is the provisions for mounting various power-supplies. for instance, you can get a pair of mounting brackets with holes that match the voodoo pedal supplies and extra cross-rails to mount them between.
i also mounted an effectrode atomic power supply to one of the cross-rails on the other side from the voodoo-bracket (hmm, it might be nice to get another pair of cross-rails, another voodoo supply - i'm thinking the 4 x 9V + 4 x 12V one - and screw the other side of the atomic power-supply to the other inner-rail, eh?)...
you then screw the power-supplies-assembly to the cross-rail holes in the bottom of the temple-board sheet-metal...
this is what i initially had in mind (but currently lack the power lead and patch cables to wire up correctly)...
:bang: and this is me trying to get the damned signal path sounding decent before committing to anything.... :deadbanana:
:zen: some things i've learned about the temple-board:
- getting the IEC mains module (see upper left corner of the temple-board in the third image above) screwed into place is a total pain in the butt (it involves blind screw-drivering into a tight corner :zombie: )!
- fitting multiple pedal power-supplies into a nice compact wedge is cool and all, but it comes at the expense of having to undo the bottom brackets in order to access the screw-on-plates that you attach to the bottoms of your pedals in a temple-board system. this kind of sucks... i'm somewhat tempted to place some velcro tape over the sections of the temple-board where the holes are obstructed by the power-supplies underneath and only use the screw-on-plates for things i'm confident aren't moving anytime soon (such as the supa-trem2) - sort of a best-(or at least not-worst-)of-both-worlds approach...
- i was initially nervous about attaching the temple-board screw-on plates to my pedals, wondering how they could be removed should i ever decide to sell some pedals or ditch the temple-board for example. but i accidentally discovered that all you need to do is screw the plate onto the temple-board and then rock the pedal back and forth a bit until the screw-on-plate's adhesive gives way (it kind of makes a "snapping" sound when this occurs). you then have a minute or two to re-attach the adhesive side of the screw-on-plate back to the bottom of the pedal (if it was indeed an accident) or to the bottom of a different pedal (if you so prefer)...
- it took me a day or so to realize that the temple-board output buffer module and the effects-loop return inputs on my orange rocker-32 amp didn't care much for one another (the temple-buffers were essentially biasing things so that the signal through the effects loop was very small, fixed and quiet regardless of the volume or gain settings of any of the pedals in the loop). when i finally removed the cables from the buffer outputs and plugged them into the supa-trem2's outputs (which had been plugged into the buffer inputs) all was good again. one needs to carefully consider where and when to place buffers in one's guitar signal paths...
cheers
“i'm telling you my dear that it can't happen here because i've been checking it out. i've been checking it out for a couple of days...”
