I'm addicted to Phasers.
scozbor
100th Member!
Post by scozbor » Wed Mar 15, 2017 9:09 pm
a100user wrote:Do any of you phaser fans have any experience of the CGS Phaser?
I used to have the Synthasonic frac module which was based on this I believe. Loved it and a highly regarded frac module of old!!
rauch
Post by rauch » Thu Mar 16, 2017 3:48 am
i'm in the market for another phaser.
have a small stone (v4)
and looking at
mutron phasor 2 (butterfly effects?)
Maestro ps1 (heptode?)
ada final phase
can't decide.
:hmm:
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Mar 16, 2017 10:42 am
When I worked at Symetrix decades ago, we made a phaser called the Phase Filter that was based on SSM2040 filter chips. It had dual LFOs and external ins etc. We originally designed it to use 3 SSM2040's but the effect was so intense (it bent notes and such) that the production units only had 2 chips installed. It had a GREAT sound. The two filter chips were driven by the same LFOs but the design was such that they never tracked exactly the same - one would always be ahead while the other was catching up to the same frequency. This made for a very beautiful full tonal sound - beauty in inaccuracy. I don't remember how many we sold but we stopped making them decades ago. If you see one used, check it out. They are very sweet. If you have a DIY bent, just use the all pass filter circuit from the SSM2040 data sheet and make two of them in series.
-James
rauch
Post by rauch » Fri Mar 17, 2017 6:32 am
is there a schulte compact phasing clone pedal out there?
edit: found one. www.infanem.com/compact-faye-sing-b/
not an exact clone i suppose but maybe worth a try.
edit 2: out of stock
BillyCardigan
Post by BillyCardigan » Thu Jul 20, 2017 9:13 am
my favorite phaser is my black Sovtek EHX Small Stone...it's in terrible cosmetic shape but still somehow works. it sounds better than any of the non-Russian Small stones i've played with....it's more extreme...i really desparately wish there wasn't the intense volume drop on it
Scories
Post by Scories » Thu Jul 20, 2017 9:46 pm
I have a Lovetone Doppelganger dual tremolo/phaser. One lfo for low frequencies and an one lfo for high frequencies. And you can adjust the range of low/high frequencies.
With subtle settings, you can use it on any source and it makes it sound more natural; like a subtle breeze. On extreme settings, it can provide some really nasty modulations. Considering its value, I often think about swaping it for something else, but at the end of the day, I always decide to stick with it.
Klangzaun
Post by Klangzaun » Mon Jul 24, 2017 12:28 am
I had a small stone, stereo poly phaser, bad stone from EHX and the Moog MoogerFooger 12 stage Phaser.
The EHX stereo polyphaser was my favorite for a long time, because it didn't kill all the low frequencies.
The Moog phaser was great as well - especially modulated by some cv sources.
Now I have switched to a digital ( :zombie: ) Source Audio Gemini chorus, which can handle all the algorithms of the lunar phaser as well. With the editor the effect can be tuned according your taste.
snakejaw
Post by snakejaw » Wed Aug 16, 2017 11:26 pm
Does anybody know if the Pittsburgh Modular Phaser can produce a more classic shimmering sweet phasing effect? The demos I've found are kind of wild (I like wild) and I can't tell if it can also do the creamy, smooth, shimmery stuff too.
Ranxerox
All the gear, no idea
Post by Ranxerox » Sat Aug 19, 2017 4:38 am
rauch wrote:is there a schulte compact phasing clone pedal out there?
There's the mode machines krautrock phaser? A little pricey, but still available I think.
I'm rocking the TC XII b/k, it's not a clone but can get reasonably close.
rauch
Post by rauch » Sat Aug 19, 2017 8:50 am
Ranxerox wrote:There's the mode machines krautrock phaser? A little pricey, but still available I think.
yes thanks forgot about the krautrock. it's discontinued but some shops still have it. put it on my list. can't have enough phaser flavours!
i found a mutron phasor clone. haven't had a lot of time to test it but i like it so far.
areed
Post by areed » Sat Aug 19, 2017 10:48 am
dumbledog wrote:Hi, is this Phasers Anonymous? I have a problem.
Makes a great stereo send/return for my DAW.
This appears to be a picture of some music gear but actually it's a photo of pure happiness.
Figures
Post by Figures » Sat Aug 19, 2017 2:10 pm
cant believe that i missed this one.
my favourite current 2 are -
maxon ph350
dod 201 yellow original version
both excellent in different ways.
maxon does wide range of stuff and always sounds big open and classy.
dod one dial but just sounds bang on
also have still a small stone american and Soviet.
have had boss ph3. ibanez pt909 and mxr phase 90
rauch
Post by rauch » Sat Aug 19, 2017 3:02 pm
i love my small stone but the volume drop is really annoying. still not sure if there's a version that doesn't have this problem?!
RubberGong
Post by RubberGong » Fri May 04, 2018 6:18 pm
considering getting 2 of those mf-103 - do you have any sound examples?
Rost + Licht
Post by Rost + Licht » Sat May 05, 2018 9:17 am
Nice topic here!
Just shot one of these on local Ebay announces. Its this kind of effect that I always searched for, but never been quite sure what it is. Used in a more "unconventional" Style those things are pure bliss
drowld
Post by drowld » Sun Nov 18, 2018 4:44 pm
I actually have a small stone new gen and i'm buying the xaoc kamieniec soon.
I felt in love with the sound thu the videos so hopefully it will be even better in person.
At some point i was in between buying a vintage pedal unit for a hefty price. Hopefully soundtoys mistress is doing the job realfine
PapaLazarou
Post by PapaLazarou » Sun Nov 18, 2018 7:21 pm
I've got a Palthegiraffe Milton Slade that I can't seem to take out of my setup for more than a day. From what I understand his stuff is all old bent and rehoused DODs.
dkcg
Post by dkcg » Tue Nov 20, 2018 8:39 pm
drowld wrote:I actually have a small stone new gen and i'm buying the xaoc kamieniec soon.
I still have all my hardware phasers, the only software phaser I ever use is the Soundtoys plugin. You should be set if you do things in the box. I only use the MF103 with synths, the rest of my phasers sit on a shelf or get used pretty exclusively with guitar/bass.
And anyone know where I could get my Mode Machine's Krautrock phaser fixed?
Post by MindMachine » Fri Nov 23, 2018 2:52 am
Currently the only Phasers besides modular (Serge) that I have are:
Boss PH-3 on a Micromoog and a Castle Instruments Phaser III that floats around the studio. I also have an Alesis Faze that is good for electric bass.
I prefer the analog.
Fallen_lassen
Post by Fallen_lassen » Fri Nov 23, 2018 8:11 am
Two Roland system 500 572 phasers in stereo is what i am using nowadays.
Next to the Boss ph-1 ph-2 and ph-3(sheppard tone like rise/fall mode ftw).
Chevron87
Post by Chevron87 » Mon Nov 26, 2018 4:46 am
I love Phasers too!
zolar_czakl
Post by zolar_czakl » Mon Nov 26, 2018 1:36 pm
Anyone else got the Dwarfcraft Ghost Fax? I'm really digging it, but more for the extra stuff it can do with feedback and the manual control. It's kind of my secret weapon, and has pushed me to explore more feedback effects. Neat-o!
Here's the Knobby review:
dave999z
Post by dave999z » Tue Dec 04, 2018 11:37 am
I have a BYOC Royal Phase. Easy build. Sounds awesome. Inexpensive.
Post by MindMachine » Sun Jul 21, 2019 1:57 am
Now have an EH Small Stone reissue on my Roland RS-09 and am considering either an EH Bad Stone or MXR 100 for my Micromoog. Out of all of the fancy phasers out there these just sound so classic.
Down to three phasers now (Alesis Faze, EH Small Stone and Castle Electronics Phase III).
FS: Pedals and Euro modules, Delta Labs, dotcom Q128 for 37.00
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
Illiac
Post by Illiac » Tue Jul 23, 2019 9:40 pm
Has anyone been able to get their hands on the new Bi-Phase reissue? Not a lot of content out there on it, but, from what I understand, it's pretty much a part for part replica done by the man himself:
https://www.mu-tron.com/products/mu-tron-bi-phase/
