Buchla Easel Command Module 208C
Re: Buchla Easel Command Module 208C
Hello, I was wondering if anyone got reliable results from using the m.o.freq input, to trigger the sequencer steps?
I’ve flicked the internal switch to seq mode to enable this mode.
When using an external clock straight in, it doesn’t work, perhaps my clock pulse is too weak? When using a pulse direct from the pulser, it triggers the sequencer, but it’s kind of erratic and jumps all over the place. I’ve tried boosting my external clock in via the preamp and again, it sort of works, but not consistently.
I’m using a midi to clock converter and it’s producing a steady pulse.
However this is my first Buchla, so I’m not au fait with their needs. Perhaps they expect a ‘thicker’ pulse than other systems?
I’d love to get this working as would like to hook it up to a looper eventually..
Ambient // Drone // Elektronische Musik.
Radio/blog: https://www.flatlandfrequencies.com/
Submissions: flatlandfrequencies@gmail.com
Hmm, going via the inverter seems to be helping!
Hi,do you have an idea about the availability of the next batches?
Thanks!I am on a waiting list
Molotov wrote: ↑Sun Feb 21, 2021 11:16 amHello, I was wondering if anyone got reliable results from using the m.o.freq input, to trigger the sequencer steps?
as far as i understand the adendum you can either use a cv source to modulate the step count or make the socket an output that gives a pulse when a step is in the off position. external clocking of the sequencer is done via the card.
youtube /// soundcloud
Aha ok, modulating the step count would explain the erratic behaviour! I misunderstood it’s use then.. Shame they don’t come with the old school cards like the previous easels, as this is a feature I’d like to useprphnc wrote: ↑Sun Feb 21, 2021 1:23 pmMolotov wrote: ↑Sun Feb 21, 2021 11:16 amHello, I was wondering if anyone got reliable results from using the m.o.freq input, to trigger the sequencer steps?
- papz
- Super Deluxe Wiggler
- Contact:
Improved old school program cards are available on http://www.portabellabz.be/208prog.html
A pulse input to clock the sequencer is a standard feature of the BOB expander and an optional feature of the 208 ToolBox http://www.portabellabz.be/toolbox.html
Finest EMS gear service and Music Easel/208 goodies
I'm not a synths dealer and I'm not aware of an inexpensive Synthi secret market, please don't ask me if I know one for sale.
I don't offer support of any kind to people attempting to build clones of EMS equipment.
winn3r wrote: ↑Sat Jan 23, 2021 12:33 pmBuchla FB just posted this..
$3999 Easel and sub-$1000 LEM 218e coming Spring 2021. No new photos.
Timestamp 4:14:
https://www.facebook.com/BuchlaUSA/vide ... 572128601/
DOES ANYBODY HAVE MORE INFO ABOUT THIS? WHEN? HOW? pleazz
Anyone else had problems with the USB Host board in the Easel Command ?
I got a few lock-ups / hanging notes & the 208C stopped responding to all MIDI input at the weekend. I had an Arturia Beatstep Pro connected.
even a few power cycles didn't cure it initially. I then reverted to powering the BSP externally & using din MIDI & all was normal.
Then it worked again via the host port. Then crapped out again ... this time just powe cycling the BSP worked & then it worked solidly for a good hour or so
It's not a massive problem - though I am intending to play live with this set-up ( that was one of the reasons I got the Host Board - to streamline cables etc for gigs ) & it would be bit worrying thinking I might get a MIDI hang-up mid-set !
Intermittent problems are the worst - it's like there's no rhyme or reason to it
No everyone is waitingmella wrote: ↑Sun Feb 21, 2021 8:39 pmwinn3r wrote: ↑Sat Jan 23, 2021 12:33 pmBuchla FB just posted this..
Timestamp 4:14:
Mine was being erratic/stopped working. Turned out I didn’t seat it hard enough - that might not be your issue but it was mine, FWIW. Now it seems fine.Xmit wrote: ↑Mon Feb 22, 2021 5:38 amAnyone else had problems with the USB Host board in the Easel Command ?
cheers. yeah, I did wonder about that. I'll see if it stays working now. If not I'll try re-seating even more firmly. It feels sort of wrong to press it in really really hard somehow ?! Like you'll break something ...
Yeah it was kinda weird pushing it that hard. I’m used to ICs with shorter pins (and only on two sides), so it did feel like I was gonna break it.
In which case, instead of the sequencer, is there any way of external clocking the pulser without the program card?
Either midi clock or cv pulse? I notice it has off/ext mode as an option, but not getting much luck there either. I'd rather not use midi notes..
Yes - through the pulser input banana socket - set the pulser to 'kbd' and 'trans' and push the period slider to the top. Note that the pulser expects a 12v gate.
Oh excellent! Thanks for the tip, will try this tonight..
- Wiggling with Experience
This looks like a great price point for me to jump into the Buchla world. How would I get it to play well with my Eurorack gear? I'd love to be able to cross patch the Buchla from my eurorack sequencers and so forth. Now if only Serge would come out with an affordable entry point then having these two classics would be amazing.
My music:
https://soundcloud.com/modben
My modular setup (always work in progress)
https://www.modulargrid.net/e/racks/view/1391380
- antonriehl
- Common Wiggler
- Contact:
The simple answer is that the Easel Command accepts 1v/oct and Eurorack gate.mixxalot wrote: ↑Wed Feb 24, 2021 6:58 pmThis looks like a great price point for me to jump into the Buchla world. How would I get it to play well with my Eurorack gear? I'd love to be able to cross patch the Buchla from my eurorack sequencers and so forth. Now if only Serge would come out with an affordable entry point then having these two classics would be amazing.
But, if you want to go back and forth, a format jumbler is a great option. I just added this one from Low-Gain, and immediately started getting amazing back and forth modulation. https://www.low-gain.com/shop/p/utl1
They also have one with inline attenuators, if you need that. You should plan to use an attenuator going from Buchla to Eurorack to control any differences in voltage. (From what I understand, most Eurorack won't be damaged by 15v, but I don't know if that's always true)
Receiver II Soundtrack: https://bandcamp.antonriehl.com/album/r ... soundtrack
My other music: https://songwhip.com/artist/h-anton-riehl
I’ve done all the work to integrate my Easel Command with my modular rig and lots of other gear. But really I’m not doing a lot there beyond integrating controllers (right now I’m loving my Haken Continuum, my MicroFreak and my 0-Control for different flavors of this). Otherwise, I’m not really playing outside the 208c box much. The 208c is a very deep ecosystem, and one I keep finding new areas to dig into without adding in the gazillion pieces of other owned gear I could hook up. Part of why I’m loving the Command is that it’s a deep, self contained realm to play in. It’s a true instrument.
getting back to my troubles with the USB Host module : I'm ready to throw it out of the window now.
Not working again. Opened the 208C up - re-seated about 10 times, checked & re-checked. Then actually didn't seat it fully - had it standing a bit proud...Worked. Great, I thought. Popped the top back on - checked, still working. Screwed the plate back on, moved back in situ in my studio & powered on - nope. Back to power only, no MIDI input. I bought this thing for live use - hardly confidence inspiring if gently moving it causes it to flake out again.
Then spent another 30 mins or so re-seating, power-cycling, repeat. Nothing. Can't get it to work at all now. I've taken it out & have reverted back to good 'ol DIN MIDI.
I think there has to be something wrong with this Host board ? they can't be that flaky ? All the pins are in fine... Guess I may have to contact Buchla.
Ugh. Hopefully someone at Buchla can sort it out for you! Deep breath...
yeah cheers - support ticket sent
Good luck with your midi board. And on that note, what do you guys like to use the usb midi for? It’s nice having it power and receive midi from a keyboard (til the new 218 comes out), and my wife bought me a playtronica touch thingy (which could be cooler than it is), I was a little disappointed that my OP-Z doesn’t send midi over usb(seems like it should). I may eventually get the morph, but is anybody having revelatory experiences with any other controller types?
Opz send's midi over usb.. You have it set wrong. Read the manual.
Just got an email from Detroit Modular that they have some Easel Commands in stock, in case anybody’s looking.
Instagram: https://www.instagram.com/markscheuern/
Awesome! I think that it would be a great addition to my setup along with more mixers and percussion modules. I also like the 252e Buchla Polyphonic Rhythm Generator module but think you need a separate boat for that module.antonriehl wrote: ↑Wed Feb 24, 2021 9:48 pmThe simple answer is that the Easel Command accepts 1v/oct and Eurorack gate.
My music:
