MARF 248r source code available
Drillionaire
Re: MARF 248r source code available
Post by Drillionaire » Sat Feb 22, 2020 11:24 am
If a build for the Rev1 units gets made I would be happy to help test and contribute to the code base.
maxl0rd
Post by maxl0rd » Sat Feb 22, 2020 11:30 am
Hey Drills
We don’t really have any show stopper bugs for v1, so the focus is on v2. But if you think there’s something that can be improved, let us know about it. We have a v1 branch as well and the power to fix...
jimfowler
Post by jimfowler » Sat Feb 22, 2020 2:03 pm
This is so awesome. So much of the missing functionality has been restored. Steve has done a bang-up job here so massive thanks to him for taking up the mantle.
As has been mentioned, you have to bridge pins 60 and 64 on the microcontroller card but once you've got Steve's firmware loaded future updates do NOT require the pin bridging so updating is as easy as pulling the module, connecting and updating. I've attached a picture of my very elegant bridging mechanism mainly to clarify which pins are 60 and 64 in case anybody needs to know.
- Jim
stevenb
Post by stevenb » Sat Feb 22, 2020 5:39 pm
I can try and build it and see if it succeeds...
architexture
Post by architexture » Sat Feb 22, 2020 9:49 pm
I would love to help you with the testing on this.
I don't have an ST-Link programmer however. Would you be able to recommend one?
@weedywhiz ?
ArguZ
Post by ArguZ » Sun Feb 23, 2020 4:10 am
My weapon of choice
Almost all Mutables need one
https://www.mouser.dk/ProductDetail/STM ... Ixq36q1BfC
weedywhizz
Post by weedywhizz » Sun Feb 23, 2020 4:11 am
Yepp, exactly what I‘m using here
Buchla format cases & parts - www.samodular.com
stevenb
Post by stevenb » Sun Feb 23, 2020 7:44 am
That's what I'm using too!
architexture
Post by architexture » Sun Feb 23, 2020 11:40 am
Awesome!! Thanks so much guys, I'll snag one and report back.
stevenb
Post by stevenb » Sun Feb 23, 2020 12:36 pm
Don’t forget
- Jim
architexture
Post by architexture » Sun Feb 23, 2020 1:57 pm
BTW I opened a couple of Pull Requests that I think might help.
jimfowler
Post by jimfowler » Sun Feb 23, 2020 2:29 pm
Anybody know of an easy-for-somebody-who-is-borderline-computer-illiterate way to load the firmware via MacOS? I've tried both versions of the official ST program and both install but neither will load/run.
ArguZ
Post by ArguZ » Sun Feb 23, 2020 3:25 pm
Yeah, don't....use windows...parallels will work just fine
cygmu
Post by cygmu » Sun Feb 23, 2020 3:37 pm
Do you mean the new STM32CubeProgrammer software? I have used that quite happily on my Macs. I haven't built my MARF yet so can't tell you if it works on that but I don't see why not: it's programmed everything else I've connected it to. I'm on OS 10.14.6 and STM32CubeProgrammer 1.4.
architexture
Post by architexture » Sun Feb 23, 2020 3:39 pm
It looks as if some dependencies that are not included under the hood in MacOS need to be installed through homebrew.
I can let you know once my ST-link comes in (I refuse to use windows for anything, whether in a vm or not)
architexture
Post by architexture » Sun Feb 23, 2020 4:14 pm
Also @jimfowler did you see the comments in this thread about needing to jumper two of the pins on the board to program the firmware? It's a known issue.
msprigings
Post by msprigings » Sun Feb 23, 2020 6:37 pm
The bugs for v1 are related to saving correct?
stevenb
Post by stevenb » Sun Feb 23, 2020 9:54 pm
STM32cubeprogrammer, https://my.st.com/content/my_st_com/en/ ... eprog.html requires java version 1.8.0_241 to run properly. I had to remove the version of java that was on my Mac (v 13 something I believe) and download and install the proper version from the oracle website : https://www.oracle.com/java/technologie ... loads.html
jimfowler
Post by jimfowler » Sun Feb 23, 2020 10:21 pm
Yeah, I’m the one who posted a picture of this a few posts up...
Steve swooped in and helped me get my programming program set up. I never would have figured it out (java something something) but thanks to him now I no longer have to schlep my work computer home.
Electrostatic
Post by Electrostatic » Wed Feb 26, 2020 6:28 am
Have just updated my REV 2.1s with the new firmware and just done a very quick check on the advance issue and clocking using stop (not firing gates) and they both work... Absolutely made up. :banana:
Will give it an in-depth test tonight or tomorrow.
Thanks so much to stevenb for tackling this. It's very much appreciated. :hail:
mestlick
Post by mestlick » Wed Feb 26, 2020 3:18 pm
I must have a Rev 1, because I can program stop on every step and externally clock and use the pulse outputs.
What does the "ref." output do on Rev 2 when a stage hits a programmed stop?
On Rev 1, the ref output falls from high to low during the time programmed, but then goes fully high once the stage stops.
This makes it all but useless when programming all stages to stop, and clocking externally.
I would love it if the ref output would stay low when a stage hits stop. Then the ref output could be used as an envelope when clocking externally.
mutierend
Post by mutierend » Thu Feb 27, 2020 9:02 pm
Never mind, I can't read. ;)
stevenb
Post by stevenb » Fri Feb 28, 2020 5:24 am
Here's the latest alpha build. This one fixes a problem where the programmed pulse from AFG2 was incorrectly being sent to the AFG1 spigots instead. This build comes from the code in the MARF v2.5 repository located at https://github.com/wir35/marf/tree/v2.5
Enjoy,
Steven
MARF_v2.5a7.hex.zip
jimfowler
Post by jimfowler » Sun Mar 01, 2020 7:24 am
Working well here. Anybody else wanna confirm?
batchas
Post by batchas » Sun Mar 01, 2020 12:47 pm
Exactly.
Save is not working. Sometimes all LEDs will lit on when loading a preset. Sometimes you'll be able to go back to where you were (last settings), sometimes not.
I tried also with B248-v1.2.hex version. Same issue. Such a shame.
Is save/recall working on Rev 2? Is it something changed in the circuit, or is it solved via firmware if it works in Rev 2? If solved via firmware, than it should be easy to implement for Rev 1 248r.
FS: New Orgone Accumulator MK2 for BugBrand/FRAC
www.batchas.com
