Serge boats
weedywhizz
Serge boats
Post by weedywhizz » Wed Jan 08, 2020 7:18 am
I'm about to finish the design of black powder coated or anodized Serge boats that will work with my cheeks @ samodular.com
Anything you Serge guys would like to see added to the boats ? Like additional cutouts for power cables or something else ?
Please let me know.
Thanks.
Buchla format cases & parts - www.samodular.com
deltaphoenix
Re: Serge boats
Post by deltaphoenix » Wed Jan 08, 2020 9:19 am
How about XL length boats
luchog
Crazy Pony
Re: Serge boats
Post by luchog » Wed Jan 08, 2020 10:18 am
Seconded, and with attachment points to handle R*S 4x4 as well as STS Shop and M-class panels.
Possibly an extra mounting point for R*S MTA distro board as well.
weedywhizz
Re: Serge boats
Post by weedywhizz » Wed Jan 08, 2020 10:24 am
XL boats - sure why not.
Need to check the exact mounting hole spacing for RS modules.
levelhead3
Re: Serge boats
Post by levelhead3 » Wed Jan 08, 2020 12:16 pm
Second the idea for extra mounting point for the R*S MTA distro board, especially since it looks like the side mounted XLR jack is going to have to go.
Here's a thread with the 4x4 dimensions - almost Buchla, but not quite... :doh:
viewtopic.php?t=215425
dbernhardt58
Serge boats - compatibility with Loudest Warning screws
Post by dbernhardt58 » Wed Jan 08, 2020 1:53 pm
As long as we are getting compatibility with R*S 4x4 as well as STS Shop and M-class panels - could we also be compatible with the Loudest Warning mounting design?
weedywhizz
Re: Serge boats
Post by weedywhizz » Wed Jan 08, 2020 2:08 pm
Awesome guys, will make a new drawing asap for larger boats with added RS mounting points :)
wavecircle
Big Audio Sodomite
Re: Serge boats - compatibility with Loudest Warning screws
Post by wavecircle » Wed Jan 08, 2020 2:20 pm
I mentioned about LW format on the Facebook post. It seems lots of 4U builders follow the LW format which I believe is Eurorack rails but separated at 4u heights. I imagine this is a very significant number of Serge/4U systems out there and the number of builders for this format seems to be growing steadily. I have wanted one of your cases for years in Serge (LW) format.
Instagram: https://www.instagram.com/thezyg/ (lots of Serge)
[s]http://bit.ly/2Mekran[/s]
Ciat Lonbarde stuff from many moons ago: http://soundcloud.com/polska-kliknij-muzyka
dubstephead
Post by dubstephead » Wed Jan 08, 2020 3:52 pm
weedywhizz
Post by weedywhizz » Thu Jan 09, 2020 5:27 am
Got you guys. Let me finish the STS/RS version first and I'll think aout the LW version.
Meanwhile a made a new drawing with RS module mounting holes and the XLR/MTA connector hole added.
The XLR/MTA hole can be closed by optional small panels or even 3D printed panels.
Will do the XL version now.....
widdly
Re: Serge boats
Post by widdly » Thu Jan 09, 2020 6:55 am
Are the panel mounting holes threaded?
weedywhizz
Re: Serge boats
Post by weedywhizz » Thu Jan 09, 2020 6:56 am
Yes they are.
syncretism
Morbidly self-aware and liking it
Re: Serge boats
Post by syncretism » Tue Jan 14, 2020 1:36 pm
Hey, hello,
How deep are these boats (internal dimensions)? Thanks!
xonetacular
Re: Serge boats
Post by xonetacular » Tue Jan 14, 2020 1:47 pm
Having the xlr hole on the back only is problematic if you are using the RS power supplies as most use one cable per boat and it would get blocked if you stack them.
What's the price point you are expecting?
weedywhizz
Re: Serge boats
Post by weedywhizz » Tue Jan 14, 2020 2:07 pm
Full depth of the boats is 78mm. So 76.5mm for you panels.
@xonetacular
Fully agree. Having the XLR ports on the side will prevent them from being mounted to cheeks though.
There's always the possibility to directly wire the distro board to a XLR plug and feed it through the other hole on the back.
Does anyone have the spacing of the mounting holes for the RS distro board ? Will make holes for it then to fix it to the boat.
Aiming a price of around 100€ for a black powder coated boat.
I'm open to any ideas :)
rampy
Re: Serge boats
Post by rampy » Tue Jan 14, 2020 6:16 pm
What is the spacing for the holes on the side? I use Intellijel 4u rack ears and am curious as to whether these are compatible. The rack ears have 2 sets of holes, one spaced 167.5mm apart and the other 88mm apart.
xonetacular
Re: Serge boats
Post by xonetacular » Tue Jan 14, 2020 9:01 pm
@xonetacular
You could always do both if you have little plates to block them off, and if they use cheeks it would block the empty hole anyway. Some people won't use cheeks and just want a cheaper boat option. Also it doesn't have to prevent them from being mounted to side panels. The side panels just need a hole in the side for each connection.
Feeding a whole xlr power cable through multiple boats doesn't really make sense. If you are using multiple boats the main benefit imo of using separate cables for each is the ability to lower resistance through multiple cables. For a 3 boat setup I would rather just have 3 xlr jack openings on the back of one boat and I would wire them and everything internally to my own distribution.
Even if you wanted to use the PSD boards in each boat you only need the xlr jacks on one and can wire the boards to the jacks separately between the boats.
weedywhizz
Re: Serge boats
Post by weedywhizz » Wed Jan 15, 2020 3:14 am
Totally got the wiring stuff and I didn't mean poeople could feed the power cables through the boats to connect this way.
You could feed cables to each boat with each cable having a XLR plug installed and the other end going to the PSD or RS distro board - using the standard Serge hole on the back of the boats.
That reminds me of getting holes for the Serge PSD done as well :tu:
luchog
Crazy Pony
Re: Serge boats
Post by luchog » Wed Jan 15, 2020 2:23 pm
Yes they are.
What screw are they threaded for? Standard M3 or a different size/pitch?
weedywhizz
Re: Serge boats
Post by weedywhizz » Wed Jan 15, 2020 2:25 pm
M3
harolddonnelly
Re: Serge boats
Post by harolddonnelly » Wed Jan 15, 2020 11:56 pm
These look great, definitely interested in the XL version. Is it going to be approximately 100€ for the XL? And are you thinking one without the powder coating?
weedywhizz
Re: Serge boats
Post by weedywhizz » Thu Jan 16, 2020 3:29 am
No, aiming at 129€ for the black XL version - just like my 6U Buchla boats. No plans yet to make boats without powder coating. Those are already available by RS and it is not my goal to push RS out of the market with cheaper boats. The goal is to make boats that also work with my Buchla style cheeks.
prtcl
Re: Serge boats
Post by prtcl » Thu Jan 16, 2020 10:27 pm
I would also be interested in LW format boats. Something like your 8U buchla case with the side cheeks would be really nice!
harolddonnelly
Re: Serge boats
Post by harolddonnelly » Fri Jan 17, 2020 12:44 am
Totally understand, thank you for your hard work and effort I look forward to being able to order the boats! I'll be sure to keep an eye out!
Corrupt
Re: Serge boats
Post by Corrupt » Fri Jan 17, 2020 4:34 am
Very cool. Following closely.
