Hello Hordijk System
100000bps
Re: Hello Hordijk System
Post by 100000bps » Wed Jan 15, 2020 6:40 am
Well, thank you for suggestions :)
Myy plan is really to replace benjolins and use 5U : OscSync/Rungler/TwinPeak & OscSync/Rungler/Shaper/FreqShift - as "much beefier" benjolins instead. Ideally i'd love to have Benjolin with clock in, the 5u rungler switch, the loop in and sine out but thats not happening so... beggars cant be choosers :)
I already have 6u 104 of eurorack that will do everything else. I love the formanty stuff from OscSync demos, and my use of benjolins is usually in similar sound venues.
Q: which type of PSU connectors should i choose? 12v or 15v?
Q2: anyone can give me W x H size of a panel?
Thats 126 hp MDLR case adapted to 5u... eurorack is already here, just switching 2 benjos for elements.
Corrupt
Post by Corrupt » Sat Jan 18, 2020 4:02 am
Quick question – something I've been wondering about since my system arrived. In addition to the node "pins"/banana convertors, Rob also sent two pairs of two different kinds of node connectors.
The type on the bottom, from what I can gather, is the one mentioned in the node matrix manual: "You module comes with two black plugs with white coding rings. These two plugs have an attenuating resistor inside that will attenuate a synth level signal by roughly —16dB"
All good, and it appears to do just that. But what is the wholly metallic one for?
Neovintage
Post by Neovintage » Sat Jan 18, 2020 4:45 am
Yes the bottom one is for "line level" output. But I never saw the upper one. Really don't know what it is. Ask Rob. And please post the answer here :miley:
thehordijkmodular.blogspot.fr
Neovintage
Post by Neovintage » Sat Jan 18, 2020 4:54 am
I would keep the Benjolins. Benjolins, Blippoo Box and Rungler module are different flavors. Even if they shared the same spirit, the circuits differ at some level. One cannot replace the others.
You can already lock the Rungler in the Benjolin with the switch. You have Tri Out instead of Sine Out which is also cool. You can also mod the Benjolins like Casper Electronics did.
Rob is using Meanwell PSU. I don't remember which one. If you order panels you can also order the PSU which I highly recommend. About size, a triple panel is around 325x222mm.
ear ear
Post by ear ear » Sat Jan 18, 2020 12:44 pm
Sorry if I'm getting the wrong end of the stick here, but I don't think you can order exactly the module combination shown above from Rob with one of his cases. You'll need a Node Processor with the power inlet. As far as I'm aware Rob only sells full systems to new customers. Please correct me if I'm wrong.
He throws the ink first and works out what it is later. "I've got to turn that into parrots." - Ralph Steadman
Neovintage
Post by Neovintage » Sat Jan 18, 2020 4:08 pm
Last time I asked that is what he said but maybe he changed his mind.
Corrupt
Post by Corrupt » Sun Jan 19, 2020 8:19 am
Eureka. Reply from Rob:
"In principle all connectors are DC-coupled, meaning that audio and LFO signals that swing around ground can be freely mixed with CV signals that may be at a constant positive or negative voltage. Th golden plugs have a capacitor inside, which does pass audio signals but block any constant positive or negative CV voltage (=the DC-part of a signal). This may sometimes be of interest.
You can check the difference by feeding a LFO pulse into the A or B audio input of the Twinpeak filter, set at a high resonance. If you couple it directly you hear that there is a slight 'dunk' in the pitch, like if the filter was modulated slightly by a short-decay envelope. But if you route that LFO pulse through the matrix using a golden plug before going into the filter you hear that the 'dunk' has gone and the pitch seems steady. Btw, myself I like the 'dunk', its more organic.
Another use is if you feed that same LFO pulse through a golden plug to a ringmodulator, e.g. to the mod input of a bipolar VCA or the mod input of the RM/VCA in the Waveshaper or Fader in RM mode. It is now only the flanks of the pulse that shortly open the RM and you get a rhythmic effect.
A third use is when you connect a signal from the outside world that comes from e.g. a device powered by only five volts e.g. USB powered). Some of these devices have the output swing around +2.5V instead of around ground, and then you can remove that +2.5V component in the signal with a golden plug before further processsing. This was actually the main reason why I added this plug, as some system owners badly needed this."
100000bps
Post by 100000bps » Tue Jan 21, 2020 9:04 am
Well, at least from my short exchange of emails with Rob it seems he does single triple panels...
Anyone can tell me please whats the depth of case/tripple panel ? Planning a portable case, need some dimensions.
Return to “5U Format Modules”
