My next challenge - a Poly Oakley
magman
Post by magman » Mon Sep 03, 2018 2:51 pm
Things have been ticking over quite nicely recently.
I had a few parts deliveries in the last week, including most of the almost 200 pots I will need for this project.
This is a photo from last Thursday, with quite a few PCB’s mostly populated, apart from a few parts that are on order.
That’s 2 normal VCO’s, 1 S-VCO with 4 octave boards and 3 VCO Controllers mostly built. Since then I have completed 3 SVCF’s, 2 FourMix’s and I’m will on with 2 Diode Ladder filters.
I have also ordered and received 3 active mults from dslman, which is one thing I overlooked in the original design.
Last but no means least, I decided to add some MultiMix’s to the design, so that I can mix the filter outputs before patching them to the ADSR VCA input. I have 2 of these in my existing modular, so will be adding two more from Mr Allgood.
Off to warm up the soldering iron again.
Regards
Magman
Next Liverpool Synth Meet - it’s 11th April 2020
jean_schön
Re: My next challenge - a Poly Oakley
Post by jean_schön » Wed Feb 12, 2020 5:54 am
Hey, any update on this project?
oozitron
solder fume huffer
Post by oozitron » Sun Feb 23, 2020 8:43 am
I am just finishing my Poly Oakley - actually I call it the Oakleyheim Four Voice.
Four ASVs and a Yarns. It is sounding awesome. My dream (since high school in 1980) of having a 4VS is coming to fruition :-)
Drew
Never want to come down, never want to put my feet back down on the ground
snevlida14
Post by snevlida14 » Mon Feb 24, 2020 8:02 pm
:sb: :yay:
Flareless
Post by Flareless » Mon Feb 24, 2020 8:56 pm
Drew
Nice! :yay:
Got pics?
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
oozitron
solder fume huffer
Post by oozitron » Wed Feb 26, 2020 3:49 pm
One voice:
The whole deal:
It sounds fooking incredible... I get lost for hours playing with it
Drew
Dr Gris
Post by Dr Gris » Wed Feb 26, 2020 4:44 pm
Fantastic!!
Would love to hear it. I really enjoy my single Oakley ASV. It's a bit polite sounding but great nevertheless.
//M
oozitron
solder fume huffer
Post by oozitron » Sun Mar 01, 2020 1:09 pm
Made a few demos. Recorded live (no overdubs but I chopped out all the time I took changing all the knobs!) with a bit of echo, but no other effects at all. (the filter can certainly create the impression that there's a phaser or flanger involved).
Voices are panned. Headphones recommended!
This one only uses VCO1 (no VCO2 or sub) and lets you hear what the filter does:
https://soundcloud.com/oozitron/oakelyh ... ice-demo-1
Both VCOs going on this one. A little "Weather Report"-ish/BoC with some Rush at the end :-)
https://soundcloud.com/oozitron/oakleyh ... ice-demo-2
Some more... (with lots of VCO sync turned on)
https://soundcloud.com/oozitron/oakleyh ... ice-demo-3
Drew
Dr Gris
Post by Dr Gris » Thu Mar 05, 2020 12:56 am
Superb!!!! :hail:
Darn... now I need three more...
//M
Sir Ruff
Post by Sir Ruff » Thu Mar 05, 2020 7:35 pm
One voice:
The whole deal:
Drew
I definitely prefer those knobs to the ones that Oakley has, and I also like how you color-coded envelope one functions. What is the name of that type of knob again?
Benjamin Vraja (1950-1996) - Anthology: https://benjaminvraja.bandcamp.com/album/anthology
oozitron
solder fume huffer
Post by oozitron » Thu Mar 05, 2020 10:17 pm
They are Davies 1900 clones. Modular Addict, SynthCube and Small Bear have them.
I used Dark Grey for the LFO Freq and the 3 LFO mod amounts
I used Light Grey for the ADSR #1 pots and the 3 ADSR #1 mod amounts
The rest are Black, except for the VCO2 fine tune and the VCF Freq. Those were for a 1/8" shaft and I had to dis-assemble them, drill them out and then put them back together. Several got damaged in that process, but it was worth it because they look so Oberheim-ey.
The different color / size knobs make it much easier to quickly program; 112 of the exact same knobs was tricky to deal with!
If you have black panels, I wouldn't suggest black knobs. I went with white panels for the Oberheim feel :-)
Drew
Sir Ruff
Post by Sir Ruff » Mon Mar 09, 2020 12:03 pm
thanks... exploring this and other knob options. I actually like the classic moog style knobs on the top half of Tony's panel on his site; I just don't like those straight knobs used for envelopes. I suspect he chose those to avoid cramping, which I definitely appreciate (and care more about than style). But if there is something similarly narrow that would look better, I'd go for it. I don't think Davies + Moog style would look that great, but maybe?
nuromantix
Post by nuromantix » Tue Mar 17, 2020 6:04 pm
Amazing
magman
Post by magman » Wed Mar 18, 2020 1:16 pm
Sorry I took so long to send an update, I only just figured out how to attach images in the new forum software.
Virtually all of the modules are complete, though I do also have to debug a few of them still.
I have temporarily installed the Poly modules in my “portable rig”, this photo is from the Birmingham synth meet a few weeks ago. I do plan to remount these in another case, as each voice works out at 12U. I also want at least 2U of modules in front of the voices to add some additional modules, such as MIDI to CV and some active mults.
I use 2 MIDI-CV modules, one from Hexinverter, for the Poly CV and Gate, as well as an Oakley midiDAC, as this gives controls for pitch bend and aftertouch, amongst others.
In this photo, the three cases on the left are 3 “Voices”, the three on the right are 1 more voice, ancillaries - including MIDI in the second case and the second set of filters and a couple of mixers in the third case.
I had most of this finished for Synth DIY at Cambridge last year, including the Front Panels, but other projects have distracted me since then.
I plan to go through the whole system again in the coming weeks, debugging and tweaking, then build them into a more useful home.
Regards
Magman
oozitron
solder fume huffer
Post by oozitron » Thu Mar 26, 2020 9:07 am
A little demo of my Oakleyheim Four Voice:
Drew
wiperactive
Post by wiperactive » Thu Mar 26, 2020 10:46 am
Fantastic work. If I hadn't already splashed out on a DSI OB-6 desktop (not the same in certain key respects, I know) I would seriously consider this as a project on the strength of this.
Your commentary/instrument sound balance on this vid could be better though.
Return to “5U Format Modules”
