Expert Sleepers Disting Mk4
Would you buy a ES Disting Mk.4 in Synthesizers.Com format?
Yes
11
58%
No
6
32%
Depends on if there is one (1) or two (2) Distings behind a 1MU panel.
2
11%
Total votes: 19
Thorsday
Post by Thorsday » Fri Jan 17, 2020 8:17 am
https://www.expert-sleepers.co.uk/disting.html
viewtopic.php?f=16&t=175310&start=1725
The flashy 3.5mm jacks would be present and normalized to 1/4" jacks, juxtaposed in the same relative layout just below, and, both sets will be essentially simultaneously available. 1/4" jacks native only will save space.
The euro-centric jacks and push encoders will nut to the 5U panel, and the stock knobs will be replaced with small Cosmo knobs, staying uniform with the format.
A +\-15V to +\-12V converter with Synthesizers.Com power header will be built in. The circuit runs safely at +\-15V. There will simply be a Euro to Dotcom power header adapter. Although it does draw a lot of current on the + rail.
Panels will be Synthesizers.Com blanks, silkscreened with applicable reference designators.
Should there be a simple passive multiple added to the 1MU panel, MIDI I/O on five pin DIN sockets implemented, or should two (2) Distings be mounted for a dual channels jobber?
I am trying to gauge and decide on quantity for a first run. :help:
sduck
experimental use of gravity
Re: Expert Sleepers Disting Mk4
Post by sduck » Fri Jan 17, 2020 10:54 am
I'm not really sure how you're going to fit 2 of those behind a 1 MU panel. I suppose it could be done.
A really nice multi-tool in a similar vein would be an ornament and crime - that would also fit well in a 1 MU panel.
Ockeghem
missa propecia
Post by Ockeghem » Fri Jan 17, 2020 12:17 pm
I selected “yes” and “it depends...” since this is my best answer right now :despair: maybe a two unit panel would work? :hyper:
synthnut wrote: This is certainly a renaissance with bells and whistles on in the modular world. More MU is good for you, that's my motto...
TTFN,
Ben
Thorsday
Post by Thorsday » Sun Jan 19, 2020 5:36 am
Disting destroys Ornament & Crime...
sduck
Post by sduck » Sun Jan 19, 2020 11:41 am
I have both, and that's completely incorrect. They are very different things.
Thorsday
Post by Thorsday » Mon Jan 20, 2020 12:57 am
So you find the quality of algorithms and means of manipulation/work flow to be very different?
What I should have said was, Disting Mk4 ticks all of the boxes for my intents and purposes, where O&C would not compliment my modular as well. I already have NLC Chaos and ASR modules... A strong sequencer selection, switches, quadrature LFO, bouncing ball envelope generators and so on. The overlap role O_C plays is more so than Disting, in my opinion. That being said, Disting will have an overlapping role, as well, but there are a handful of algorithms Disting brings to the modular that I do not already have or I can use secondaries of, with absolute certainty.
Do you have the Mk4 Disting, or an earlier one?
sduck
Post by sduck » Mon Jan 20, 2020 11:47 am
I have the new one, upgraded to whatever the newest firmware is. And yes, it has a lot more "stuff" available, although some of them are not the greatest implementation of said stuff. I find that the o+c and the disting actually complement each other well - the o+c does quantization and multiple complex envelopes really well, and you can have 4 at a time - whereas the audio processing - reverbs and delays in disting are nice to have, especially in such a small package. When I pack up my euro travel case, I put both in there. But it really depends on your needs and tastes, right? So if you could only have just one (and who wants to be limited like that?) you might want to investigate further, determine which one hits the most sweet spots.
Oh, and JLR pointed out to me that because Free State FX totally rocks, the o+c is already available in MU 1U form - https://www.noisebug.net/collections/mo ... ment-crime
hamildad
Post by hamildad » Tue Jan 21, 2020 8:56 am
Not been following Disting since I got a Mk1, ( or earlier when OS previewed it at a synth meet for me).
but no Eurojacks please, not useful and possibly an eyesore.
flashing 1/4 jacks if such a thing exists, as you need it to gauge LFO rate etc.
also if there are behind panel things such as MIDI/SD card, it would be great to have that on the front panel. I never really change my synth and dont like to have to unscrew panels from wood rails if I can help it.
happy to have one unit per 1U panel and also happy to have a multiple if there is space, but honestly make the panel work for the format.
I often wonder, why OS and other makers dont just do 5U PCBs and let the DIY/other makers do the hard work.
I would prefer a larger dot matrix screen but not possible on a simple euro>5U conversion.
Thorsday
Post by Thorsday » Wed Jan 22, 2020 12:24 am
Thank you... I agree completely.
SD Card slot is on the front on Mk4.
Now, I have arrived at the following decisions:
1. To omit the 3.5mm jacks, largely due to the fact that ES has the charge to do so... I can receive PCB's in quantity, fully populated, without jacks installed. Andrew Ostler actually holds the patent for these fancy jacks, so, perhaps down the line, a 1/4" socket could come about? Not on this run, or anytime soon, though.
2. Five-pin DIN MIDI IN and OUT sockets.
More to come...
Thorsday
Post by Thorsday » Thu Jan 23, 2020 3:14 am
It is a possibility that bi-color, through panel LED visual indicators will be worked in. So the flashy jacks will not be missed...
I think each LED should be mounted alongside its respective jack.
Juice is not worth the squeeze on this endeavor.
seta666
Post by seta666 » Sat Jan 25, 2020 2:48 pm
Hello,
I like the Disting a lot, like people say is the eurorack swiss knive. However I am not busing as much as I should.
Seeing what I have (or more important, what my system lacks) what do you think would be the best Disting mk4 programs I should try off?
https://www.modulargrid.net/e/racks/view/1112582
I work with ableton, I want to use mutan brain to sequence DFAM (2 note, velocity plus modulation wheel) and to send different clock divisions, SQ1 can act as cv modulator or sequencer, depending how I feel.
I use Kermit as LFOs or 3rd OSC for DFAM, sometimes 0-Coast Contour to give DFAM a proper amp envelope. I love DFAM as a synth too
Regards
PD--I think this post should go to the main Disting mk4 thread, I did not realise this was a different one
Thorsday
Post by Thorsday » Tue Jan 28, 2020 12:12 am
I like the Disting a lot, like people say is the eurorack swiss knive... I think this post should go to the main Disting mk4 thread, I did not realise this was a different one
Me too, and apparently eight other wigglers who read the 5U forum.
As for taking this to the main thread... I disagree. Now, when I have a finished Synthesizers.Com format Disting Mk4 operational, I will post a pic in the main thread, for certain.
seta666
Post by seta666 » Tue Jan 28, 2020 3:19 am
I mean my own post, I thought I was writing in the main Disting mk4 for eurorack as I was asking for advice.
By the way, you " 5U people " :mrgreen: also deserve to have a disting mk4 in your rack, it is great module..
Faustgeist
Post by Faustgeist » Tue Feb 04, 2020 9:15 am
I would certainly like a Disting Mk4 in MU!
Trying to build up my 5U/COTK/MOTM and MODCAN B, send me a message if you are selling gear and thanks!
Synth Con Meo
Post by Synth Con Meo » Tue Feb 04, 2020 2:08 pm
Yeah I also think it would be a great module to have in MU.
Synth Con Meo
<RIP> Kibou, I miss you.
Return to “5U Format Modules”
