Case Study Poll for moog format users
what width is your case
8 spaces or less
11
17%
9 spaces or more
48
76%
both
4
6%
Total votes: 63
companyofquail
Post by companyofquail » Thu Mar 12, 2020 2:24 pm
just curious what people are using the most. thanks!
Last edited by companyofquail on Thu Mar 12, 2020 9:45 pm, edited 1 time in total.
sduck
experimental use of gravity
Re: Case Study Poll
Post by sduck » Thu Mar 12, 2020 8:35 pm
Spaces? What exactly do you mean here? Are you asking about MU single space modules, or want to be a bit more inclusive? For example, my MOTM cabinets are 24U wide. But if I were to start putting MU modules in them, not as many would fit.
snevlida14
Re: Case Study Poll
Post by snevlida14 » Thu Mar 12, 2020 9:18 pm
3x cases stacked, all 16 MU wide
companyofquail
Re: Case Study Poll
Post by companyofquail » Thu Mar 12, 2020 9:44 pm
yes, i mean how many spaces in MU wide is your case.
Dave Peck
Re: Case Study Poll for moog format users
Post by Dave Peck » Fri Mar 13, 2020 12:21 am
Standard 22U wide studio cabinets here.
hsosdrum
Post by hsosdrum » Fri Mar 13, 2020 3:20 am
22U-wide walnut studio cabs for me as well.
FYI, the original "standard" for Moog walnut studio cases was 24U wide (Wendy Carlos's Moog is 24U wide). Moog had to switch to 22U-wide cases when they were no longer able to source solid walnut panels of sufficient width for 24U. When Wendy Carlos added a third single-row 24U case to her system in the 70's Moog used the last of the walnut panels they could find that were long enough to produce 24U cabinets.
hamildad
Post by hamildad » Fri Mar 13, 2020 5:57 am
I work with 13spaces wide..
currently having 2xcases with 3xrows of 13MU.
dont know why I ended up with this but its fine for me...
My Synth Instagram here * My Synth videos here
External PSUs and DC jacks are the hallmarks of toys. - Graham Hinton.
I am one of the "tiny fraction of a percentage of oversensitive idiots" who feels the name of this site sends the wrong message.
This is primarily for melody and historical educational purposes - Analogue Music
CZ Rider
Post by CZ Rider » Fri Mar 13, 2020 6:40 am
6 cabinets here, all 8 MU wide.
According to the Moog Archives site, it was Micky Dolenz of the Monkees that first requested the portable cabinet.
Easy to move, those Monkee cabinets. :hihi:
Flareless
Post by Flareless » Fri Mar 13, 2020 8:47 am
11 and 22 spaces wide for my cabinets
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
ranix
Post by ranix » Fri Mar 13, 2020 10:08 am
I have an 8-space wide 2-post rack, a 10-space wide cabinet, and 3 22-space wide studio cabinets
fac
wig MUffler
Post by fac » Fri Mar 13, 2020 10:32 am
I started with dotcom portable cabinet (11 spaces wide), then got another of those. Then got a 20U rack (8 spaces wide x 4 rows), but eventually replaced it with a nice custom studio cabinet 24-spaces wide x 2 rows.
Currently, my two portable cabinets are on top of the large studio cabinet, and the rack is used for effects.
cornutt
Fig juggler
Post by cornutt » Mon Mar 16, 2020 3:12 pm
About 24, but I use a mix of MU and MOTM modules. So it depends on the module mix on a given row.
Sequence 15 -- sequence15.blogspot.com
synthetek
Post by synthetek » Thu Mar 19, 2020 6:06 pm
I have a single row 11 MU wide , for now.... :deadbanana:
smbenn
Post by smbenn » Mon Mar 23, 2020 6:28 am
I'd imagine the majority of MU/5U users initially went down the dotcom route hence multiples of 11...
Si 'Electric Ape'
44SP MU modular 3 x VCO, 2 x VCF, 2 x 960
Roland JUNO-60, SH-101, TR-606, TR-707, TR-727, (TT303), JV-1010, JX03
Korg ER-1, Volca Sample
Yamaha TX81Z
Jen SM2007
Arturia DrumBrute
Synthstrom Deluge
zeta
Post by zeta » Mon Mar 23, 2020 12:12 pm
4x14 MU & 1x17 MOTM, which is the same width as the MU cases.
Racks'NTracks ig.welt_am_draht
zeta
Post by zeta » Mon Mar 23, 2020 12:17 pm
Hi, what are those black squares over the atari & c64(?), monitors?
Edit: ahh i really like your “8-space wide 2-post rack”!
ranix
Post by ranix » Mon Mar 23, 2020 12:24 pm
Atari and Amiga, the c64 is on the far right. Yep, those are special monitors that can sync with old 15khz rgb inputs. The Amiga is for sampling / tracking and the Atari runs the DAW (Cubase) that controls all the synthesizers. The C4 is a mess, I can't get a working SID for it. Filters are all blown and at $50 a pop I'm about ready to give up on it.
Pics were taken before cabling was run, it's a lot messier now...
zeta
Post by zeta » Mon Mar 23, 2020 12:40 pm
Looks neat. Any hint on a company name, got an 1040stf since years in storage. The monitor is a pain ..., as well as the mouse.
ranix
Post by ranix » Mon Mar 23, 2020 12:43 pm
I think any monitor will work for high-res (black and white) mode. Widescreen monitors work particularly well.
If you want to use the low or medium res color modes, that's when you want to go for the special 15khz monitor. These are Benq BL702A if I remember right.
The power supplies on those old systems can go bad and produce high voltages. The first thing I did was remove the entire power supply from my atari and frankenstein a PicoPSU into it. I think almost the entire system only uses 5V so the 12V doesn't get a lot of use. It might only run the floppy drive motor?
I have a trackball on mine, there's a usb converter thing you can get off ebay
CZ Rider
Post by CZ Rider » Mon Mar 23, 2020 1:47 pm
There are some really nice upgrades available for the Atari ST. I was able to DIY a simple monitor converter using an old 13 pin DIN cable to VGA using only 3 resistors. There is a mouse converter replacing the brick STM-1 with a smooth optic type. And an external SD drive giving plenty of storage and ability to swap files with WIN computers.
Using an older 4:3 type LCD monitor. Can find these for a few bucks at thrift shops.
Close up of the SD drive and mouse.
I was lucky and grabbed many programs and manuals off eBay when there was a sell off from those that abandoned in favor of newer mac/win software. Many of those old programs are deep and unique.
Glad to see I'm not the only ST user here. Makes a great sequencer with all those fun programs. And the modern upgrades really improve the experience.
Sits right across from the modular.
ranix
Post by ranix » Mon Mar 23, 2020 1:59 pm
Wow, original copies of Dr T's - nice
Stay clear, probable centre of pestilence
Just me
Has enough VCA's
Post by Just me » Mon Mar 23, 2020 4:15 pm
1 case 11 wide. 4 cases 16 wide.
If I have water in my ear, is it safe for me to listen to electronic music?
johny_gtr
Post by johny_gtr » Mon Mar 23, 2020 4:21 pm
16u and 8u tolex cases are the best for me. And even quite portable.
modular percussion and scapes - http://ovod.bandcamp.com
mu modular space electronica https://7k-ok.bandcamp.com
umma gumma
Post by umma gumma » Mon Mar 30, 2020 8:13 am
I built my own cases out of some old wooden drawers, they are 6U wide by 4 rows tall each
x3
so kind of a narrower, taller, Moog III P
Return to “5U Format Modules”
