Plague Bearer Bare Bones Kit.....
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
TestSetRadio
Post by TestSetRadio » Fri Mar 16, 2012 1:48 pm
has anyone tried stacking two PCBs to have a dual in a single space? assuming it wouldn't be too deep to bump into the busboards, it seems with some wiring trickery and smallish knobs, this could be possible... may have to ditch the mults, or make the faceplate 2hp wider to accomodate some extra jacks.
i may have to grab a couple kits and get out the calipers.
Soy Sos
Dub Surgeon
Post by Soy Sos » Fri Mar 16, 2012 5:15 pm
Soy Sos wrote:Image
Here's my hackey double Plague mod. Looks crummy, but I love it that way!
Crappy double attenuator/distributor next to it is handy as well.
This is as tight as you can get two in one panel with no mults I think.
Oh, wait, maybe I misunderstood you. This is as tight as I'd want two P.B.'s anyway.
knob_alchemist
Post by knob_alchemist » Fri Mar 16, 2012 5:28 pm
Hey how to buy the barebones kit in Europe now?? Direct in the FoH website or will they arrive at Schneiders and EFN??
FoxtoneMusic
Post by FoxtoneMusic » Mon Mar 19, 2012 2:14 pm
Hey Knob Alchemist,
Escape From Noise will be carrying all of the barebones kits later this spring when f(h) is in full swing with production. Drop Ulf a line and he will get you taken care of.
-eric
knob_alchemist
Post by knob_alchemist » Mon Mar 19, 2012 3:50 pm
Thank you very much! ;)
knob_alchemist
Post by knob_alchemist » Fri Sep 28, 2012 6:47 am
No more see at European Distributors.... :( :(
FoxtoneMusic
Post by FoxtoneMusic » Sat Sep 29, 2012 12:55 pm
The world should have BareBones Kits soon!
catchpenny
Post by catchpenny » Tue Oct 02, 2012 1:22 pm
FoxtoneMusic wrote:The world should have BareBones Kits soon!
what I came here wanting to know, thanks!
FoxtoneMusic
Post by FoxtoneMusic » Fri Nov 09, 2012 4:18 pm
IN STOCK!!!!!!!!!!!!
nd595
Post by nd595 » Sat Jan 12, 2013 12:53 pm
Two questions to flight :
I got the Barebone kit (it is travelling in the post now from Ulf), and when I look at the photo of the kit I notice that an Att switch looks different with the photos of the commercial module (it seems bigger); if so - could you please tell me the part number of the switch you use? I made an engraved front panel according to the manual (looks stunning!), and would not like to make a different one just because of a switch.
Second question is - how do you fit the PCB to the front panel? Are there some special fittings? If so - could I possibly have a look at the photo? You said before - it is DIY, not FIOY!
With Best Regards -
nd595
davebr
Plague Bearer barebones kit
Post by davebr » Mon Mar 18, 2013 11:51 pm
I am in the process of building a 1U MOTM-style Plague Bearer module with the R4 kit. I've added a Plague Bearer module page to my site.
I noticed a few silk screen and wiring diagram issues so Photoshopped some correct images that are also on the site. I'm still machining the panel but once it is complete I will post more photos and scope images on that page.
I also posted my FPE design file and one for a dual Plague Bearer in a single 1U panel.
[EDIT - I finished the front panel, PCB bracket, and wired up the module. I milled the back of the panel in 1 mm to better fit the shaft length of the potentiometers. I updated my site with pictures and a short video.]
Dave
modintx
Post by modintx » Thu Sep 19, 2013 1:10 pm
Hi Everyone,
I have exactly the same questions posted by nd595. In my case, I have a commercial v4 with a GreyScale panel, so have the orginal panel + a bear bone kit so was hoping to make a 2nd PBv4.
1) Does someone have a Mouser part # for the Att switch used on the commercial PBv4 please.
2) Advice on best way to mount the PCB to the commercial PBv4 panel- is it the 90 degree sheet metal route using the Pots to anchor?
Thanks all. :guinness:
Return to “Flight of Harmony”
