Group buys - joysticks and pots
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
Luka
Post by Luka » Thu Jan 08, 2009 3:59 am
does that mean you will have extra joysticks to sell?
im hoping i can sort some money soon
flight
The Plague Bearer
Post by flight » Thu Jan 08, 2009 8:57 am
Yup, I'm going to try to keep some available for the DIY community.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
neandrewthal
full clout y'all
Location: Spending warm summer days indoors writing frightening verse to a buck-toothed girl in Luxembourg
Post by neandrewthal » Thu Jan 08, 2009 2:07 pm
:w00t:
Initiate the sequence, create catastrophe.
flight
The Plague Bearer
Post by flight » Thu Jan 08, 2009 2:27 pm
Damn! I hadn't seen that emoticon before! :eek:
~flight
Cybananna
Funniest Guy
Post by Cybananna » Wed Jan 14, 2009 3:37 pm
Joysticks arrived today!
Soy Sos
Dub Surgeon
Post by Soy Sos » Wed Jan 14, 2009 4:20 pm
Got mine today too. When I first saw the package I thought
"Woah, maybe Flight sent me some super secret digital glitch
delay prototype to test out!" Then I remembered....the joysticks.
:hihi:
I don't think anyone will ever be starting any
"never order from F.O.H." threads.
Keep up the great work!
wetterberg
Post by wetterberg » Wed Jan 14, 2009 4:24 pm
pics, bitches! :mrgreen:
flight
The Plague Bearer
Post by flight » Wed Jan 14, 2009 7:49 pm
Yeah, sorry guys, I haven't had time or money to do any development. Soon though (gotta get the parts!). ;)
~flight
Kwote
Voltage Controlled Crackpot
Post by Kwote » Wed Jan 14, 2009 9:15 pm
got mine too. looks good. one of em is pretty stiff though. the other is cool but a bit rough and squeaky. anyone got any tips for loosening and smoothing em up?
i figure some caig deoxit might do the trick.
kwotemusic.com
my other sites
flight
The Plague Bearer
Post by flight » Wed Jan 14, 2009 10:26 pm
Hmm, try & see if they'll work loose and free up. They are probably 10-20 years old, and the lube may be caked up. If that doesn't work, you could clean them with good isopropyl alcohol or contact cleaner. Or send 'em back to me and I'll send you some better ones.
~flight
plord
Wacky for Wiard Wiggler
Post by plord » Fri Jan 16, 2009 8:25 pm
Got my joysticks while I was in GA this week on business. Mighty quick :)
Flight (or anyone), have you got an FPD with the right cutouts and mounting screw holes etc? I'll probably jump on the DIY module kits but I have other plans for the panel.
flight
The Plague Bearer
Post by flight » Fri Jan 16, 2009 8:45 pm
I assume you are speaking of a Front Panel Express native format file? Nope. But the datasheet is below, it has the PCB hole pattern at least.
Of course, these were not designed to be panel mounted, so they don't have those specs. Which way are you mounting them - drill holes in the corners or replace the hub screws with longer ones?
Is there a way to convert other formats to FPD? I have some templates in Illustrator CS3 format.
~flight
brandon daniel
Post by brandon daniel » Mon Jan 19, 2009 3:48 pm
Got back from NAMM show, had FoH joysticks waiting on my desk, thanks man!
plord
Post by plord » Mon Jan 19, 2009 4:20 pm
flight wrote:I assume you are speaking of a Front Panel Express native format file? Nope. But the datasheet is below, it has the PCB hole pattern at least.
Hm, I could work it that way I guess but I was thinking of panel mounting for the highest density. Maybe I should get one of your "kit minus joystick" and then decide on the best construction method...
There ARE holes in the corners! I was going to tap them then find the right matching screws, or use self-tapping screws into the holes that are already there. But like I say, that may be the wrong call, so I'll wait a bit before I get all excited about panel design :)
flight
The Plague Bearer
Post by flight » Mon Jan 19, 2009 5:31 pm
Umm, there shouldn't be any holes in the corners, that's only in the new style. Here are all the joystick templates I have made, with different views, different panel options, and the PCB layout.
~flight
brandon daniel
Post by brandon daniel » Mon Jan 19, 2009 5:55 pm
Just checked the ones I received, no top screw-holes, but the rectangles that make the sides of the joystick body all have holes at the four corners far enough from the throw of the js mechanism. Some U-shaped L-brackets could allow for panel-mounting.
spbaker
Post by spbaker » Mon Jan 19, 2009 6:01 pm
mine arrived in oz today! thanx Flight!
now i'm itchin for the kit!
patience is a virtue, patience is a virtue patience is a virtue aaarrgghhhh
new DVD out now Fracture
things to listen to and look at:
http://abreojos.net
flight
The Plague Bearer
Post by flight » Mon Jan 19, 2009 6:46 pm
@ plord & brandon daniel:
The four corner holes in the templates are where the new style has them. I usually just drill holes there and use the self-tapping screws. I don't recommend using the little gaps in the corners! The housing will probably distort if you force some screws in there, as the side corners aren't fastened together. If a screw pushes out the side it will move the pot off-axis and will probably shorten the lifespan of the pot.
spbaker
lol, you're welcome!
I must apologize again, I can't believe how badly that snowstorm f*cked everything up over here.
Oh yeah:
Why do so many people not capitalize names? I see this a lot now & am a tad mystified...
~flight
brandon daniel
Post by brandon daniel » Mon Jan 19, 2009 10:04 pm
flight wrote: @ plord & brandon daniel:
Uh, yeah, I wasn't suggesting that. If you think of the housing as a cube, and the side with the js is the top, the opposite side is the bottom, the four "walls" around the side have holes, each rectangle around the outside here has four holes (not counting the ones you're talking about above) that I think could be used... you'd use an L bracket for each of the four sides (with a cutout in the center to let the pots rotate freely.
spbaker
Post by spbaker » Tue Jan 20, 2009 12:02 am
flight wrote:
Oh yeah:
capitals are SOOO 1995! :lol:
http://abreojos.net
neandrewthal
full clout y'all
Post by neandrewthal » Tue Jan 20, 2009 9:39 pm
:w00t:I got mine. Thanks so much!:w00t:
flight
The Plague Bearer
Post by flight » Tue Jan 20, 2009 10:24 pm
@ brandon daniel: Oh, those holes. Okiedokie, have at 'em!
@ neandrewthal: Yah, you got a cram-packed box o' joy. :)
~flight
Luka
Post by Luka » Wed Feb 18, 2009 4:30 am
are there still more joysticks flight?
i am doing all i can to get some spare money to you but i am being hit from all sides repaying debt. will the opp still be there within a month or so. i am after about 5 or 6
flight
The Plague Bearer
Post by flight » Wed Feb 18, 2009 9:28 am
Yup, I've got plenty, you're good. Same price too.
Oh, I understand about repayment debt...
~flight
Luka
Post by Luka » Wed Feb 18, 2009 2:52 pm
woohoo
i am about 2-3 weeks away then
Return to “Flight of Harmony”
