Can the Plague Bearer act as regular old Low Pass Filter?
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
Demi Jon
Switched Out
Post by Demi Jon » Fri Aug 10, 2012 2:32 am
I looooove what I've heard of the Plague Bearer in the demos. It sounds like a fantastic FSU module. But how does it function as a regular LPF? Can it do classic/subtle as well as gonzo/nutso, i.e., can I get a nice round cut off with thick low end resonance before it cuts out to complete silence?
If this module can perform standard filter duties AS WELL as being an awesome noise-maker, then I'm all over it. My Wasp filter in my skiff is not nearly as gritty as I'd hoped but it is lovely. My band's music oscillates between loud/distorted and quiet/delicate so I'd like something that can do both. I'll move the Wasp outta the skiff to my main 6U if the PB is a good replacement.
Any demos or opinions would be most welcome.
PS I thought I'd already posted this as a new topic, but it seems to have disappeared, so if it shows up suddenly as a double new post then I apologise.
CursedFrogurt
Square Enthusiast
Post by CursedFrogurt » Fri Aug 10, 2012 7:21 pm
Nope.
Demi Jon
Switched Out
Post by Demi Jon » Fri Aug 10, 2012 7:27 pm
CursedFrogurt wrote:Nope.
Hmmm. Not even close?
CursedFrogurt
Square Enthusiast
Post by CursedFrogurt » Fri Aug 10, 2012 8:38 pm
You get filtering action, and when you apply modulation it starts to sound more filtery with the resonance sweeping around, but it's pretty unsatisfying if approached as a conventional filter. I think it is something of a mutant bandpass filter. The high corner freq. adjustment gives you lowpass-like cutoff control, but it is tied to resonance as well.
It's definitely not all about balls out distortion and fsu, and can be quite subtle, but there's nothing conventional about it.
computer controlled
Post by computer controlled » Sun Aug 12, 2012 2:59 am
Yeah, def not for standard filtering. Calling it a filter is a bit misleading really. I mean, it IS a filter, technically. But not your conventional VCF. Also, the High is actually low pass, and the Low is actually Hi-Pass.
But, don't forget, there are no rules :tu:
Stuff: TR-8S . MX-1 . D-20 . Waldorf MicroQ . Ensoniq ESQ-1 . Ensoniq EPS 16+ . Yamaha MODX6 . DX7 . TX802 . MPC Live . RE-303 . Avalon BassLine . Behringer Neutron . Behringer MS-101 . Behringer Pro-1 . Behringer K-2 . Behringer TD-3 . E-mu EmaxSE . E-mu Emax II . E-mu EMAX II rack . PCM 41 . BeatStep Pro . Keystep .
polytoxicommander
Post by polytoxicommander » Sun Aug 12, 2012 3:53 am
can anybody pls explain "FSU"?
computer controlled
Post by computer controlled » Sun Aug 12, 2012 3:56 am
FSU = Fuck Shit Up
=o]
Demi Jon
Switched Out
Post by Demi Jon » Sun Aug 12, 2012 5:22 am
Right -- I might have to go for something like the Polivoks? Something very dirty and unstable, but still a filter. Whaddaya reckon? All respect to FoH -- PB sounds terrific, but at heart I still need a VCF/LPF.
computer controlled
Post by computer controlled » Sun Aug 12, 2012 5:32 am
The Polivoks is indeed a dirty and unstable VCF =o] One of my faves!
CursedFrogurt
Square Enthusiast
Post by CursedFrogurt » Sun Aug 12, 2012 7:22 am
Don't forget the synthacon filter!
Soy Sos
Dub Surgeon
Post by Soy Sos » Sun Aug 12, 2012 8:07 am
Love the Plague Bearer, I have 2 of them.
It is as described above.
Agreed, the Harvestman Poliviks will get you there.
Bumply
Post by Bumply » Tue Aug 21, 2012 3:42 pm
The blue lantern diode is pretty nasty and unstable.
Return to “Flight of Harmony”
