ClockBox Changes
Look forward to it very much. Wondering whether to sell the quad Divider and pick up a Dual or 2, slightly different functionality and more divisions and ratios on the quad so probably no point apart from space considerations..
Are you still building towards a clock box or has it evolved into a wider picture Tom?
- chrisdermo
- Ultra Wiggler
Looking like a clock box with more choices of smaller footprint component parts for a greater degree of personalised configurations. Like it a lot!
WTB / WTTF: Bugbrand PRC2B, DD3, PRC4, ENV1
Current Bugs frame:
https://www.modulargrid.net/f/racks/view/580413
Current Bugs frame:
Yes, generally wider picture - though I still need the dedicated clock (dropped the dual-clock idea).
But I would still like to get to the point where I can have a selection of suggested configurations for various applications - SynthVoice started that off. Other areas would be Expander, Clocking, Audio-processing - making some progress slowly on all fronts but it probably feels a bit all over the place at present!
- chrisdermo
- Ultra Wiggler
So would the joystick and bbv go in the 'expander' category while the ddsr, QDiv, dual divide, logic and diode director are clocking?BugBrand wrote:Yes, generally wider picture - though I still need the dedicated clock (dropped the dual-clock idea).
Audio-processing has me very excited
Current Bugs frame:
Current Bugs frame:
- chrisdermo
- Ultra Wiggler
BugBrand wrote:You think I have a clear plan?!
Current Bugs frame:
Current Bugs frame:
- DickMarker
- Veteran Wiggler
- chrisdermo
- Ultra Wiggler
Yes! Wildcard frame should also contain a fruit machine style rotating display that randomly stops on different combinations of CV and gate outputs. Or Oscillator waveforms.DickMarker wrote:
Joystick = wildcard
Or a theremin style CV antenna.
Current Bugs frame:
Current Bugs frame:
- knittingram
- Common Wiggler
- chrisdermo
- Ultra Wiggler
post moved to new thread
Current Bugs frame:
Current Bugs frame:
- Morbidly self-aware and liking it
- Contact:
I wouldn't turn down that dual clock at all; I reckon if I wanted a cut-down version, then a simple pulse source on the left as a master clock and a fully-featured clock on the right (for a 3 fu module?) would strike a reasonable compromise and be way, way more useful for clocking duties than the VC Timegen Clock on my Gator, eg.chrisdermo wrote:Dual Clock - What's missing for you? A clock with both straight and pwm outs to allow for swing seems totally necessary. v/oct CV response too as that allows tempo changes at precise division/multiplication via a keyboard or sequencer/quantizer. I don't know that I'd *need* two clocks along with all the support modules![]()
Your comments w/r/t the Binary Block and DDSR combo are intriguing...
- chrisdermo
- Ultra Wiggler
S+H !!BugBrand wrote:Such areas have fallen a little off the map but I think that a 2FW clock-osc along the basic lines of the dual-clock will be the way to go - just needs my attention back!
Current Bugs frame:
Current Bugs frame:
- laserpalace
- Super Deluxe Wiggler
- Contact:
After having a couple live sets take some turns because of failing external clock sources ... I've been thinking about a dedicated clock module for the bug that includes a tap tempo function. I'm completely ignorant to what this might involve but it would be cool to be able to manually control/inject tempo changes on the fly
Tap-tempo is probably not possible direct from me, sorry.
While I do still ponder on a dedicated clock module, I tend to use external devices for more regular clocking - things that can do tap-tempo or easily slave to a master MIDI clock.
Saying that, a clock module with sync input should be fine to slave to whatever external master clock you have.
PS - Chris - strange with the new S&H proto, the osc part, though unchanged, is acting up when it worked great in the previous proto.. frustrationary!
Funny cause 4 days ago I made a video about the TAP tempo function on Grilles, showing it syncing a sample on Radio Music, but then I deleted it, not happy with the video qualityBugBrand wrote:Tap-tempo is probably not possible direct from me, sorry.
I might make one on the smartphone, so I don't need to worry about quality like I do.
EDIT : see post here from Thu Nov 28, 2019.
- chrisdermo
- Ultra Wiggler
I'm hoping for a Christmas miracle!BugBrand wrote: PS - Chris - strange with the new S&H proto, the osc part, though unchanged, is acting up when it worked great in the previous proto.. frustrationary!
Current Bugs frame:
Current Bugs frame:
- laserpalace
- Contact:
No apologies necessary! I figured it was not worth the hassle and it's really only my problem with being finicky about external clock sources and having them fail on me.BugBrand wrote:Tap-tempo is probably not possible direct from me, sorry
I'm much more interested in this S/H anyways! Also should probably just check out Grilles to fix my problems.
- chrisdermo
- Ultra Wiggler
laserpalace wrote: I'm much more interested in this S/H anyways!
Current Bugs frame:
Current Bugs frame:
