Who's this little fella then? (Board Chirper)
Moderators: Kent, BugBrand
DickMarker
Post by DickMarker » Fri Jan 25, 2019 5:39 am
chrisdermo
Post by chrisdermo » Fri Jan 25, 2019 6:05 am
Lovely! Might have to pick up one to accompany my Boardweevil2012 in the future
Current Bugs frame:
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Jan 25, 2019 6:12 am
Yeah, I felt I was missing a 'board' design. Should have got it out before Christmas really - the first batch was built but took me another month to clear other things and do some (very damn basic) documentation.
cebec
Post by cebec » Fri Jan 25, 2019 8:57 am
Sounds incredible!
BananaPlug
Post by BananaPlug » Fri Jan 25, 2019 9:04 am
Outstanding! That plus headphones, tucked in a backpack, for walks in the woods. :tu:
Edit:
Okay, instead of headphones...
Though you might get some pushback!
ClausF
Post by ClausF » Fri Jan 25, 2019 9:35 am
BananaPlug wrote:Outstanding! That plus headphones, tucked in a backpack, for walks in the woods. :tu:
- minus headphones
- plus power amp to show all these other littler chirpers what is a real chirp!
rowsbywoof
Post by rowsbywoof » Fri Jan 25, 2019 11:14 am
Such a cool little guy. I was tempted, but figured I'd wait for now... Had to pick up a DRM2 today, instead. :) I can see picking up one of these in the future, though.
lud
Post by lud » Fri Jan 25, 2019 11:54 am
Beautiful little Chirper, no doubt even more fun with the touch points (really intrigued by their control - lovely graphics!). Sounds just as good as the original.
Is it exactly the same synth minus the banana jacks?
Kafgee
Post by Kafgee » Sat Jan 26, 2019 4:53 am
:wow:
BugBrand
Knowledge of Bugs
Post by BugBrand » Sat Jan 26, 2019 5:40 am
lud wrote:Beautiful little Chirper, no doubt even more fun with the touch points (really intrigued by their control - lovely graphics!). Sounds just as good as the original.
It is very similar but I had to do some distinct tweaks to get it running off a single battery. + doesn't have things like sync.
I did a pair of proto full-size chirpers with touch expanders (some might have seen pics on Instagram via Palle and MengQi) but there were design niggles I didn't like, especially on something large/expensive like that - so the small board standalone approach seemed a much more suitable place to install the touchy stuff.
lud
Post by lud » Sat Jan 26, 2019 8:02 am
Glad you solved the conundrum Tom, the Board looks rad!
southphillysynths
Post by southphillysynths » Sun Jan 27, 2019 12:21 am
Are similar plucky pining sounds still possible from the filter? Would anything be able to be soldered to banana jacks to modulate?
Dcramer wrote:"Not all who wiggle are lost" :boat:
WHO IS BOZO TEXINO?!?!
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon Jan 28, 2019 6:34 am
southphillysynths wrote:Are similar plucky pining sounds still possible from the filter?
Absolutely!
southphillysynths wrote:Would anything be able to be soldered to banana jacks to modulate?
I knew this would be asked! I don't really recommend connecting external machines (go for the proper Chirper!) and said that on the instruction sheet. Sure there'd be ways, but... as always I design for the specific purpose and this one was for portable exploritations.
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon Feb 04, 2019 10:26 am
Some minimal descriptive ideas on touchplates & combinations (not that I know them all by any stretch!) - there are some small labels on the back:::
Each OSC has four plates:
- on the outside the one above the other are square-wave (SQR) output on top and triangle (TRI) wave below
- the next block in is the CV input - try touching an osc output (either osc) back into this.
- the most central block for each connects to the comparator input (COMP)of each oscillator. Really it just seemed like an interesting node to allow access to!
The Filter has 8 plates:
- the lowest two are Filter CV (similar to Osc CV) on the right side and Filter Input on the left side. The good thing with the input is that you can turn down the Drive control (yellow knob) to mute input to the filter and then touch a signal across to the input.
- the other plates are inputs and outputs for each filter stage - Lo/Band/Hi outs and points to their input summers (labeled eg BPND = bandpass NODE)
The two triangular plates connect to V+ and V- (via current limit resistors) - the theory was that touching these along with one of the CV inputs would raise or low the section but I don't think it quite works like that in practice.
- the centre square connects to 0V and might be useful for muting certain parts or otherwise mutating behaviours.
BananaPlug
Post by BananaPlug » Tue Mar 26, 2019 5:07 pm
:mygod:
Breaking radio silence to bring you this message.
Board Chirper emanations have been detected. This may not be a test.
Threat or menace? Analysis suggests three pedals also involved.
>LISTEN<
Kafgee
Post by Kafgee » Wed Mar 27, 2019 1:45 pm
I cannot listen to the link :despair:
BananaPlug
Post by BananaPlug » Wed Mar 27, 2019 2:06 pm
I've fixed the server. The formerly broken link is working. :banana:
chrisdermo
Post by chrisdermo » Thu Mar 28, 2019 6:26 am
BananaPlug wrote::mygod:
>LISTEN<
The bit at 03:21 is pure sci fi coded message in space. Nice recording! :party:
Current Bugs frame:
Return to “BugBrand Devices”
