My Setups::::
Moderators: Kent, BugBrand
BugBrand
Knowledge of Bugs
My Setups::::
Post by BugBrand » Tue Jun 25, 2019 4:55 am
Stupidly I didn't snap my home 5Frame setup before taking it apart to make the current 4Frame Travel system. DAMN.
But I thought I'd share a pic to show my approaches:::
Top Row - COFilter (Aux 1), PT Delay (Aux 2), SComp (Group1/2 bus)
Row 2 - 3 x CVCO (cross modulating one another), DDSR, DRM2
Row 3 - 2 x DDiv, DDSR, DFilter, DAmp, DMix [two filters for pinging rhythmically]
Row 4 - Grids, DDiv, Penrose, Tresses, DFilt, LPG, PTDelay [Tresses chain pre-patched with pomonas as socket spacing is 0.75"]
Sonic Potions LXR drum machine for extra drums & trigger I/O
Soundcraft 12MTK with Aux3 going to Eventide PitchFactor and OTO reverb
chrisdermo
Re: My Setups::::
Post by chrisdermo » Tue Jun 25, 2019 5:38 am
BugBrand wrote: Row 4 - ... LPG, PTDelay
OTO reverb
Nice four frame! So those are 2 x 2 frames conjoined with dual end cheeks right? How does that little wooden prop work? Do the frames screw into that too or do they just rest there?
:ripbanana:
LPG and PT Deay designs look awesome, PT Delay in particular is quite different from the old one. Is that an input level control for one of the two inputs? and just 1 CV input I think? Would love to see the I/O and labelling on the LPG up close.
How do you find the OTO reverb by the way? I've been toying with the idea of getting one for some time. You were using an eventide one before if i'm not mistaken? Which do you prefer?
Current Bugs frame:
BugBrand
Knowledge of Bugs
Post by BugBrand » Tue Jun 25, 2019 6:18 am
Heres pics of the 4Frame approach for travel - yes, 2 x 2Frame with four bolts on each replaced with butterfly bolts. Seems good - quick to set and nice & stable. Of course, not a briefcase solution but still...
Will post details on LPG soon. PT a little further away.
OTO - tends to just be set & forget for me (as with many reverbs). Got it in part trade I think and tend to like it more than the Space which I found a little weird compared with other Factor pedals (had some great sounds in it though). Dunno, both are good & still have the Space (oops)
shred
desperation tentacle
Post by shred » Tue Jun 25, 2019 7:26 am
very cool to see, and lovely setup!
so what are your main "voices" you go for in this configuration? DRM2, filter pings, and Tresses? seems like a lot of dividers but I guess there are lots of clocking abilities so the more the merrier.
How are you finding the travel with this setup? Do you have a case or bag that everything fits into? (sorry for the prying questions, I like figuring out portable solutions.. I'm working on a briefcase for my two frame atm).
LPG! yes :guinness:
A Dingleberry Monstrosity wrote:CATS OR GTFO!!!!!
www.shredderghost.bandcamp.com
chrisdermo
Post by chrisdermo » Tue Jun 25, 2019 7:27 am
BugBrand wrote:Image
Yeah that's neat! I like it. I wonder if there is an off the shelf 'suitcase' somewhere that'd fit 2x2frames.... :hmm:
Current Bugs frame:
chrisdermo
Post by chrisdermo » Tue Jun 25, 2019 7:31 am
shred wrote:very cool to see, and lovely setup!
There's those 3 cross-modded oscillators too!
Surprised to see no logic module in this setup. But then, the SL grids can do fancy patterns :party:
Current Bugs frame:
shred
Post by shred » Tue Jun 25, 2019 7:37 am
chrisdermo wrote:There's those 3 cross-modded oscillators too!:
:goo: :nana:
lud
Post by lud » Tue Jun 25, 2019 7:38 am
Great set up, excited about the LPG and PT!
Are there vactrols in the LPG?
BugBrand
Knowledge of Bugs
Post by BugBrand » Tue Jun 25, 2019 7:55 am
Yeah, I might actually swap one of the DDivs over to a Logic.
Yes, basically 3 voices + some extra LXR drums >>>
-- DRM2, Tresses, Filter Pings, LXR
The 3 cross-mod Oscs I'm not sure about - I started with 2 cross patched like in the Chirper. Tend to use this at LFO rates.
I'll have to report back about actual portability! I have a large suitcase to pack this & everything (going in the hold...). Maybe I should look again at the padded cases I got made for 2x16FW cases back in 2012 - those would be great for the 2Frames & weren't too pricey.
LPG - yes with vactrols (even if I did swear off ever using them again!)
T. Jervell
Post by T. Jervell » Tue Jun 25, 2019 8:14 am
Looking good!
LPG and PT!! Ov yeah :banana:
lud
Post by lud » Tue Jun 25, 2019 8:54 am
Hurray for vactrols! Can't wait, will they be available soon?
phisynth
banana nabab
Post by phisynth » Tue Jun 25, 2019 1:23 pm
BugBrand wrote: LPG - yes with vactrols (even if I did swear off ever using them again!)
Oh yeah, I remember that :hihi:
nice setup :yay:
How does it work regarding power ? 2 separate inputs on each top frame ?
BugBrand
Knowledge of Bugs
Post by BugBrand » Tue Jun 25, 2019 1:54 pm
Each 2Frame has a DC and 0V point. So I just need 2 x 3A 12VDC bricks.
I guess I could make a join between the 2 x 2Frames, but that would require a bit more thought - this is just simple!
chrisdermo
Post by chrisdermo » Tue Jun 25, 2019 5:12 pm
BugBrand wrote:Each 2Frame has a DC and 0V point. So I just need 2 x 3A 12VDC bricks.
Considering you can get IEC splitters (1->2) or even just 1x mains plug to 2 x IEC you could still realistically power the whole 4 frames from one plug without having to source a single dc brick with 6+ amps right?
Current Bugs frame:
BugBrand
Knowledge of Bugs
Post by BugBrand » Tue Jun 25, 2019 5:18 pm
Yes, I only need a 2 way - one for a twin IEC to the two power bricks of the 4Frame and another for the LXR. (though debating whether to take the pfactor/bam chain too)
DickMarker
Post by DickMarker » Tue Jun 25, 2019 6:18 pm
Interesting to see those shorting bars (is that what they're called?) fit with your modules - wasn't sure if they did but might pick up a few to try out.
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Jun 26, 2019 4:41 am
Yes, Pomona shorting bars - they're useful in some such instances + I got a few 4" pomonas, again for pre-configured patching (something I've rarely done before but now focusing on standardised voices, just with variable modulations - lots of modulations!!)
lud
Post by lud » Wed Jun 26, 2019 5:02 am
Didn't know about IEC splitters - just rewired my desk and they would have been super handy!
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Jun 26, 2019 5:29 am
Yes, you can get 'extension' ones (male one end splits to two at the other) but that gets quite bulky overall so find the mains plug one end to two IEC the other. Great!
Post by /\/\/\/ » Wed Jun 26, 2019 9:15 am
Would love to hear that system! Looking fairly different from the recently pictured setup.
Briefcase would be awesome! Swap frames in and out and be on the move.
Gute Reise in Deutschland!
DickMarker
Post by DickMarker » Wed Jun 26, 2019 9:33 am
Just noticed you don't have any envelope modules in this setup (couple of built in ones obvs), interesting....
KNYST
hiding in the forest
Post by KNYST » Mon Jul 08, 2019 5:56 am
Nice system, prototypes, end cheeks, ... everything. :guinness:
NOISE HEALS.
patch responsibly.
LISTEN | WATCH
ear ear
Re:
Post by ear ear » Wed Dec 25, 2019 1:43 pm
Have you looked into approaches along these lines: https://nonlinearcircuits.blogspot.com/ ... haser.html ?
He throws the ink first and works out what it is later. "I've got to turn that into parrots." - Ralph Steadman
Return to “BugBrand Devices”
