PEQ
I should certainly say that this is a very early idea with absolutely no promise of anything actually coming out soon or far off. Even a quick design takes nearly a year to reach production and this is just some toe-dipping to see how the electronics work and feel (result, as I said, was disappointment but that gives a lot of work potential).
I also envisage this as a studio-processor (ie. like my red designs) rather than a pure modular design (ie. like blue designs) - filling a particular production need - kind of a master EQ but with less complicated insides than the PEQ ideas I've been mentioning above..
Perhaps the bananas confuse things and I'm not sure I'd really want/need them personally - they are kind of a bi-product of these stereo-eq designs as everything is Voltage controlled internally so that you can gang controls (while note using ridiculous custom multigang pots etc).
I could, though, see this going a different way - a more modular approach - with lots of things 'broken' out. Would fill a full frame in no time...
I doubt I'd do an expander for a red design though.. I see these as different areas in general.
I never really understood all the concepts within the 296 (never really tried). Could sure be interesting with env-follows etc, but that seems to me like a different design brief.
PS - all my banana designs expect a 10V p-to-p signal as standard (but most things are accepted just fine)
- dogoftears
- Puddle of Sealions
- Contact:
for me this unit having jack ins and banana cv's makes plenty of sense. i love the idea of a stereo unit that i can run full program material into and warp the shit out of it with VC per band that i plug into all manner of modular sources. the potential for this in my mind is nearly limitless, especially when i think of it in terms of a twisted "remix" tool.
looking forward to developments on this puppy.
music and mastering: http://xexify.com
Nelson Baboon wrote: What do you mean by 'really is'? You mean, what do I look like? Just look in a fucking National Geographic.
- indexofmetals
- Super Deluxe Wiggler
looks very interesting Tom!
I agree with below as well, hook up one of your joysticks to this and it'd be a great live remix tool.
dogoftears wrote:for me this unit having jack ins and banana cv's makes plenty of sense. i love the idea of a stereo unit that i can run full program material into and warp the shit out of it with VC per band that i plug into all manner of modular sources. the potential for this in my mind is nearly limitless, especially when i think of it in terms of a twisted "remix" tool.
- Learning to Wiggle
I've still got boards for more - but exactly when I'll do up another batch I can't fully say right now. Sometime Jan-Mar 2017 most likely.
Join the mailing list via The Bug Contact Page if you haven't already.
- rowsbywoof
- Ultra Wiggler
- Contact:
- indexofmetals
I highly recommend the "two PEQs in a 6U box". I'm on a mixing mission till early January when I am likely going to have to sell my Chandler Curve Bender but I've been using it with a pair of PEQ's and JLM Pultec type EQ's for a while now and the PEQ's easily integrate with the others.
The only thing I wish the PEQ had was a mix (wet/dry) control so I could fade in more extreme settings (used more with mono signals) but I get around that with another pedal within a loop setup.
- dogoftears
- Contact:
wire it as an fx send on your mixer?indexofmetals wrote:I highly recommend the "two PEQs in a 6U box". I'm on a mixing mission till early January when I am likely going to have to sell my Chandler Curve Bender but I've been using it with a pair of PEQ's and JLM Pultec type EQ's for a while now and the PEQ's easily integrate with the others.
or use 2 dacs/2adcs (not sure how your mixing-- ITB, analog, combo, etc)
it's not typical to use an EQ in parallel so i wouldn't call it an essential feature. that said i do like to use colored EQ's/extreme EQ settings in that very way. i've got a few ways to run parallel over here.
how do you like the curve bender? i have a bunch of EQ's, but my fave right now is the Hendyamps Michelangelo... which I'm mostly using in parallel.
I'm still dragging my heels on it because it is way more complex than 2 PEQs in one box. I pretty much know how to do the circuitry, but the design is massive and needs real focus to progress.rowsbywoof wrote:Hey Tom, I know you hinted at a stereo version of the PEQ in the future, and I know the answer of this is probably, "Too early to know," but figured I'd ask if that's still on the burner, and will that be a new design or essentially just two PEQs in a 6U box? :)
Still slightly wondering whether I do it with full voltage control as standard (in which case it'd likely be a full 11FW unit) or have a VC-expander option (eg. 6FW main unit and 5FW expander).
I also have a pair I use on the master bus- it's an incredible eq. Voltage control is interesting but not for that purpose imho- would make it a different beast: still interesting but not overly suited to the uses I am most aware of people loving this for. With that in mind Id suggest expander for CV.
Yeah, that's along my line of thinking in many ways.tIB wrote:I also have a pair I use on the master bus- it's an incredible eq. Voltage control is interesting but not for that purpose imho- would make it a different beast: still interesting but not overly suited to the uses I am most aware of people loving this for. With that in mind Id suggest expander for CV.
The key is that the stereo approach design is, by its very nature, built around voltage controlled elements (VCFs and VCAs - lots and lots of them). I could just hide or ignore that fact because, yes, I'm not entirely sure of the desire/need for voltage control in a design like this.
- Paranormal Patroler
- indexofmetals
I wasn't very clear, this is for when I'm using the PEQ within an effects chain, usually for a gig. sometimes the Nord 4 can get a bit peaky and I usually tone it down with a PEQ and a tube preamp.dogoftears wrote: wire it as an fx send on your mixer?
For mixing I parallel eq and compression, usually feeding the same stereo mix through two sets of different eq's & comps.
The curvebender is pretty special and it definitely finishes a mix in the best way possible . I have a pair of JLM PEQ500's as well which work well with the PEQ so I probably have enough with the pairs of PEQ's and the JLM Pair.
- neuroportal
Try it simply with a Y insert cable - should be fine.
If not then we can look at the Rane app note - http://www.rane.com/note110.html
- neuroportal
- neuroportal
For reference - I can confirm this works no problems in an A&H Zed mixer.BugBrand wrote:Try it simply with a Y insert cable - should be fine.
