Nord Drum 2
Carci
Post by Carci » Mon Aug 07, 2017 3:24 am
I plugged my Mutable Ears into a Nord drum 2 input yesterday.
The response is amazing. You can hit the thing to trigger the drum, scratching the surface gives nice results too.
:sb:
TURTLE project : http://vimeo.com/23648701
http://www.facebook.com/TURTLEPROJECT
FS : Doepfer MCV24 - Eowave Ringobug - Cwejman PH4 and more eurocrack
https://www.muffwiggler.com/forum/viewt ... 30#3046530
BrokenBo
Post by BrokenBo » Sat Nov 18, 2017 7:37 am
i now have a ND2, too. sounds are very good, but i have the feeling it is rather silent. i have to amplify the signal quite a bit.
trigger sensitivity is at max level. master level also.
splonge
Post by splonge » Mon Nov 20, 2017 11:23 am
BrokenBo wrote:i now have a ND2, too. sounds are very good, but i have the feeling it is rather silent. i have to amplify the signal quite a bit.
Yes, it does have a rather annoyingly soft output.
ipnoteca
cane morto
Post by ipnoteca » Wed Feb 07, 2018 7:54 pm
would be possible to add separate audio output for all the channels?
forgive my noobness but maybe anything i can do with the ethernet cable?
i've blown a fuse...
previously robocoder
YOUTUBE http://www.youtube.com/user/ipnoteca
INSTAGRAM http://www.instagram.com/ipnoteca/
oldgearguy
Post by oldgearguy » Wed Feb 07, 2018 8:10 pm
ipnoteca wrote:would be possible to add separate audio output for all the channels?
Nope - I asked that a long time ago. The way the digital voices are generated and muxed internally means there's no place where 6 voices merge into the main L/R and that means no way to break them out. You'd have to replaced a bunch of circuitry and then rewrite the firmware to do it.
ipnoteca
cane morto
Post by ipnoteca » Wed Feb 07, 2018 8:16 pm
oldgearguy wrote:Nope - I asked that a long time ago. The way the digital voices are generated and muxed internally means there's no place where 6 voices merge into the main L/R and that means no way to break them out. You'd have to replaced a bunch of circuitry and then rewrite the firmware to do it.
thank you for quick reply...guess i will stick to the L/R option then
oldgearguy
Post by oldgearguy » Wed Feb 07, 2018 8:29 pm
My solution for a long time was to buy a second one. :yay:
ipnoteca
cane morto
Post by ipnoteca » Wed Feb 07, 2018 9:01 pm
oldgearguy wrote:My solution for a long time was to buy a second one. :yay:
:hmm: never thought about that option :hihi:
splonge
Post by splonge » Thu Feb 08, 2018 1:58 am
I have been triggering mine from various random gate generators going into the the trigger inputs. Took me way longer than it should have to figure out that you can do that.
sutekina bipu-on
Post by sutekina bipu-on » Fri Feb 23, 2018 6:58 pm
I've been wanting a nord drum 2 with the pad for a long time. Is the 3p capable of making the same kinds of sounds? I've been listening to youtubes but that makes it seem like the 2 is capable of all kinds of synthesis whereas the 3p is mostly samples. Is that true at all?
chvad
Post by chvad » Fri Feb 23, 2018 7:12 pm
pretty sure the 3p has the same synth engine
nostalghia
Post by nostalghia » Fri Feb 23, 2018 8:56 pm
Yep, same. No samples on either as far as I know, both use analog synthesis, physical modeling, FM, etc.
Here's a comparison chart from the Nord website:
Nord Drum 3 comparison chart
And full details on the 3:
Nord Drum 3P
I have the Nord Drum 2 and really like it. No problem with low output levels, going into instrument channels (preamps) on my Focusrite audio interface (Clarett 8Pre), master level on the Nord up about 75%. Triggered from Grids module.
FWIW, I see there are some posts on gearslutz (sorry...) and the Nord user forum that are saying the 3 has noisy internal reverb and headphone output.
No noise issue on line outs or with reverb bypassed. Seems odd if 3 is so similar to the 2, which doesn't have noise issues-any 3 owners that can verify?
“If you look for a meaning, you'll miss everything that happens.” - Andrei Tarkovsky
https://soundcloud.com/nostalghia70s
splonge
Post by splonge » Sun Feb 25, 2018 9:19 am
sutekina bipu-on wrote:I've been wanting a nord drum 2 with the pad for a long time. Is the 3p capable of making the same kinds of sounds? I've been listening to youtubes but that makes it seem like the 2 is capable of all kinds of synthesis whereas the 3p is mostly samples. Is that true at all?
I'm think there might be small differences in the synth engines if you look at the parameters that are available between the two. Noise - Attack and Tone - Timbre is missing on the ND 3. I don't know how much of a difference it makes, but I think they are different.
I do know that you can't share presets between them.
flocked
Post by flocked » Wed Feb 28, 2018 8:37 am
Yes, the Nord Drum 2 has more synthesis parameters than version 3. The removed some parameters to add reverb/delay to nd3.
If you have an external reverb unit I would recommend nd2. Eg. you can't make nice claps with version 3 as its missing the clap decay envelopes.
bhmcc
Post by bhmcc » Wed Feb 28, 2018 8:58 am
I've been considering one for a while but there's a lack of ND2 on the used market. But given the somewhat universal love of the unit they could probably put out a ND2x or something just by adding some more outputs to the ND2 and make a mint.
Howes
Post by Howes » Wed Feb 28, 2018 9:10 am
Really interested to give ND2 a go, shame they switched it up for 3
ipnoteca
cane morto
Post by ipnoteca » Fri Mar 09, 2018 11:09 pm
anyone here usind the nord drum 2 with circadian rhythm and the skipmin?
i need some help...
basically this is the situation,
1. skipmin won't accept all the incoming trigger from the CR, it will skip some trig randomly.
2. changed the trig to gates on the CR, now the skipmin will accept all the incoming trigger from the CR.
3. problem is that now nord drum will double the gates incoming from the skipmin.
did try some different combinations on the nord drum with the trshold and trig type but nothing happened...
as far as i read the nord drum will work properly only with triggers right?
EDIT: find solution for it, was just simply necessary to adjust the gate lenght on the circadian rhythm :bang:
dogoftears
Puddle of Sealions
Post by dogoftears » Sat Mar 10, 2018 1:42 pm
ipnoteca wrote:anyone here usind the nord drum 2 with circadian rhythm and the skipmin?
i need some help...
or trigger an envelope with those gates. voila, instant trig (attack 0 decay 0)
music and mastering: http://xexify.com
Nelson Baboon wrote:I have made America great again.
ipnoteca
cane morto
Post by ipnoteca » Sat Mar 10, 2018 9:07 pm
i need some help...
it's too "complicated" do not have enough envelope to do so and wanted to avoid more cables around the case, but thank you anyway for your suggestion!
:guinness:
soundshaper
Post by soundshaper » Sun Mar 11, 2018 9:31 am
We have both (selling the 3P soon though) and have been using exclusively connected to an electronic drum kit for live drumming. The Nord Drum is extremely expressive and the sounds are incredibly unique. We actually have to use two of the voice channels for the open and closed hi hats, using a momentary foot switch to redirect the trigger signal between the two inputs. Having the reverb available per voice channel is nice on the 3P, but because it lacks trigger inputs we decided the ND2 is better for us. MIDI triggering has a tad amount of latency and is noticeable with live drumming.
soundshaper
Post by soundshaper » Fri Apr 06, 2018 8:15 am
Ok so we discovered recently that after about an hour of use, the ND2 emits a low-level noise from its outputs. It’s a kind of whiney buzz, and goes away when you cycle power. Very annoying. Anyone else with a Nord Drum 2 have this issue? Going to try a different power supply. The one that comes with it is cheapo, looks like a charger for a Nokia phone.
chvad
Post by chvad » Fri Apr 06, 2018 8:45 am
mine never had that issue
acidbob
Post by acidbob » Fri Sep 14, 2018 2:46 am
I struggled to find a ND2 and now it seems I have one on it's way.
I plan to use it with my MD, so question is, is midi on the ND fast enough?
Any tips and tricks for a newcomer to ND?
Is it possible to use parameter locks per step from MD to ND2?
maltemark
Post by maltemark » Fri Sep 14, 2018 3:15 am
MIDI is fast enough.
You can parameter lock midi commands on the MD to control the ND2.
tIB
Stainer!
Post by tIB » Fri Sep 14, 2018 4:17 am
Assuming you have the UW version you might also try internally sampling and mangling gnd-imp machines and sending them out of the alternate outs into the Norddrums trigger inputs...
