KOMA Field Kit FX - CV Controlled Multi Effects Processor
starthief
Post by starthief » Fri May 25, 2018 12:33 pm
The code has been released: https://github.com/KOMA-Elektronik/FieldKitFX
I'm not seeing anything about a phaser. There's no code for it in the frequency shifter nor the UI.
:despair:
If FM overkill is wrong, I don't want to be right. ★ starthief.bandcamp.comstarthief.netModularGrid
bougie
Post by bougie » Fri May 25, 2018 12:56 pm
received mine! loving it so far. looper is pretty fun but i wish there was a way to change the speed/pitch instead of the srr/bitcrusher (or have a variable sampling rate that affects the pitch ;) )
delay is great and really comes alive with the roll-o-decks. can easily dial in perfect octave-fifth shift and the longer time settings are super gritty and noisy, which is quite enjoyable.
should have gotten the eurorack panel, i think this will replace rosie and doepfer a-135 in my rack
chrisdermo
Post by chrisdermo » Tue May 29, 2018 6:39 am
Backer 629 just received mine. Most the nuts for the 1/8" jacks were screwed on so loose I could actually tighten them with my fingers, also I seem to have received a japanese plug power supply which is surprising as a lot of people the UK seem to have been sent proper UK plugs? I do wonder how many amps it requires as I have a ton of negative tip 9v supplies from my pedal days so hopefully won't be such a big deal :despair:
Other than that I must say it looks and feels very nice! Can't wait to try it out tonight.
WTB / WTTF: Bugbrand PRC2B, DD3, PRC4, ENV1
Current Bugs frame:
https://www.modulargrid.net/f/racks/view/580413
mokomo
Post by mokomo » Tue May 29, 2018 2:20 pm
starthief wrote:The code has been released: https://github.com/KOMA-Elektronik/FieldKitFX
:despair:
Yup, the website says "The digitally controlled parts include the looper, the frequency shifter, sample rate reduction, bit crushing effect, phaser, the CV interface and the Roll-O-Decks."
chrisdermo wrote:I seem to have received a japanese plug power supply
Me too, expected a UK plug and got what looks possibly Japanese.
a100user
All the gear, no idea!
Post by a100user » Wed May 30, 2018 7:03 am
FX Field Kit has arrived.
No time to play until the weekend but really looking forward to getting to grips with this.
I'm looking for nothing at this moment in time
chrisdermo
Post by chrisdermo » Thu May 31, 2018 10:13 am
Has there been any word on how much mA the strom mobile power conditioner thingy can provide at 12v?
Current Bugs frame:
MrNovember
Post by MrNovember » Thu May 31, 2018 10:44 am
I was messing around with the FKFX frequency shifter in the feedback path of the Chronoblob last night. Recorded a quick clip processing some sounds from the Mother 32, Plaits, and No Coast:
GovernorSilver
Post by GovernorSilver » Thu May 31, 2018 11:11 am
:despair:
So is this just the source code of the digital FX in the Field Kit FX, or is this firmware for the Field Kit FX?
Member of Alliance for Synth Farting
bougie
Post by bougie » Fri Jun 01, 2018 1:24 pm
anybody else noticed their Fieldkit fx getting hot? Using the provided Power brick, mine gets hot on the bottom side after 20-30 minutes.
euromorcego
Post by euromorcego » Fri Jun 01, 2018 1:29 pm
bougie wrote:anybody else noticed their Fieldkit fx getting hot? Using the provided Power brick, mine gets hot on the bottom side after 20-30 minutes.
only tested one unit briefly (not mine), and indeed it go super hot. KOMA said this is normal.
bougie
Post by bougie » Fri Jun 01, 2018 1:53 pm
thanks for confirming, cheers
12eightyfive
Post by 12eightyfive » Fri Jun 01, 2018 3:13 pm
Has anyone successfully intergrated this into a larger rack? I was really excited to get the field kit but it took up too much power, had to sell it because I couldn't rack it.
Post by /\/\/\/\/\/ » Sat Jun 02, 2018 2:22 pm
euromorcego wrote: indeed it go super hot. KOMA said this is normal.
:confused: mmm... was thinking about picking one of these up somewhere down the line to partner my original... I don't like the sound of that heat in a device encased in a small wooden box with no (?) ventilation, though. I try to be careful about fire hazards, super hot would freak me out a little bit too much I think :deadbanana:
MrNovember
Post by MrNovember » Sat Jun 02, 2018 4:39 pm
I would be incredibly surprised it could get anywhere close to hot enough to ignite the case. And it only gets hot when you're using it so, you'd at least be sitting there to notice. I've never noticed mine getting hot.
mokomo
Post by mokomo » Sun Jun 03, 2018 1:27 pm
Being a wooden box, a few vent holes should be easy to add if needed.
It’ll be interesting to take a closer look inside for useful patchpoints - or for insert effects before, after or instead of certain components.
Paranormal Patroler
Post by Paranormal Patroler » Mon Jun 04, 2018 5:51 pm
Ordered! 8-) I couldn't help it.
arbee
Post by arbee » Tue Jun 05, 2018 10:25 am
backer #452 finally delivered. it is waiting for me at home. got the eurorack version and really hope it'll play well with the rest of my rack.
mateo
Post by mateo » Tue Jun 05, 2018 11:22 am
Paranormal Patroler wrote:Ordered! 8-) I couldn't help it.
Did you order direct from them? Or from a store?
Paranormal Patroler
Post by Paranormal Patroler » Tue Jun 05, 2018 4:12 pm
I got it directly from Koma, it's available through their website. Mine is on the way.
Al
Post by Al » Thu Jun 07, 2018 7:36 am
The dual mono output is a nice touch because it doubles as a headphone jack.
I don't know squat about coding but it could be fun to change the freq shifter to a phaser or VCA. The bit crusher could be useful as a pitch shifter. I'm not sure if this is possible.
starthief
Post by starthief » Thu Jun 07, 2018 8:31 am
I wrote to Koma and asked about the hidden phaser mode -- it didn't make it into the final version.
GovernorSilver
Post by GovernorSilver » Thu Jun 07, 2018 2:26 pm
But the phaser is in the hardware right? Or was it excluded from that too?
starthief
Post by starthief » Thu Jun 07, 2018 2:49 pm
The phaser was going to be a secret mode of the frequency shifter.
ArboriaAuralist
Post by ArboriaAuralist » Fri Jun 08, 2018 11:04 am
Koma's nerd detector seems to be working! :miley:
I'm no spaceship, I'm a free number! :zombie:
GovernorSilver
Post by GovernorSilver » Fri Jun 08, 2018 12:06 pm
starthief wrote:The phaser was going to be a secret mode of the frequency shifter.
But you guys are talking about the software in GIT, not the firmware that's actually in the hardware right?
