Gotharman's Little deFormer 3
gotharman
Post by gotharman » Thu Nov 21, 2019 2:01 pm
Modulus
Post by Modulus » Thu Nov 21, 2019 3:11 pm
Love the new case Flemming! And what’s this a percussion osc type? :party:
gotharman
Post by gotharman » Fri Nov 22, 2019 5:24 am
Modulus wrote:Love the new case Flemming! And what’s this a percussion osc type? :party:
Thank you very much!
Yeah, soon LD3 will play percussion :-)
gotharman
Post by gotharman » Fri Nov 22, 2019 9:27 am
Yesterday I was really hungry for some new drum sounds, and I was just about to go out and get myself a Roland TD-20 module. But then I got a much better idea :) And I didn't even leave my lab:)
dekalboy
Post by dekalboy » Fri Nov 22, 2019 11:28 am
Is it the same PERC engine than the one we can find inside FUZION ?
gotharman
Post by gotharman » Fri Nov 22, 2019 11:36 am
dekalboy wrote:Is it the same PERC engine than the one we can find inside FUZION ?
No, it's a new one...
zite909
Post by zite909 » Fri Nov 22, 2019 12:51 pm
Wow ! I tested the new bass enhancer and I really enjoyed it. It sounds really nice ! And now I discover that there is an upcoming perc oscillator !! :)
There are so many things happenning with the LD3 :)
el-kartoff
Post by el-kartoff » Fri Nov 22, 2019 2:16 pm
Thank you Flemming,
this is so cool!
:bananaguitar: :yay: :bananaguitar:
gotharman
Post by gotharman » Sat Nov 23, 2019 3:51 am
zite909 wrote:Wow ! I tested the new bass enhancer and I really enjoyed it. It sounds really nice ! And now I discover that there is an upcoming perc oscillator !! :)
Great to hear, that you are enjoying the bass enhancer. I hope that you will soon enjoy the percussion oscillator too :)
And thanks again for your really nice LD3 review!
gotharman
Post by gotharman » Sat Nov 23, 2019 3:53 am
el-kartoff wrote:Thank you Flemming,
this is so cool!
Thanks so much for appreciating it!
It is indeed cool, if I should say so myself :)
bda65
Post by bda65 » Sun Nov 24, 2019 6:44 am
I've made an arduino based midi controller for my LD3. With part from e-licktronic (midilickuino, dilicktal and licklogic). And a 16x2 display.
The arduino code is now finished. The face plate (with my 3D printer) too.
I'll add 16 pots soon, the code is ready.
The buttons permit to change the CC for each row of pots. 5 pots used actually which represent 16x5 CC.
2 others buttons and 16 pots each are attributed to a Raspberry Pi 4b. With bipscript, nekobi with a distortion. I'll add another synth plugin soon. Stereo audio output (from a USB Asus Xonar U3) go to the LD3 as 2 mono input. LD3 used as mixer and effects processor.
It's a work in progress. I want to make a small flight case for this small setup. I need to transport it by walking or cycling.
3 connectors for power and main audio output on the side wired internally. No need to connect disconnect anything inside. Plug and Play ;)
Nothing screwed for now ;)
rayce
Post by rayce » Sun Nov 24, 2019 11:49 am
Very impressive diy effort. Look forward to seeing a video of it in action!
Tremendous amount of hands on modulation potential there.
gotharman
Post by gotharman » Sun Nov 24, 2019 11:57 am
Looks really cool bda65! I am also really looking forward to see it in action :)
bda65
Post by bda65 » Sun Nov 24, 2019 3:05 pm
I'll make a video soon. Stay tuned ;)
rayce
Post by rayce » Sun Nov 24, 2019 10:43 pm
I've been having fun using the sample XFADE mode on LD3.
Just a short video of (Tiny) LD3 creating a pad sound using two samples of my voice doing an oooh ahhh sound and crossfading between the two looping samples. Passes through a VCF8 Spaze and granulating delay. Iphone LOFI audio.
Really like the Tiny LD3 as a portable all in one on the road toss it in a backpack studio solution. So small and easy to use with a battery pack that puts out 9v dc. I wasn't sure how the reduced buttons and knobs would translate but I'm happy to say its easy and fast to navigate.
gotharman
Post by gotharman » Mon Nov 25, 2019 8:09 am
rayce wrote:I've been having fun using the sample XFADE mode on LD3.
Thank you very much for sharing this cool video. It sounds great!
bda65
Post by bda65 » Mon Nov 25, 2019 9:08 am
@rayce: can i ask which is the keyboard/synth?
rayce
Post by rayce » Mon Nov 25, 2019 9:28 am
Its a a shrolca. Fun compact little synth with a nice analog filter. The poly touch keyboard is a perfect lightweight companion for tiny LD3. Just using it for its midi keyboard in the video.
viewtopic.php?t=202177&highlight=
gotharman
Post by gotharman » Mon Nov 25, 2019 11:04 am
Some beats
Scories
Post by Scories » Mon Nov 25, 2019 7:16 pm
@Rayce : Compelling mood. My favourite Tiny/LD3 video so far.
About filming: Just one piece of friendly [technical] advice :
About portability: Have you ever considered paring it with an Eventide MixingLink for more audio option such as an headphone output.
rayce
Post by rayce » Mon Nov 25, 2019 8:24 pm
Thanks Scories!
The Left output of the LD3 can be used as a headphone jack which is what I have been using though I can see advantages to having the mixinglink. A battery powered mic pre/fx loop/minimixer in pedal form factor is pretty cool. Appreciate the suggestion.
I'll never be able to look at vertical vids the same way after watching that PSA ;)
gotharman
Post by gotharman » Wed Nov 27, 2019 10:16 am
Some more percussion presets, to be available soon…
gotharman
Post by gotharman » Mon Dec 02, 2019 7:51 am
A new update are now available for LD3 and Tiny LD:
-Percussion Synthesizer trial version included (fully functional, but save disabled). 4 new percussion oscillator types will let you use LD3/Tiny LD as an advanced drum machine.
-Long envelope times are now possible.
You can download the update at:
www.gotharman.dk
-To support and encourage for further LD3/Tiny LD updates, please unlock the percussion synthesizer. You can unlock it here:
http://www.gotharman.dk/LD_optional.htm
-You can download 10 presets, to get you started with the percussion synthesizer here:
http://www.gotharman.dk/LD3_presets.htm
zite909
Post by zite909 » Tue Dec 03, 2019 8:53 am
I just watched the videos that have been posted on this page. There are so nice !
The sample Xfade function works really well for pad and atmosphere.
Im really intrigued by the new Percussion oscillator. I have not tried it myself yet, but it sounds really rich on the video. The combination of the percussion oscillator + sample + compression/distortion/granular FX is really unique.
gotharman
Post by gotharman » Tue Dec 03, 2019 10:07 am
zite909 wrote:I just watched the videos that have been posted on this page. There are so nice !
Thank you very much friend!
I hope that you will enjoy playing with the new things :bananaguitar:
