gotharman wrote: ↑Sat May 16, 2020 7:18 am
It might even be possible to do some other fun stuff
Ha, I was going to ask if something like this would be possible. :)
On a related note, could an option be added to route external inputs to a pair of busses, like you can do with Parts? I've been achieving the same thing by splitting an external signal to two inputs and it would be nice to be able to to it in the LD3 itself.
Two reasons you might want to do this:
1. Feedback experiments. Route a signal from an external effect to two busses and send one of them back into the effect.
2. Use Bus Levels as aux sends to hardware effects. Send a signal from a Part (or two external inputs) to two busses and route one of them to an output/effect. This is quite flexible as you can end up with everything from a 100% effected signal to no effect and all ratios in between.
I'm sure there are many other things you could do too, especially if you can send busses to other busses!
