Pulsar-23 by Soma
nodog
Re: Pulsar-23 by Soma
Post by nodog » Thu Mar 05, 2020 4:12 pm
Bobby wrote:
Thu Mar 05, 2020 2:48 pm
Fingers crossed for you dude. Hopefully a loose connection.
...course that's a prototype so potentially nothing wrong too.
Cheers man. I've just send a mail to SOMA. I'll report back on how it goes.
gosh
Post by gosh » Thu Mar 05, 2020 5:22 pm
First thoughts after an hour or so. Wow, mental machine, love it very cool.
Re. The SD/Clap thing I’m pretty sure mine is the same so guessing that’s design. If you use the sensor to trigger you can get the SD and the clap with the attack spreading wider so that at extreme settings you don’t hear the clap for a few seconds. The trigger in (I’ve not tried midi) seems to just trigger the SD. I think.
That said, I can’t think of many situations where I’d want the delayed clap thing; it makes it sound a bit weird but horses for courses I guess. There is certainly a bucket load of sound variability in the SD/CP channel even with the trigger vs sensor difference. Will be keen to hear back.
My BD seems consistent though. Again, I think. Need to explore more.
Can’t explain the wild sounds you can get though. Very fun
nodog
Post by nodog » Thu Mar 05, 2020 5:37 pm
Thanks for that gosh. I really don't care for a consistent bd in this machine but with the snare/clap thing on top of that I started wondering if there's maybe a bit more wrong with mine. Good to hear that's apparently by design.
I'm not exactly sure how to embed soundcloud stuff here but I've uploaded two bits from sessions I've done.
https://soundcloud.com/spatialfoundatio ... rd-80s-bit
https://soundcloud.com/spatialfoundatio ... trojam-bit
lionel
Post by lionel » Thu Mar 05, 2020 6:42 pm
Is the weird-80-bit pulsar Only ?
That sounds really good !
nodog
Post by nodog » Thu Mar 05, 2020 7:01 pm
Cheers but neither of these are Pulsar only. I guess "mainly Pulsar" would be a good description. There's a Peak involved in weird80s. TT303 and SEM in the electrojam bit plus DRMIII for extra drums in both.
Bobby
Post by Bobby » Fri Mar 06, 2020 3:04 am
Electro jam bit is ace. Nice work.
Bobby
Post by Bobby » Fri Mar 06, 2020 3:05 am
Abstractly I'm sad about this clap thing though.
Bobby
Post by Bobby » Fri Mar 06, 2020 3:38 am
Again thinking purely in the abstract as i don't have a pulsar yet: Could it be that the clap knob actually interacts with the sequencer, like introducing a flam and therefore you could do a similar thing with an external sequencer?
nodog
Post by nodog » Fri Mar 06, 2020 6:05 am
That sounds logical but it flams also with just touching the pad on the channel.
Got a reply back from SOMA very early this morning (maybe a bit too early for them ;-). The BD thing with changing attack is normal. The Clap issue I think the guy misunderstood me, apparently thinking that the complete channel didn't trigger. I've replied with a further explanation and haven't heard back yet.
Now it seems a bit like I'm concentrating on these "issues" but really, it's about 0,0001% less fun to use now then with the clap pot working as I'd expect it.
This thing rocks so hard. I'm sure you'll be totally satisfied when it arrives Bobby. Hope you'll get it soon!
chvad
Post by chvad » Sat Mar 07, 2020 1:42 am
nodog wrote:
Wed Mar 04, 2020 3:18 pm
At the moment I'm mostly salivating while trying different connections/modulation possibilities on quite a bland drumpattern. Not much to share yet I'm afraid.
I'm sequencing it with a external sequencer because firstly, I've a shitty feel for rythm and secondly, I'm not ready yet to dive in the manual recording mode.
Two things that were a bit unexpected and I don't know if it should work like this:
- With attack at 0 the BD won't have a consistent attack, let's say 12,13 out of 16 BD's have the very fast attack and then a couple haven't.
- The Clap pot on the SD channel doesn't work when triggered by midi (it does work when triggering manually).
I must say these aren't biggies. For instance; I'll be modulating the shit out of the sounds so don't need a consistent BD.
The Pulsar seems like the ideal companion for the Vermona DRM (which does have amazing sounds but doesn't do modulation). These two (plus my Eurorack percussion setup) will keep me going for the rest of my life I think.
So I just tested out the clap and here is my discovery:
It DOES work via midi but the velocity of the midi note HAS to be 113 or higher. LOWER than that only triggers the snare.
It's actually pretty cool with you think about it. When working with MIDI you can basically program in the clap effect independently of the snare.
Velocity in general is VERY expressive on this and I recommend playing with it to get some feel for it. I hadn't noticed this snare/clap behavior before but I gotta say.. I love it!
nodog
Post by nodog » Sat Mar 07, 2020 2:39 am
Wow, excellent news chvad!
I did notice the very distinct effect of velocity and also note length but not this yet. Cheers!
NoLegs
Post by NoLegs » Sat Mar 07, 2020 2:50 am
Quick little Friday night jam.
Through a 100GRIT and Fusion Delay. Taking the trigger out from the kick to trigger an envelope that opens the filter and VCA on the 100GRIT.
Bobby
Post by Bobby » Sat Mar 07, 2020 3:56 am
Nice one matey. Tip!
blipson
FF velocity = sustain?
Post by blipson » Sat Mar 07, 2020 8:25 am
Does anyone get a sustained note when a module receives MIDI velocity FF=127? I thought I once read this somewhere, but now I can't find it. My BASS module reacts like that, at least in PRC mode, and I hope that's not a glitch. What I'd really like to do is disable that behavior if possible.
NoLegs
Post by NoLegs » Sun Mar 08, 2020 5:00 pm
Some multi band processing of the Pulsar-23 using the Noise Engineering Seca Ruina.
Ruiner
Post by Ruiner » Mon Mar 09, 2020 2:33 pm
any idea what number they're on guys? Thanks!
Bobby
Post by Bobby » Mon Mar 09, 2020 4:09 pm
Europe or elsewhere?
Ruiner
Post by Ruiner » Mon Mar 09, 2020 4:35 pm
United States
Bobby
Post by Bobby » Mon Mar 09, 2020 5:24 pm
United States
Can't help on that one sorry. Higher than us in Europe tho!
behndy
Post by behndy » Mon Mar 09, 2020 5:43 pm
hey there gurrrrL! i was number 389, mines shipped about 4 weeks ago?
music, noise, in progress silliness - http://www.youtube.com/c/behndy
Ruiner
Post by Ruiner » Mon Mar 09, 2020 6:25 pm
Great, thanks Behndy. I'm 527 so probably still got a while......
behndy
Post by behndy » Mon Mar 09, 2020 7:52 pm
the struggle. is REAL.
Bobby
Post by Bobby » Tue Mar 10, 2020 2:13 am
I'm 90 something in Europe and nothing yet. Europe is dry af.
Richard deHove
Post by Richard deHove » Tue Mar 10, 2020 2:15 am
Waiting on parts from China perhaps ?
m:o
Post by m:o » Tue Mar 10, 2020 3:39 pm
man, this is around the corner...i`m EU #1501 (ordered June 2019) :eek:
