Gotharman's Tiny LD
Cat-A-Tonic
Lobsters love Muff
Post by Cat-A-Tonic » Thu Apr 18, 2019 5:25 am
Is this gonna get some Tiny PolySpaze(6) alternative OS action?
Maybe that doesn't make sense
unless it has the filter-board expansion.
gotharman
Post by gotharman » Thu Apr 18, 2019 8:08 am
Cat-A-Tonic wrote:Is this gonna get some Tiny PolySpaze(6) alternative OS action?
You are right. That wouldn't make sense, and I have not planned to make this. It only has room for a single filterboard.
gotharman
Post by gotharman » Fri Apr 19, 2019 7:53 am
The Comparison Cart at www.gotharman.dk , has now been updated, to include Tiny LD.
gotharman
Post by gotharman » Fri Apr 19, 2019 11:25 am
To give you an idea on, how this tiny thing is operated:
gotharman
Post by gotharman » Thu Apr 25, 2019 4:46 am
Tiny LD structure:
gotharman
Post by gotharman » Fri Apr 26, 2019 4:46 am
Tiny LD user manual are now available here:
http://www.gotharman.dk/tiny_ld_manual.htm
gotharman
Post by gotharman » Fri Apr 26, 2019 12:15 pm
gotharman
Post by gotharman » Tue May 14, 2019 10:13 am
New update are now available for Tiny LD :)
Main features:
-Many parameters can now be hard-assigned to MIDI CC’s. These parameters can also be controlled directly from the sequencer controller tracks, and movements of these can be recorded on the controller tracks.
-Follower gain x2 and x4 added to the Audio BUS Envelope Followers.
-The sequencer controller tracks are now selected separately from the parts.
You can find the update here:
http://www.gotharman.dk/LD3_updates.htm
gotharman
Post by gotharman » Fri May 24, 2019 6:03 am
One week left to save 10% on Tiny LD, by pre-ordering it!
gotharman
Post by gotharman » Tue May 28, 2019 5:59 am
New update are now available for Tiny LD:
-It is now possible to select, if parameter CC control, from both MIDI in and the sequencer controller tracks, should affect only the selected Morph layer, or both Morph layers at the same time.
-Size parameter has been added to the PitchShifter effect.
-A * is now shown in the preset name, if the preset parameters has been tweaked, and the preset has not yet been saved.
-A compare preset function has been added.
You can download it here:
gotharman
Post by gotharman » Mon Jun 17, 2019 3:15 am
gotharman
Post by gotharman » Wed Sep 04, 2019 10:42 am
A new Tiny LD update are now available:
-It is now possible to copy/paste a selected number of steps from any location, to any location of a sequencer track.
-Importing of Cue Points (Markers) as Chop Points has been optimized, to cover cue points generated on a wider range of programs.
-The Sequencer Step Advance parameter is now switched on as default.
-An “Esc” touch button has been added to the Auto Sample Rec “Waiting For Trigger…” page.
Bug fixes:
-Sometimes, when doing a chopped audio track recording, clicks would appear on the first 5-6 steps of the recording. This has now been fixed.
-In some cases, at some specific sample lengths, adjusting the start point of the last sampling in a sample bank, would cause LD3/Tiny LD to freeze. This has now been fixed.
Scories
Post by Scories » Mon Sep 23, 2019 4:20 pm
Is there some kind of a tutorial out there?
Since I got back from vacation, I've been too busy (or lazy) to get my head around it.
I'd love to do some live remixing of previous tracks by importing loops and samples as different elements of a track with a global tempo. Then I'd like to filter some elements, add effects and be able to change the pitch of some elements (for intuitive tonal changes from an external controller) without changing the tempo.
I'll definitely have to spend a few hours with the manual.Must take hours to properly learn!!
Btw, I hope these new oscillators/features will also be implemented in a future update. :tu:
gotharman
Post by gotharman » Tue Sep 24, 2019 7:13 am
Scories wrote:Is there some kind of a tutorial out there?
You could watch the video's :)
Sure, now that I have made a manual for it anyway, you can right as well read it :-)
gotharman
Post by gotharman » Tue Sep 24, 2019 7:14 am
-New oscillator types: Smooth oscillators and Resonator oscillators.
-The 2 new oscillator types can be microtuned per key in an octave.
-More oscillator modulation destinations: Extra pitch modulation, Reso, Sample length and Portamento.
-Monophonic trigger system improved.
-Output Effects gain can now be adjusted.
Bug fixes:
-If linear envelopes were used, with different settings for each part, sometimes the settings of each part would interfere with each other, i.e. long attacks would appear on parts, that it was not supposed to. This has now been fixed.
gotharman
Post by gotharman » Mon Sep 30, 2019 10:42 am
gotharman
Post by gotharman » Fri Oct 04, 2019 6:03 am
A handful of presets, to get you started with the new oscillator types, are now available here:
http://www.gotharman.dk/tiny_ld_presets.htm
gotharman
Post by gotharman » Tue Oct 08, 2019 3:50 am
A new update are now available for Tiny LD:
-Resonator Type 2 added to Resonator Insert Effects.
-Output Effects 1 and 2 gain has been moved from the Zone page to the output effects Mod2 page.
Improved user interface:
-When pushing and holding the Func/mute button, the 4 Edit Knobs will now function as Volume, Morph, Seq Morph and Cut from any page.
-Parameter row for editing can now be selected, just by touching the parameter row.
-A green dot in the left side of the screen, now indicates which parameter row is selected for editing.
-On the Sequencer step pages, it is now possible to select 4 groups of step values, instead of 2 (4 steps at a time, to fit Tiny LD’s 4 Edit Knobs).
gotharman
Post by gotharman » Sun Nov 17, 2019 5:11 am
TINY LD UPDATE AND SPECIAL OFFER!
Order a Tiny LD on 17/11 or 18/11, and get the new Bass Enhancer included!
New update:
-Bass Enhancer insert effect can now optionally be added.
Bug Fixes:
-The CV Scaling and Octave parameters mysteriously disappeared from the Controller Track pages. Has now been fixed.
-Tiny LD only: It was not possible to set the Bus outputs to “Off”. Has now been fixed.
Find the update and offer at:
www.gotharman.dk
gotharman
Post by gotharman » Tue Dec 17, 2019 6:49 am
-Swing All function has been added.
-Extra Trigger Random function added, that will make it randomly toggle between the part and the extra part, instead of just playing both back at the same time.
-USB sample import: It is now possible to select, if it should use the sample “LD” name or the file name, when importing samples.
Get it at:
www.gotharman.dk
gotharman
Re: Gotharman's Tiny LD
Post by gotharman » Wed Feb 26, 2020 3:04 am
Tiny LD are now available in MkII casing style:
gotharman
Post by gotharman » Thu Feb 27, 2020 8:07 am
[/bbvideo]
gotharman
Post by gotharman » Fri Mar 06, 2020 6:45 am
Tiny LD has been reviewed by Amazona.de:
https://www.amazona.de/test-gotharmans- ... groovebox/
gotharman
Post by gotharman » Fri Mar 06, 2020 12:30 pm
-2 new Percussion Oscillators has been added: Clap Oscillator and Cymbal 2.
-Edit Knob’s MIDI CC output can now be switched off.
-Triggers from Part 13 to 16 has been added to the modulation sources, instead of MIDI CC 58 to 61.
Bug fixes:
-When syncing LD3/Tiny LD to a MIDI sequencer, and recording the MIDI notes, the sequence would, in most cases, be time shifted one step ahead. This has now been corrected.
Find it at:
www.gotharman.dk
gotharman
Post by gotharman » Sat Mar 07, 2020 7:33 am
Inputting notes on the Tiny LD Sequencer:
