Arturia Keystep pro
Estes
Re: Arturia Keystep pro
Post by Estes » Wed Jan 15, 2020 4:59 pm
No Micro USB! :goo:
kay_k
Post by kay_k » Thu Jan 16, 2020 4:02 am
No Micro USB! :goo:
yeah that f***n USB port on the BSP is so fragile I had to repair mine twice, not sure if the pads will suffer thru a third time!
I also wonder if that thing still has the USB noise problem the BSP had.
zoneswithoutpeople
Post by zoneswithoutpeople » Thu Jan 16, 2020 5:31 pm
Looks really cool... tons of outputs, wow. Just wish it had full size keys and maybe another octave, then it would be perfect. I find it much harder to play on mini keys.
gloamtrotter
Post by gloamtrotter » Fri Jan 17, 2020 1:02 am
Was considering getting an endorphin.es ground control when it finally comes out but now I’m thinking this might be a better way to go. $300 cheaper too
StillNotWorking
Re: Keystep pro coming
Post by StillNotWorking » Fri Jan 17, 2020 8:47 am
TheRosskonian wrote:
Wed Jan 15, 2020 11:19 am
StillNotWorking wrote:
Wed Jan 15, 2020 6:53 am
My crystal ball foresees there are a commercial 9U rack forthcoming where this device can be mounted on a hing plate function as partial front cover for easy transportation and setup. Maybe another one that are 6U + 1 U and deep enough to host a mutitimbral rack synth :75:
Looking at the pictures on the website, I didn't spot any mounting points on the sides like the rackbrute/minibrute system has. Such a shame as I think the Link System is a really cool concept that they seemed to have abandoned. Arturia did say it is open source though, so maybe someday someone else will adapt to it.
Yes 3. party. Probably steel bottom plate on this one too, — that stick to magnets.
BTW a tip to those tired of defective connectors are to tape a cardboard or metall plate to the bottom, — sticking out 30-50mm behind the back. Then tape cable (not connector body) to the plate, or drill holes and use strips. Then any movement will be taken up by the flexible cable rather than the flimsy connector.
looking for service manual for the Clavia ddrum AT or ddrum III
ckwjr
Post by ckwjr » Sat Jan 18, 2020 12:17 pm
A Beatstep Pro +2(Keystep) makes so much sense - just wish it had happened before I bought a Beatstep Pro and a Keystep. Whatcha gonna do.
thetechnobear
Post by thetechnobear » Wed Jan 22, 2020 11:58 am
hmm, i need a portable keyboard ....
I guess this can be used as a midi to cv converter (midi in -> cv outs) like the beatstep.
does anyone know what the latency of the beat step was like for midiin-> cv.
(I'd read about sloppy sequencer timing, but that's not **that** important to me, really I just need a cv keyboard and midi to cv converter)
ReverseShuffle
Post by ReverseShuffle » Sat Jan 25, 2020 12:10 pm
I placed an order for an Arturia KeyStep Pro. My main studio setup is controlled by a Pioneer DJ Toraiz SQUID. However, the KeyStep Pro will be used for a smaller studio setup with idle synths, drum machines,outboard and other gear I have available.
hawkfuzz
Post by hawkfuzz » Mon Jan 27, 2020 10:30 pm
Does anyone know if it can record parameter locks?
THUMPR BC SC
flashheart
Post by flashheart » Tue Jan 28, 2020 1:06 pm
As s controller parameter locks don't mean anything as there are no 'parameters'. I see there's 4 poly sequencers, don't know how will work as CV yet, the only other parameter it it's the same as the BSP is velocity. AFAIK there's no recording of paramters from an external device (if that's what you mean).
I'm not buying a maths though, not my idea of fun...
hawkfuzz
Post by hawkfuzz » Tue Jan 28, 2020 9:10 pm
As it has 8 outputs of CV, a 'parameter' is anything you want to send CV, and since you have several knobs and a few sliders maybe you can record the modwheel motion within a sequence...?
I know it's a controller. Maybe I should've said 'motion sequence' or automation lane, but I thought they were synonymous.
THUMPR BC SC
Man-In-A-Suitcase
Post by Man-In-A-Suitcase » Wed Jan 29, 2020 3:30 am
Last edited by Man-In-A-Suitcase on Wed Feb 26, 2020 5:48 pm, edited 1 time in total.
040B
Post by 040B » Sat Feb 08, 2020 4:47 pm
So what’s the real benefit (IF any) of this Keystep pro over a BSP + keystep combi?
I am just getting in to this modular thing, and was going to buy a beatstep next. Wondering if I should just go for this one instead. :hmm:
StillNotWorking
Post by StillNotWorking » Sat Feb 08, 2020 5:09 pm
Polyphony, more program memory might give even more options to come
CalvaryBand
Post by CalvaryBand » Sat Feb 08, 2020 8:23 pm
Scenes and pattern chaining are a big improvement over what is included in the base model Keystep. That and you have 4 pattern layers vs just one on the Keystep. The Pro could be the center of your rig while the original Keystep works best as an attachment to one synth/modular setup.
Jordan Passmore -
ONInstagram / Live synth sessions.
joeSeggiola
Post by joeSeggiola » Tue Feb 18, 2020 11:18 am
Do anyone know what mono/polyphonic allocation strategy will be used for the four CV/gate outputs? And if keyboard split options will be available?
Zijnzijn Zijnzijn!
Post by Zijnzijn Zijnzijn! » Tue Mar 03, 2020 12:22 pm
Just got an update from where I pre-ordered this; Arturia is delaying the launch until April sometime due to coronavirus. Not sure if this is for all retailers or just the one I happened to buy from (Kraft Music)
Licudi
Post by Licudi » Tue Mar 03, 2020 12:52 pm
Just after I sold my Vermona qMI 2 as well. :bang:
The SB1/SuperBee is delayed too - coronvirus is going to disrupt many new product schedules. Speaking of which, I wonder how things are going in the workcamps at Music Tribe City?
mrhooks
Post by mrhooks » Tue Mar 03, 2020 1:40 pm
EDIT: Nothing to see here...
If you have an original MI Rings panel you're willing to part with, please PM me.
joeSeggiola
Post by joeSeggiola » Tue Mar 03, 2020 2:17 pm
The manual is already online.
But that's the manual for the BeatStep Pro only, isn't it?
ronnieb
Post by ronnieb » Tue Mar 03, 2020 2:19 pm
As expected, it's similar to the KeyStep: CV/gate outputs are for separate monophonic sequences only. The manual doesn't talk about the keyboard at all, so I'm assuming no split.
:foul: That's the beatstep pro manual...
:omg:
mrhooks
Post by mrhooks » Tue Mar 03, 2020 3:22 pm
Whoops, lol, I searched for the KSP and it came up. That's what I get for not having my glasses on. Anyway, I wouldn't be surprised if it's monophonic.
black_label
Post by black_label » Tue Mar 10, 2020 2:21 am
I got updates from a couple of retailers. KSP is shipping Mid April/early May.
040B
Post by 040B » Sun Mar 22, 2020 3:38 am
I looked at a retailer here in the Netherlands. The site says it will ship in 8 days.
