The Elektron Model:Cycles Thread
AdamJay
Re: The Elektron Model:Cycles Thread
Post by AdamJay » Wed Apr 22, 2020 8:38 am
So, using the patches I made for these tracks, plus around 90 other patches, I’ve made a 100 sound patch pack, available at www.replicantsounds.com
You can hear all 100 sound here too:
orangehexagon
Post by orangehexagon » Fri Apr 24, 2020 5:41 pm
Does anyone have the Cycles and not feeling it? I'm suuuuper keen on getting my hands on one. I have things to trade including money ;-)
SphericalSound
Post by SphericalSound » Tue Apr 28, 2020 5:33 pm
90% sold. Just a few questions:
Do it has midi out?
Accepts midi in?
Can you use the sequencer to sequence other midi machines?
bougie
Post by bougie » Tue Apr 28, 2020 6:05 pm
Do it has midi out?
Accepts midi in?
Yes you can sequence external midi gear but there is one issue i wish i'd knew about before purchasing. There is no way to directly play external midi gear from a midi controller connected to midi in.
It will however send the notes played with its 16 buttons in real time.
SphericalSound
Post by SphericalSound » Thu Apr 30, 2020 6:19 am
Do it has midi out?
Accepts midi in?
Nice to know. Still sold. Thanks!!
hawkfuzz
Post by hawkfuzz » Sat May 02, 2020 6:48 pm
So it won't engage the transport controls?
THUMPR BC SC
jdaddyaz
Post by jdaddyaz » Sun May 03, 2020 12:12 am
This thing is great. I love the sounds of the drum hits, percussions, hats, and chords. Still trying to make something other then zap guns with the tone machine but other than that am really enjoying it.
Be good to yourself, and be good to others.
orangehexagon
Post by orangehexagon » Thu May 21, 2020 4:09 pm
I just received mine, and I have to say, I'm a bit disappointed. Does anyone else find the output volume to be pretty low? Maybe I've just lost a lot of my hearing...
I had really high expectations for this -- and I might just need to give it some time -- but I'm considering putting it up on the BST
inoshi
Post by inoshi » Thu May 21, 2020 6:18 pm
Dibs
SnipeCatcher
Post by SnipeCatcher » Fri May 22, 2020 3:35 am
I was seriously underwhelmed the first few hours of receiving mine. But I kept thinking of all those great demos I’d heard. Now I think it’s just shockingly good on a lot of levels.
If you’re referring to the headphone output ...this is my 4th Elektron machine and the headphone output kinda sucks on all of em
bedhed3000
Post by bedhed3000 » Fri May 22, 2020 12:05 pm
Not being sarcastic at all, but did you try turning the volume up? I am typically cranking the master volume to like 95%, and adjusting the individual track volumes as needed. The "punch" parameter helps too if you need a particular track to cut through the mix (although it adds a bit of saturation to the sound). There's also the "Volume + Distortion" parameter to adjust. I'm also running it through some form of compression at the end of the chain - either the built-in compression from my interface, or a desktop compressor.
Question for thread: Is there a way to keep the master tempo constant when switching patterns while playing? I looked for this in the manual but couldn't find anything. Let's say I create a pattern at 120 BPM, and another at 125 BPM, and another at 127 BPM. If I start playing the first pattern (120), then switch to the second or third pattern, I'd like the tempo to stay the same as the pattern that I started playing. This is how the OG Electribe boxes worked (I believe the tempo was reset to whatever the pattern was saved at when you stop playing).
Kingnimrod
Post by Kingnimrod » Sat May 23, 2020 8:42 am
go to the audio config menu and set the HP max output higher. The default output of 60% is pretty low.
orangehexagon
Post by orangehexagon » Sat May 23, 2020 10:01 pm
Thanks... I should have maybe figured that out on my own. That definitely helps. I've been running it through my Analog Heat now as well and so far enjoying it much more now.
soon_come
Post by soon_come » Wed May 27, 2020 4:11 pm
Seriously? How strange. I figured that any incoming MIDI notes (whether on specific track channel or auto channel) would just be forwarded to the MIDI channel each track is set to for output. It'll allow you to record the sequence from the keyboard but not play the channel's MIDI output directly?? :doh:
soon_come
Post by soon_come » Wed May 27, 2020 4:20 pm
CoreInside wrote:
Mon Mar 16, 2020 10:48 am
Really enjoyed the tune that starts around 29:30. Great tones.
soon_come
Post by soon_come » Wed May 27, 2020 4:31 pm
AdamJay wrote:
Thu Mar 12, 2020 11:56 pm
I've had it for a day and a half.
I'm digging it.
Model Samples + OT is my current favorite combo, especially live. I have less limitations, oddly, with using samples. And I can adjust start point to get an attack parameter (great for turning kicks into baselines),
but I can definitely get some usable work done on the Model:Cycles, so long as I surrender to the tonality of it.
Here are the three patterns I've made so far (sorry, embed isn't working)
https://soundcloud.com/inoperabledata/m ... fm/s-Brv9g
https://soundcloud.com/inoperabledata/m ... no/s-8cvcY
https://soundcloud.com/inoperabledata/m ... ve/s-7HPWb
All good, but I really dig this third one. How do you like the Micro Limiter? The whole thing sounds nice.
dooj88
Post by dooj88 » Thu Jun 04, 2020 2:30 pm
so nobody has complaints that the sounds are too canned? they are tweakable enough to get an idea out (with perhaps that elektron sound imprint on everything?)
i'm kinda thinking i'd prefer the samples version as i'm only looking for a rhythm addition, not necessarily a whole track composition machine.
Post by lisa » Thu Jun 04, 2020 2:40 pm
I think it sounds great and I can’t hear any typical Elektron sound. However, sound is so subjective so you are probably better off listening to some of the demos. ;)
I’m using it for drums only and I’m very happy with it. Powerful tool with the parameter locks, algorithms, probability settings and etc.
You go too high too early, man. The beat sounds like the a slow mudslide and the melodies that go on and on. :zen:
jdaddyaz
Post by jdaddyaz » Thu Jun 04, 2020 2:43 pm
No complaints here. Sure it would have been nice to have some deeper controls here and there, an extra lfo as well, but I certainly don't feel too restrained. This thing bangs.
LameAim
Post by LameAim » Thu Jun 04, 2020 3:04 pm
I'm not sure that I'd pick Cycles as a primary rhythm machine myself - I usually build up with samples first. Really liking it as a secondary source to fill out the gaps, though. Love the Metal and Chord machines quite a bit. Definitely think it's worth the money.
SnipeCatcher
Post by SnipeCatcher » Sat Jun 06, 2020 2:13 am
Like most, I’d love several upgrades... more LFO’s, individual outs, etc. But $300 gets you a lot of machine. A beginner can make full tunes. It’s also a fantastic drum machine. It can also fill in a lot of gaps in most any system. I bought it on a whim after hearing some amazing demos and I’m very glad I did
AdamJay
Post by AdamJay » Sun Jun 07, 2020 12:35 am
Love me the MicroLimiter. Have two, in fact. Best set and forget dynamics box for me.
and to dooj88:
I feel less limited on my Model Samples than my Model Cycles for sure.
Bought the M:S as a drum machine. Just a simple replacement for the Acidlab Drumatix. Found myself doing way more than that with it.
Got the Cycles because for $300, why not? Using Cycles paired with my A4 (as a filter bank) is giving me really fun results:
https://soundcloud.com/inoperabledata/m ... DDUlaTcZAF
dooj88
Post by dooj88 » Sun Jun 07, 2020 10:29 am
and to dooj88:
that's kinda what my gut is saying, thanks
soon_come
Post by soon_come » Sun Jun 07, 2020 1:14 pm
and to dooj88:
Thanks for the info!
And that's funny - I am an A4 mk1 owner (as of a few months ago), and I have a Model:Cycles on the way because I really don't have any FM-focused synth. I think it will greatly complement the A4 in a very practical way.
soon_come
Post by soon_come » Wed Jun 10, 2020 11:03 am
OK, so here's my first attempt with the Model:Cycles, all sounds streamed direct from the USB audio output to my phone. It's fantastic.
