WHAT IS THIS (piece of equipment)?
Voltcontrol
Post by Voltcontrol » Mon Mar 23, 2020 11:22 am
Could not find the right kind of similar thread, so here goes:
WHAT IS THIS?
Your help would be appreciated.
Thank you.
jdaddyaz
Re: WHAT IS THIS (piece of equipment)?
Post by jdaddyaz » Mon Mar 23, 2020 11:29 am
Sherman Filterbank?
Be good to yourself, and be good to others.
Red Electric Rainbow
Post by Red Electric Rainbow » Mon Mar 23, 2020 11:38 am
2x Tempest. I wonder if one is used more as synthesizer and not a drum machine.
TOO FAR GONE
deltaphoenix
Post by deltaphoenix » Mon Mar 23, 2020 11:41 am
It is a Niio Analog Iotine sound processor
sduck
experimental use of gravity
Post by sduck » Mon Mar 23, 2020 12:11 pm
Voltcontrol
Post by Voltcontrol » Mon Mar 23, 2020 12:13 pm
..Image of the thing..
Thank you! Very impressive bit of kit.
And looks the part too in this type of live setup. More so than say, an Analog Heat.
Post by Red Electric Rainbow » Mon Mar 23, 2020 12:23 pm
Looks very impressive, but the Analog Heat is great if your on a stricter budget.
TOO FAR GONE
Voltcontrol
Post by Voltcontrol » Mon Mar 23, 2020 12:33 pm
That and I'd also appreciate it's portability when touring (considering I'd have to lug my own gear) versus the Niio. But damn, it looks, spec and resulting sound are fantastic.
Voltcontrol
Post by Voltcontrol » Tue Mar 24, 2020 1:31 am
Was expecting 'what's this' questions from y'all by now. Come on, don't by shy! :cloud:
slumberjack
Post by slumberjack » Tue Mar 24, 2020 5:26 am
https://schneidersladen.de/en/niio-analog-iotine-core-4
It's not too expensive but AFAIK not really suitable for stereo use on mixes since the channels are not identical?
btw. Who is the act?
Voltcontrol
Post by Voltcontrol » Tue Mar 24, 2020 5:42 am
Not too expensive for what it is indeed.
Karenn. See/hear it in use here:
vnsc
Post by vnsc » Tue Mar 24, 2020 11:09 am
Funny, I saw the two Tempests and thought, is that Karenn live? Apparently that one video I watched ages ago stuck... (:
http://vaultofstars.com
Music, art, photography, design, words
Zerius
Post by Zerius » Wed Mar 25, 2020 4:34 am
What's the bigbox under the Nioo iotine ?
Bodo1967
Post by Bodo1967 » Wed Mar 25, 2020 4:53 am
I guess it's one of these (TL Audio Ivory 5052 Stereo Valve Sound Processor) -
... why buy it for $100 when you can build it yourself for $150?
Voltcontrol
Post by Voltcontrol » Wed Mar 25, 2020 5:09 am
Nice bit of bit. From the Sound On Sound review:
Pros
*Competent mic preamp.
*Versatile compressor with side-chain access.
*Separate peak limiter.
*Musical EQ section.
*Balanced channel insert facility.
*Digital output option.
*The possibility of a digital input option in the future?
Cons
*None.
slumberjack
Post by slumberjack » Wed Mar 25, 2020 5:15 am
I did not read good things about TL Audio.
slumberjack
Post by slumberjack » Wed Mar 25, 2020 5:16 am
Pros
Cons
*None.
For single channel processing it really seams great. Digital input would be super cool.
Voltcontrol
Post by Voltcontrol » Wed Mar 25, 2020 6:38 am
If you have some sources plz share (or feel free to mention what you've heard.)
Tumulishroomaroom
Post by Tumulishroomaroom » Wed Mar 25, 2020 7:04 am
Benjamin Damages uses the Niio Core as well in his against the clock :
I remeber him saying something to the extent that if you don't have any idea what to do live you can just run your kick / drum machine through it for a while until an idea pops up :)
slumberjack
Post by slumberjack » Wed Mar 25, 2020 7:07 am
First is a friend which is working as producer for national radio, second is my own observation of auction and third are threads on gearsluzz.
The common sense I've got from there is like a strong' either you like it or not' scheme while the group who like it seemed small.
Sorry to lazy to dig all these threads about lower range eq through...
Voltcontrol
Post by Voltcontrol » Wed Mar 25, 2020 9:10 am
Ample signals to launch an investigation for those interested into the matter as far as I'm concerned. Thank you!
nectarios
Post by nectarios » Wed Mar 25, 2020 9:21 am
The Ivory series 5051 and 5013 had a very audible noise floor. If I remember correctly (was using them in uni) the Ivory series uses a lower 150V HT rail than the higher end, high anode plate (HT) voltages of around 250V that the VP-1 uses.
They are "ok", not bad not great, they are not expensive so you get what you pay for.
alog4738
Post by alog4738 » Wed Mar 25, 2020 9:29 am
TL Audio Ivory series is mediocre piece of junk.
Despite the fact that they had nice gear in the past (classic valve series).
https://medias.audiofanzine.com/files/t ... 479645.pdf
So better not to stick to it if you're not planning to perform modifications.
Schrank
Post by Schrank » Wed Mar 25, 2020 1:35 pm
Here we go.. whats the blue beauty in this picture?
Voltcontrol
Post by Voltcontrol » Wed Mar 25, 2020 2:12 pm
That's the EEF Modular, a rare 80's beast from Belgium. https://greatsynthesizers.com/en/genera ... nthesizer/
