More CVs into DFAM
Bite
More CVs into DFAM
Post by Bite » Wed Mar 25, 2020 6:41 am
Hi
Finally I got my DFAM, great stuff - but I badly miss an input on the machine. A CV input allowing me to control/modulate the "VCF EG Amount".
Why, oh why, did that input not made it into the design?
But.. With a soldering iron and insights I guess it's doable (maybe not so advisable). Somone out there that have been brave enough to hack their DFAMs and extended the capabilities and would like to share some insights?
Tajnost
Re: More CVs into DFAM
Post by Tajnost » Wed Mar 25, 2020 8:44 am
Aha, and also step reset input for the sequencer...
I talked to many synth technicians, and all of them told me that it's super hard if not impossible to hack dfam due to the way it made inside.
However, would love to see some mods, especially sequencer related (back/frw playing, random, step reset or just set the seq length ).
Richard deHove
Post by Richard deHove » Wed Mar 25, 2020 11:08 am
Loopop has a good video on the DFAM which has a workaround for sequence length. The Moog Music channel also has a worthwhile hour long video on some deeper aspects. There's still a lot that can be done with DFAM even though it has quite a few "wish it had" aspects.
hinterlands303
Post by hinterlands303 » Thu Mar 26, 2020 11:48 am
Hi
Do you have a modular outside of the DFAM? If so you could use an external (DC coupled) VCA.
Set the VCF EG amount know to zero. Envelope out into VCA in. Control signal to CV input of VCA. VCA output to VCF Mod input.
flashheart
Post by flashheart » Thu Mar 26, 2020 6:17 pm
Hi
Adding control of an amount of something (in this case the EG) involves a VCA, not that trivial, would have been nice but I can see why it's not there as standard. Wouldn't be easy to add either.
I'm not buying a maths though, not my idea of fun...
flashheart
Post by flashheart » Thu Mar 26, 2020 6:20 pm
Hi
Adding control of an amount of something (in this case the EG) involves a VCA, it's not that trivial. Yes it would have been nice but I can see why it's not there as standard. It'd need more than a sodering iron and a drill :)
seta666
Post by seta666 » Fri Mar 27, 2020 9:24 am
It would be nice if the sequencer could be hacked. Number of steps and reset.
FM audio input would be nice too.
Transistor
Post by Transistor » Fri Mar 27, 2020 10:01 am
+1 on the reset, horrible omission. I still very much looove the DFAM though!
hru
Post by hru » Fri Mar 27, 2020 11:15 am
Behringer pls install the DFAM to your upcoming Q960 Clone-Sequencer
Moog is these Days apparently too stupid for that
Otherwise Pattering + Expert Sleepers FH-2 works with DFAM well
seta666
Post by seta666 » Fri Mar 27, 2020 4:16 pm
I wish moog had used Korg's SQ-1 sequencer..
hru
Post by hru » Sat Mar 28, 2020 3:33 am
SQ-1 is great but there would also be no reset.
almost all hardware sequencers have too few CVs
Maybe a Voltage Block + Attenuators (Dfam needs different Volts)
seta666
Post by seta666 » Sat Mar 28, 2020 3:52 am
I know it has no reset but it is still way better than DFAM's own sequencer
I use the step jump button as a manual reset button, and if you press stop button at least it goes back to first step.
In DFAM you have to stop the sequencer and manually advance to the last step...it is a very dumb dumb sequencer..
hru
Post by hru » Sat Mar 28, 2020 4:29 am
very good Tip, Thanks!
