Ensoniq ASR-10 rackmount is very hot
thunderheart530
Post by thunderheart530 » Mon May 18, 2020 2:27 am
Does anyone who own's an Ensoniq ASR-10 have a solution for the amount of heat this unit produces? the front panel around the transformer gets very hot after a few hours and they decided not to put any vents on the top. I talked to a tech and he said if I tried to add a fan it would most likely add noise to the signal. Has anyone bothered to do this?
WTB/Trade Modcan A series or A series format modules.
nangu
Re: Ensoniq ASR-10 rackmount is very hot
Post by nangu » Mon May 18, 2020 2:43 am
Following. The keyboard version was my largest hammer in the mid to late 90s. Got a great deal on a rack a couple years ago, but it has button issues. I’ll be looking at possibilities when I have it open again.
The obvious solution would be to drill some strategically placed holes to aid convection. Probably lots of tiny holes- to deter spiders and dust from invading the chassis. I hate adding acoustically noisy fans to things, so I don’t care whether a fan would be electrically noisy or not.
gruebleengourd
Post by gruebleengourd » Mon May 18, 2020 3:18 pm
The bad news is that ASR-10 racks that run to hot are prone to crash, and there is not a lot you can do too cool it beside drill holes and install a fan. I had enough trouble with it that I downgraded to an EPS16+. It will be somewhat better if you do not install it in a rack with other units adjacent to it.
thunderheart530
Post by thunderheart530 » Tue May 19, 2020 1:36 pm
Pulling it out of the rack has definitely helped. I also put it in a spot where I can access it with ease as I have been using it so much lately.
About drilling holes, Maybe taking the top to a shop and having it professionally cut might be the best option? Also putting some sort of foam inside to keep dust from getting it.
nangu
Post by nangu » Tue May 19, 2020 2:08 pm
I think foam would block convection and act as an insulator. If I do decide to drill holes, I have adequate tools to do a good job.
I’m planning to continue using the open-frame rack it’s in now- I haven’t noticed excessive heat, but will be keeping a closer eye on things..
My rack is similar to this, but I think it cost less:
https://www.samash.com/hosa-rmt-254-19- ... rmt254xx-p
Blairio
Post by Blairio » Tue May 19, 2020 8:46 pm
How much free rack space do you leave above and below your ASR10?
Could you leave 1 U above and below it, and buy some vented 1U panels to cover the gaps?
thunderheart530
Post by thunderheart530 » Wed May 20, 2020 1:54 am
I actually decided to separate the unit from the rack for now. I'm going to look for someone who can modify the top around town.
