With a sequence playing (such as one might do during a performance), I want to be able to edit the note in a given step (via "Step Edit") and NOT have that note also PLAY when I tap it.
In other words, I'd like to be able to edit a sequence in step edit, when it's running, without having to get the timing right so I don't just have a random-ish note sound whenever I'm trying to edit.
Having a step-edit function is much less useful if you still have to hit the notes just right if you're using it during a performance. So, I figure I must be missing something, but I've tried:
- Shift-step edit
- Holding down the step when hitting the note
- Trying to do step-editing in "Record" mode rather than playback mode. (Step edit turns off)
- Going into record mode and holding down the step button then hitting the note (works the same)
