Inexpensive mic pre with optical out?
- slentthndr
- Common Wiggler
I have an Apollo Twin x, and I need to be able to record at least 1 additional channel, so I'm looking for a mic pre that will interface with my adat/spdif input.
I'm having trouble finding good info online about this, so I thought I'd ask the hive mind. Do y'all have recommendations?
Priorities:
1) Relatively inexpensive (sub $500, ideally less)
2) Not giant (I don't need a huge 8 channel deal)
3) Tube would be a bonus, but not essential
Obvi it has to sound good, whatever that means to you/us.
And it has to have an optical out.
EDIT: side question.... can I use an amp that's marketed as a headphone/phono type amp? as long as it has an optical out doesn't that mean it's doing the analog-to-digital conversion and it will work?
Priorities:
- rowsbywoof
- Ultra Wiggler
- Contact:
Re: Inexpensive mic pre with optical out?
Hmm... A mic pre with ADAT or optical might be hard to find, but XLR to ADAT a lot less so. Maybe go standard mic pre with a converter box in line to the Apollo? You can probably find relatively cheap boxes to do that conversion.
ART Digital MPA II?
It's stereo, tubes, optical output available.
I've got one going into an RME PCIe card and it sounds pretty good to me.
https://www.sweetwater.com/store/detail ... eamplifier
- slentthndr
- Common Wiggler
Oh interesting. Do you have an example of such a converter box that you could link for me? Maybe I'm missing something, but my searches are coming up empty. The mic I'm trying to add in via ADAT is a Rode NTK, and it comes with it's own tube 'power supply' which might amplify the signal already? Idk, but maybe there's a chance I wouldn't need much additional amplification... that's probably stupid. I'm sure I'll need something.rowsbywoof wrote: ↑Sat Sep 26, 2020 11:28 amHmm... A mic pre with ADAT or optical might be hard to find, but XLR to ADAT a lot less so. Maybe go standard mic pre with a converter box in line to the Apollo? You can probably find relatively cheap boxes to do that conversion.
Focusrite isa one has an optional digital in/out.
https://www.soundonsound.com/reviews/focusrite-isa-one
The Rode power supply is only a power supply, it does not function as a mic preamp. You still need a separate preamp. If it has to be an optical out, the ART looks like the best bet in that price range. The option of using any analog pre amp and a separate A/D converter would be more flexible, but it would be hard to beat the price/performance of just using the ART box.slentthndr wrote: ↑Sat Sep 26, 2020 12:28 pmOh interesting. Do you have an example of such a converter box that you could link for me? Maybe I'm missing something, but my searches are coming up empty. The mic I'm trying to add in via ADAT is a Rode NTK, and it comes with it's own tube 'power supply' which might amplify the signal already? Idk, but maybe there's a chance I wouldn't need much additional amplification... that's probably stupid. I'm sure I'll need something.rowsbywoof wrote: ↑Sat Sep 26, 2020 11:28 amHmm... A mic pre with ADAT or optical might be hard to find, but XLR to ADAT a lot less so. Maybe go standard mic pre with a converter box in line to the Apollo? You can probably find relatively cheap boxes to do that conversion.
double post
- slumberjack
- Super Deluxe Wiggler
- Contact:
blakeq wrote: ↑Sat Sep 26, 2020 1:07 pmFocusrite isa one has an optional digital in/out.
It's designed by Rupert Neve, so the price is a steal.
> WTB ADDAC502 <
www.stefanrudin.bandcamp.com / www.soundcloud.com/stefan_rudin / www.youtube.com/user/slumberknut
Carefully crafted dj set meandering between deep house, minimal and electro.
- Michael O.
- Veteran Wiggler
- Contact:
Came here to recommend this one. Excellent and versatile preamp that you’ll never outgrow or need to upgrade.blakeq wrote: ↑Sat Sep 26, 2020 1:07 pmFocusrite isa one has an optional digital in/out.
The Focusrite is single channel, the ART is two channels. If you are pretty sure you won't need two mic pre's / stereo inputs, the Focusrite is the better choice. Focusrite ISA series is very nice stuff.
I'm not advocating for any specific product here, but careful on the Focusrite if the budget is $500 and you want optical output. The AD converter is an optional add on and costs close to the price of the preamp.
Audient Mico
It's not being made new anymore, but there's one on reverb...
Yeah. The board is optional. Would need to either pick up a used one with the digital board or one without and then add it.
Wouldn't you just get a Behringer ADA8200?
- slentthndr
- Common Wiggler
Hmm. I was about to pull the trigger on the ART Digital II but then I realized it only runs at 16-bit. I imagine I'd have to run my apollo at 16-bit as well then to use the ensemble, and I don't really want to do that. The Focusrite ISA One looks cool, but with the cost of the A/D board factored in its nearly double my intended price range. Soooo, back to the drawing board I guess!
Looks cool but I don't see it on reverb.
Hmm. Looks like this only goes up to 48k and I like to record at 96k. Also I don't trust behringer, but that's just a personal thing I'm sure I could get over.
- rowsbywoof
- Ultra Wiggler
- Contact:
I have two of these: https://www.musiciansfriend.com/pro-aud ... -converter
They're usually cheap (< $100 on average, and under $50 from time to time), solid, and work great for getting digital to analog and the reverse. Just great boxes that are easy to find used, but... Didn't see you were recording at 96k. The Flying Cows only do up to 24bit/48kHz which is perfect for my uses, but a bit under for yours. Not sure if you need to record at that high of a sample rate, but if you do, that probably does reduce the cheap side of the market a bit.
The old Presonus Eureka mic channel. They didn't come with digital out but you could buy it as an option.
I saw some completed eBay listings that were around $500 and included the digital board if used is an option and if you can wait.
That card is spendy new! I thought it was a couple hundred. Not closer to 500...
slentthndr wrote: ↑Sun Sep 27, 2020 7:24 pmThe Focusrite ISA One looks cool, but with the cost of the A/D board factored in its nearly double my intended price range.
- slumberjack
- Contact:
Well there are the DBX tube preamps with EQ, comp and de-esser and digital out. I had one but sold that piece, it sounded not round rather harsh to my ears for a tube. But you find them for 200-300 used and they are useful.
If you don't want to spend on and ISA AD option you might look after an other AD conversion option like an audio interface. As in another post mentioned, the ISA is something that will never leave your studio since it's pro level stuff nor consumer or prosumer type electronics and in that case you'll maybe want to get the ISA DUO so you can use in on synths with stereo signals too and rack it up.
> WTB ADDAC502 <
A really cost effective way would be the Mindprint DI Port.
It's not top shelf stuff, but definitely useable.
- bobbylandry
- Common Wiggler
- Contact:
You can usually run 16bit into 24bit SPDIF without any problems, it's sample rates that cause the real problem. SPDIF will just puts 0s in place of the missing bits, or something, I'm not sure the technical reasons why it works. ART mentions dithering in the product description so they seem to be expecting people will connect it to 24bit gear.slentthndr wrote: ↑Sun Sep 27, 2020 7:24 pmHmm. I was about to pull the trigger on the ART Digital II but then I realized it only runs at 16-bit. I imagine I'd have to run my apollo at 16-bit as well then to use the ensemble, and I don't really want to do that. The Focusrite ISA One looks cool, but with the cost of the A/D board factored in its nearly double my intended price range. Soooo, back to the drawing board I guess!
- slentthndr
- Common Wiggler
Super helpful comments all around. Thanks everyone. I also discovered the ART VoiceChannel tube channel strip, and now I'm sorta leaning towards that. It does 24bit 96k, has some extra controls for eq/comp, and by all accounts sounds nice/usable.
I guess the 16bit dither into 24 on the ART Digital would be fine. Thanks bobby for explaining that! But I'd rather encode all 24 bits since it's for a vocal and I'd like it to be as expressive as possible. Hopefully I'm not being an extremist about the numbers... idk. Plus I've heard that you're supposed to dither as few times as possible on a track - ideally just once for the master. Not sure exactly what the mechanics of that are, but that's another reason why I'm leaning in favor of the VoiceChannel.
- bobbylandry
- Common Wiggler
- Contact:
The dither shouldn't make any practical difference but the Voice Channel looks pretty sweet anyway. The dither would only happen going from 24 bit to 16 bit, so in your case leaving the computer and going into the MPA. I believe what happens when going from 16 bit to 24 bit, the MPA into the computer, is that since the bits don't exist they are set to 0s. All the same I've never actually tried this with the stuff you're looking at and might be totally wrong so absolutely don't make a purchase based on anything I've said! Also if you have to raise the signal a ton once it's recorded you might get a higher noise floor with only 16 bits available, though the noise of the tubes would probably be higher.
You don't need more channels but if you ever do I use the old M-Audio Profire 2626 over ADAT with my RME setup. You can get 8 preamps with that, which I think sound plenty good, or it has combo jacks so if you connect another preamp via 1/4 inch it bypasses the internal one. You unfortunately need an old computer with Firewire that can run the old drivers to setup the standalone mode. The ADA8200 is the modern cheap option for almost the same thing which is why it was suggested above.
Not trying to make this more complicated, the Voice Channel looks sweet.
- slentthndr
- Common Wiggler
Thanks! I got the VoiceChannel and it sounds nice. I like it so far but I'm also having wicked problems getting the audio to route correctly in UAD Console. That's a topic for another thread though, I suppose. Gaaah.
