KYMA - SONIC LAB SEEDS
Reaktor, MAX/MSP, VST/AU, etc. A place for all things soft....
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Fri Jan 10, 2020 5:08 am
A Brass Swarm with one of the, by Ben, provided Fairlight samples:
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Sat Jan 11, 2020 9:48 am
Controllers: QuNeo is talking to the Pacarana
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Mon Jan 13, 2020 9:22 am
INTERSECTIONS
Roland Kuit: Buchla 200 | Kyma 7 | Pacarana
At the intersection of analogue - and digital modular.
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Tue Jan 14, 2020 4:31 am
I just tested more midi controllers at the same time in Kyma. It is working, see the DSP window:
About updates in MIDI in Kyma:
-- New !SongStart, !SongStop, !SongContinue EventValues that you can control by sending the respective MIDI System Real-Time Messages to the Paca(rana)'s MIDI input
-- You can now merge up 8 USB MIDI controllers using the drop down menu in the DSP Status window (requested by JPJ)
-- Fixed longstanding bug in Preferences>Performance>External MIDI Controller>Echo MIDI which would always output 3 zero MIDI bytes after the correct data. (Thanks to Doug Kraul for reporting)
-- Added 14-bit MIDI controller support for Echo MIDI mode
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Fri Jan 17, 2020 4:43 am
As FireWire will disappear, Symbolic Sound is ahead in this situation. The Kyma Paca(rana) can be connected both, by FireWire/USB-C, or Ethernet laptop connection. Expansion Port B using a Cat6 Ethernet cable:
peripatitis
Re: KYMA examples
Post by peripatitis » Fri Jan 17, 2020 4:50 am
Wow, can you really connect kyma to pacarana thru the ethernet connection?
I had no idea, that would be a life saver.
I've been looking for thunderbolt laptops all this time..
By usb-c you mean thunderbolt right?
Of course this does not remedy the audio interface situation, since the selection there has become a lot thinner.
bphenix
Re: KYMA examples
Post by bphenix » Fri Jan 17, 2020 8:44 am
If I had to setup a system from scratch today and I only needed stereo, I’d used the Dante USB to Ethernet adapter with Kyma.
I do hope for another revision on the hardware side, mostly because I’ve been pushing the limits on the processing side. I may just go wormhole soon. Unfortunately, they can’t use enable Dante on the current hardware due to the need for specialized chipsets.
I currently from USB-C to a PCI enclosure that has my RME HDSP AES interface and FireWire card for Kyma & a Lynx Aurora. I also use Ethernet because that is how I’ve always used Kyma Connect. The setup works great and the AES & Lynx are also used by the rest of the studio. It is semi-annoying that changing specs will make the current setup harder to maintain in the future, though from a pure spec and connector standpoint, USB-C has a lot going for it if implemented to the fullest of the spec.
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Sat Jan 18, 2020 3:37 am
Yes, ethernet.
On my Lenovo laptop I used this connection:
From Thunderbolt in/out to Startech TBT - Apple FireWire
As there are 2 FW ports on the Paca(rana), I still use FW to my audio interface connected directly with my Pacarana.
peripatitis
Re: KYMA examples
Post by peripatitis » Sun Jan 19, 2020 4:07 am
Thanks Roland, I cross checked it with Carla and/or Bert in the forum.
I wasn't 100% certain I understood your setup. But yes, with kyma 7+ which is the 64bit version,
you can use the expb ethernet port to connect with a pc or mac instead of the firewire interface.
This is great for the pc world, where thunderbolt is not so popular but the express port is :)
peripatitis
Re: KYMA examples
Post by peripatitis » Sun Jan 19, 2020 4:15 am
A new hardware would be a blessing and curse for me I guess.
I am not utilizing my pacarana to that extend, but the allure of new algo's not being able to work on previous machines
is something usual in symbolicsound's world :)
I would hope they include the audio interface this time around,
somehow owing capybara before the rana and not having to look for supported interfaces whilst undeniably
getting an excellent sound from the included interface made things simpler.
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Sun Jan 19, 2020 4:30 am
Back to sound examples.
Resynthesis in Kyma is an extremely powerful tool:
gosh
Re: KYMA examples
Post by gosh » Sun Jan 19, 2020 5:57 am
It’s a real shame that Dante (or audio over Ethernet) can’t be enabled but it is what it is. At least the data over Ethernet simplifies things (I was already using for KymaConnect too). I’d happily pay for either new hardware or a mod to existing hardware to remove the requirement for a separate audio interface. A little extra processing power wouldn’t go amiss though. With things like replicators now I’m Kyma it can be quite easy to max out.
Love Kyma and Symbolic Sound though, they are so responsive and their continual stream of updates and new features is outstanding!
Here are a few new things I’ve done;
https://soundcloud.com/unconventionalwi ... avetable3d
Hidden Markov Model on Vivaldi’s four seasons with a few interpolated wavetables.
https://soundcloud.com/unconventionalwi ... everywhere
Replicated chaotic7 chopping of James Blake and Fleetwood MAC songs ;)
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Mon Jan 20, 2020 1:53 am
So much fun! :)
Roland Kuit
Re:
Post by Roland Kuit » Tue Jan 21, 2020 5:51 pm
Roland Kuit wrote:
Sun Dec 01, 2019 2:56 am
Project: The violoncello sound is processed in the spectral domain in Kyma.
This abstraction is modulated by the violoncello's amplitude and frequency.
Balázs Adorján - Violoncello
Roland Kuit - Kyma
Again with Balázs Adorján - Violoncello,
This time his bowing is helped by KYMA with 4 lossy integrators:
Roland Kuit
Re:
Post by Roland Kuit » Tue Jan 21, 2020 5:52 pm
bphenix
Re: KYMA examples
Post by bphenix » Sun Feb 02, 2020 7:45 pm
Spectrum from Fairlight samples setting the frequency and amplitude of a cloud bank that is then fed into harmonic network that is also being controlled by the same spectral source. Wave shape of grains in the cloud bank are being slowing modulated.
chiavere
Re: KYMA examples
Post by chiavere » Mon Feb 03, 2020 9:32 am
Gorgeous work, @bphenix ! :yay:
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Thu Feb 06, 2020 8:42 am
Ben Phenix Fairlight human sample spectra for this example:
bphenix
Re: KYMA examples
Post by bphenix » Thu Feb 06, 2020 9:03 am
That is great, Roland. Has that nice organic feel of a Delia Derbyshire piece or similar.
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Sat Feb 08, 2020 9:42 am
Acoustic cello noise controlling swarm agents in additive FB system:
bphenix
Re: KYMA examples
Post by bphenix » Sun Feb 09, 2020 6:18 pm
Prompted by a conversation with fabbly about physical modeling and drums, I tried to build an 'acoustic' kit in Kyma. Instead, I ended up with something more like my old Emax II with an 808 sample set.
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Tue Feb 11, 2020 8:59 am
Still a very acoustic feel into it Ben. Did you use a modal filter for this?
bphenix
Re: KYMA examples
Post by bphenix » Tue Feb 11, 2020 9:25 am
I used a combination of a modal filter, spectra files plus creating an impulse that is only the 'unvoiced' part. Was a bit fiddly and I had some issues with other samples, particularly a low tom for some reason. I may return to the ideas later but I hooked back up the Soundplane yesterday so I think I am going to work on fine-tuning an instrument for playing on that.
Roland Kuit
Re: KYMA examples
Post by Roland Kuit » Wed Feb 12, 2020 8:24 am
PM Snare Drum Model.
Tweaking stiffness and HP Filter:
bphenix
Re: KYMA examples
Post by bphenix » Mon Feb 17, 2020 10:15 am
I seem to be very much in the physical modeling rabbit hole this year.
Here is a sympathetic string example. The decay is set a bit overly high because I was pushing it to see what happens. Using Satie's Gnossienne as the sequence.
Here is a heavy feedback / distorted version. Same sequence, same basic model but with different feedback and added an offset to the modal filter ratios.
Return to “Music Software”
