NoClassDefFoundError with OpenJRE (Ubuntu)
Downloads, information and resources for the RackPlanner software.
Moderators: Kent, dougcl
sonicwarrior
Post by sonicwarrior » Sat Sep 03, 2011 4:20 am
I'm getting a NoClassDefFoundError with Ubuntu 10.10 and OpenJRE:
Java version:
$ java -version
java version "1.6.0_20"
OpenJDK Runtime Environment (IcedTea6 1.9.9) (6b20-1.9.9-0ubuntu1~10.10.2)
OpenJDK 64-Bit Server VM (build 19.0-b09, mixed mode)
$ ./start.sh
Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/jai/operator/SubsampleAverageDescriptor
at org.gnu.java.music.rackplanner.ModuleFactory.resize(ModuleFactory.java:159)
at org.gnu.java.music.rackplanner.ModuleFactory.getModule(ModuleFactory.java:173)
at org.gnu.java.music.rackplanner.Rack.addModule(Rack.java:188)
at org.gnu.java.music.rackplanner.Rack.readModulesFromXML(Rack.java:167)
at org.gnu.java.music.rackplanner.Rack.<init>(Rack.java:362)
at org.gnu.java.music.rackplanner.RackPlanner.addRack(RackPlanner.java:270)
at org.gnu.java.music.rackplanner.RackPlanner.main(RackPlanner.java:306)
Caused by: java.lang.ClassNotFoundException: javax.media.jai.operator.SubsampleAverageDescriptor
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
... 7 more
Is this class really missing in OpenJRE? It looks like the class is a part of the Java Media Framework, but I don't remember having to install it when I used RackPlanner with Windows. :hmm:
Soundcloud
For sale: Jürgen Haible Tau Phaser (MOTM format)
pugix
Post by pugix » Sat Sep 03, 2011 12:49 pm
I'm not following OpenJDK. I did a search, but didn't find much. I am a Java programmer (since 1.1). I suggest trying a different JDK. You can download an Oracle 1.6 JDK for your Linux box here.
http://www.oracle.com/technetwork/java/ ... 40405.html
Usually you only need to set JAVA_HOME environment variable to the installation you want applications to use, and also put the Java bin directory into your path.
Richard
http://www.pugix.com
chromium
Post by chromium » Sat Sep 03, 2011 2:36 pm
sonicwarrior wrote:Is this class really missing in OpenJRE? It looks like the class is a part of the Java Media Framework, but I don't remember having to install it when I used RackPlanner with Windows. :hmm:
I glanced at these, and it looks like JMF and JAI are released under Sun's binary code license, which might prevent inclusion in the open-source JDK/JRE(?) Looks like you can get them separately here: http://www.oracle.com/technetwork/java/ ... 1e-oth-JPR
The Oracle JDK/JRE that Pugix linked to would contain the closed-source components, and installing that would probably be the easiest solution.
sonicwarrior
Post by sonicwarrior » Tue Sep 13, 2011 6:36 am
Ha, guess what? It works with OpenJRE! At least RackPlanner 1.2.
It had to be an older version I was using. :banana:
Soundcloud
dougcl
Number 6
Post by dougcl » Thu Sep 15, 2011 7:39 pm
I believe that JAI stuff got ripped out of the latest version (v1.2). I was trying a bunch of rendering options, but then I discovered a simple bug (my fault) and the discovery allowed me to revert the code to the simplest solution, apparently making the program more robust in the process.
Return to “RackPlanner”
