Volta Ring Output
Discussion and support for MOTU's Volta software.
Moderators: Kent, stretta
ThatFunnyLookinGuy
Volta Ring Output
Post by ThatFunnyLookinGuy » Sun Nov 29, 2009 3:56 pm
When Volta is sending cv from the tip contact, what is it sending to the ring contact?
1nput0utput
Post by 1nput0utput » Mon Nov 30, 2009 8:08 am
Technically speaking, Volta is not generating anything but the CV signal you've configured it to generate at a particular output. The balanced output of the audio interface produces that signal on the tip portion of a TRS jack or pin 2 of an XLR jack, and it produces the same signal phase-inverted on the ring portion of a TRS jack or pin 3 of an XLR jack.
ThatFunnyLookinGuy
Post by ThatFunnyLookinGuy » Mon Nov 30, 2009 5:07 pm
So if these two voltages were to be combined in a stereo to mono cable and sent to say, an oscillator, would it cause a problem?
1nput0utput
Post by 1nput0utput » Tue Dec 01, 2009 9:35 am
That depends upon your definition for problem.
For example, imagine that the signal you're dealing with is steady at +3 VDC. That signal appears on the tip portion of the output. The balancing amp in the output inverts the polarity of the signal and transmits that on the ring portion of the output. When you invert the polarity of +3 VDC about ground (0 VDC), you get -3 VDC. Then you want to sum those two signals on a TRS-to-TS cable. What do you get when you sum +3 VDC and -3 VDC?
Like I said, it's only a problem if you expect to have a useful signal after summing…
doctorvague
ole fuckity fuck
Post by doctorvague » Tue Dec 01, 2009 9:58 am
There's no summing going on here that I can see. You'd simply be shorting the outputs and risking blowing up the output circuitry. Shorting the ring to ground is to be avoided according to MOTU, so shorting +5V to -5V would be that much worse. Don't do it!!
Return to “Volta”
