Volta killing external MIDI control on Ultralitemk3
Moderators: Kent, stretta
thekernel
Post by thekernel » Wed Aug 18, 2010 8:04 am
Hello.
I've installed Volta on two different operating systems. In each instance, volta disables external MIDI control. I can control my synths with the computer keyboard in Logic 8 and Ableton 8, but all external MIDI control is 'knocked out' , even for the onboard software synths etc.
My MOTU Ultralite mk3 is receiving MIDI (the 'm' flashes to indicate this), but neither software recognises the signal. I've re-installed the ultralite software, but this still doesn't solve the problem.
Has anyone else encountered this, or am I doing something fundamentally silly? Any help would be greatly appreciated because other than this, everything is sounding great.
With thanks,
K
thekernel
Post by thekernel » Fri Aug 20, 2010 11:21 am
Just me?
I've haven't heard anything from MOTU either :(
thekernel
Post by thekernel » Tue Aug 24, 2010 5:25 pm
*UPDATE*
One week later and still no reply from MOTU about this issue. (Despite a promise of a reply within two working days).
So, in an attempt to get around the MIDI problem, I installed my USB Oxygen 8 controller... and this was a success with Ableton.
This install also brought the external MIDI to life from the ultralite, however, this again became disabled when I made any adjustments and switched from one midi input to the other (or added another instance of Volta).
It's a case of having to deactivate the ultralite input in Ableton, exiting, re-opening and turning the Midi input back on.
This entire scenario sounds like some kind of MIDI software conflict. I wasn't expecting this from MOTU. Their advert for volta even features an ultralite!
I haven't tried this workaround with Logic yet, but i'll post here when I get round to it.
isaaclevy
Post by isaaclevy » Thu Aug 26, 2010 3:06 am
hey there, any news on this issue? have you worked it out?
cheers.
thekernel
Post by thekernel » Sun Aug 29, 2010 4:16 pm
Still no response from MOTU. My 'tech issue' remains unread.
hmmm.
The only workaround is the one mentioned above, and i still haven't resolved this problem with Logic 8 or 9 on 10.5.6 or 10.5.8.
I will have another go with logic and see what i can do.
Surely someone else must have encountered this issue?
m0rb1d
Filtersweep Abuser
Post by m0rb1d » Sun Aug 29, 2010 7:18 pm
good to know i almost bought an ultralight and volta
thekernel
Post by thekernel » Sun Aug 29, 2010 8:54 pm
ok, checked my volta/ultralite set up with Logic 8 on a 10.5.6 system...
The USB Oxygen 8 control works fine, but there are problems with the Ultralite MIDI input control. If for example, you wish to change the hardware buffer size or activate Logic's MIDI beat clock, external midi control to the Ultralite is disabled. The only way to remedy this is to click on the 'reset Midi devices' button. This, as you can well imagine, is a major pain. Besides which, even with a low setting of '64' in the hardware buffer, the latency is for me unacceptable/unusable. (I'm using a 2.5 GHz core 2 duo/4 GB ram MBP BTW)
On the plus side, Ableton 8 is rock solid, but i'm not exactly thrilled to be paying a fortune to be a beta tester.
The_Crooked_Man
mad man with a box
Post by The_Crooked_Man » Sun Sep 05, 2010 10:52 am
MOTU's tech support/customer service is the absolute worst that I've ever encountered. I had an unresolved "tech issue" for months with them. I've also worked for pretty much every music store in the Philly area, and all of my customers that had to deal with them said the same thing. I really want Volta, but am loathe to deal with/support them in any way, shape or form.
thekernel
Post by thekernel » Mon Sep 06, 2010 9:45 am
I had contact from MOTU four days ago. They said:
'We have not been able to reproduce the symptom you're reporting with an UltraLite mk3 Hybrid'
Hmm. :bang:
thekernel
Post by thekernel » Thu Sep 23, 2010 3:14 pm
Yup, still no way forward. The workaround is the only way.
In addition, importing a MIDI file causes a whole heap of problems in Ableton 8/ Volta...
Good job I had the Oxygen 8 really, otherwise i'd have been screwed.
On the plus side, when it works, it's really fantastic and is the holy grail of analogue sequencing!
emergencyofstate
Synthesist
Post by emergencyofstate » Thu Sep 23, 2010 3:31 pm
Hmm, I've always used Volta with 2 seperate Ultralites with no problems (firewire old, and firewire mk3)
Although I'm not really sure I understand the problem. So the problem is only inside Logic Pro now? You got things working in Live?
thekernel
Post by thekernel » Sat Sep 25, 2010 10:27 am
No, I get MIDI problems with Ableton and Logic when using Volta.
For example, I can load up Logic and select an EXS24 piano. I can then play that piano from my Korg Z1. Simple MIDI out from the Z1 to MIDI in on the Ultralite MK3. So far so good.
If I then set up Volta, all MIDI input to the Ultralite becomes disabled. That means that when i call up volta, it disables control of the EXS24 and any other MIDI controlled elements in the software. To get control back, i have to select 'reset all MIDI devices'. This is a pain, because any software adjustment (or an additional instance of volta) means that i have to keep selecting "reset all MIDI devices'.
I would like to use my Z1 with this set up because it has a useful arpeggiator. In addition, importing MIDI files causes volta to go nuts...
Weirdly, i was expecting to have problems with the CV/Gate side of things, but this is not the case. That's fine...
In Ableton, calling up volta does the same thing. All MIDI input via the Ultralite becomes disabled when using volta. It's fine when using the Oxygen 8, and i suspect that is because it's on it's own USB bus. As i've said before, the 'm' flashes on the ultralite so i know it's receiving MIDI... the software however doesn't get it. I'm convinced that this is a volta software problem.
By the way, I'm powering the ultralite via firewire, and note that my macbookpro has to be powered via the mains power as the ultralite will not operate without well on macbook battery power alone. From the battery, there is not enough power and all audio becomes distorted. The LCD on the ultralite also flashes and fades. This is a seperate side issue to the volta issue of course...
thekernel
Post by thekernel » Wed Jun 15, 2011 7:11 pm
I bought Silent Way. Problem solved. Perhaps MOTU would like to re-imburse me? :hmm:
Return to “Volta”
