firmware 4.17 issues
Moderators: Kent, os
Post by ignatius » Sun Sep 13, 2020 10:16 pm
4.17 is buggy as hell for me. doesn't really work. crashes the module. also, doesn't allow paging through parameters. the Z knob still works but pressing it doesn't page through the parameters.
os
Re: disting mk4 firmware announcement thread
Post by os » Mon Sep 14, 2020 2:16 am
Splitting to a new thread.
os
Re: firmware 4.17 issues
Post by os » Mon Sep 14, 2020 2:18 am
Could you expand on what crashes and when?
Some algorithms use Z for something else e.g. reverbs use it as freeze. You can still select parameters with S.
Post by ignatius » Mon Sep 14, 2020 1:45 pm
i was exploring the granular pitchshifter and only had access to the first parameter. couldn't page through the other parameters. i tried to change algorithms and it freaked out and would jump around in the algorithm list as i turned the knob. then all the lights in the display got brighter and it did a kind of pulsing thing and freezed up. I rebooted and tried again but got same results.
i put v4.16 back on it and it now works as it should.
edit: i should add that i did reinstall v4.17 thinking maybe something went wrong w/the install and wiping it and starting again would help but it didn't.
os
Post by os » Tue Sep 15, 2020 2:02 am
4.17 adds the freeze function to the granular pitch shifter, so you'll have to change parameters with S.
Post by ignatius » Tue Sep 15, 2020 1:27 pm
push/turn S right? well, i'll give it another go but didn't work out last time. will report back.
Post by ignatius » Wed Sep 16, 2020 9:23 pm
sucess this time! i think i maybe was a little impatient with the previous install and was jumping around trying to get through parameters and that caused some freaking out of the module. seems fine now that I go slower through accessing the parameters via the S knob.
tldr - user error ;)
Return to “Expert Sleepers”
