How to use vst editors for hardware synths??
Moderators: Kent, os
Luigi
Post by Luigi » Sun May 31, 2015 6:26 pm
How do I setup vst editors for hardware synths, like Soundtower, with my Expert Sleepers, when the outputs of the Expert Sleepers dont show up in the vst editors midi in/outs list?
cheers
win7 PT11
Post by os » Mon Jun 01, 2015 2:00 am
What Expert Sleepers stuff are you using?
Luigi
Post by Luigi » Mon Jun 01, 2015 6:03 am
os wrote:What Expert Sleepers stuff are you using?
ESX-8MDmk2 and ES-40 in pro tools 11 win7
cheers
Post by os » Mon Jun 01, 2015 11:50 am
You have to send the MIDI into the plug-in. Pro Tools supports sending SysEx into plug-ins so it should be possible.
Luigi
Post by Luigi » Tue Jun 02, 2015 6:01 am
os wrote:You have to send the MIDI into the plug-in. Pro Tools supports sending SysEx into plug-ins so it should be possible.
Ok but how? when I cant choose the Expert Sleepers midi outs inside of the plugin? just my regular midi outs?
cheers
Post by os » Tue Jun 02, 2015 7:57 am
Luigi
Post by Luigi » Tue Jun 02, 2015 2:23 pm
ok thx!
I tried it and still nothing. I choose the Loopbe1 inside the plugin, but nothing still happens.
Post by os » Wed Jun 03, 2015 5:44 am
You don't want to choose Loopbe1 in the plug-in, you'd want to choose it in PT for the MIDI track input.
Luigi
Post by Luigi » Wed Jun 03, 2015 5:54 am
os wrote:You don't want to choose Loopbe1 in the plug-in, you'd want to choose it in PT for the MIDI track input.
okey then what sould I choose inside of the plugin?
cheers
Post by os » Wed Jun 03, 2015 5:55 am
You don't need to choose anything.
In fact I'm not sure what you're asking - where in the plug-in is there a MIDI input to choose?
Etan
Post by Etan » Wed Jun 03, 2015 6:57 am
Probably you just need to (re)read the manual which is usually the case with "non working" es hardware/ software around here...
Luigi
Post by Luigi » Wed Jun 03, 2015 7:35 am
os wrote:You don't need to choose anything.
cheers
Luigi
Post by Luigi » Wed Jun 03, 2015 7:37 am
Etan wrote:Probably you just need to (re)read the manual which is usually the case with "non working" es hardware/ software around here...
There is nothing in the manual about this.
Post by os » Wed Jun 03, 2015 7:54 am
Oh you mean the input of the patch editor plug-in.
That would just be your regular MIDI input, the one you have connected to the synth's output.
Luigi
Post by Luigi » Wed Jun 03, 2015 8:48 am
os wrote:Oh you mean the input of the patch editor plug-in.
yes I have tried that, and I get no signal from the Tetra synth
The editor is inside Blue Cat audios Patch Work(since the editor is not AAX) wich can send and transmit midi, but nowhare can I choose the output to Expert Sleepers.
I tried alot of different routings and it just wont work.
I got it working inside Cubase with my motu midi hubb, just choose the regular midi in and out that goes to the synth, like it regulary, would be.
cheers
Post by os » Wed Jun 03, 2015 8:53 am
No, that's where you would choose the Loopbe path. Then the other end of the Loopbe connection goes into the PT track which is hosting the ES plug-in.
limpmeat
Post by limpmeat » Wed Jul 29, 2015 1:31 am
Thought this would be the relevant place.
I use an editor for my Microwave called MonstrumWave and am looking to add an ESX8MD to my ES3/5 setup.
Thing is, I use Ableton. Do you think there is a way to get this plugin editor working with an ESX8MD with Ableton?
Ableton has no Sysex support, so the MW plugin accesses your midi ports directly. I'm guessing there is no real way to route the sysex messages to get it to work?
Post by os » Wed Jul 29, 2015 2:18 am
Mac or PC?
limpmeat
Post by limpmeat » Wed Jul 29, 2015 5:47 am
Mostly PC.
Post by os » Wed Jul 29, 2015 6:41 am
Then you need something like loopbe as mentioned above.
Seamus
Re: How to use vst editors for hardware synths??
Post by Seamus » Thu Feb 13, 2020 7:26 am
Hi
Has anyone managed to get sysex working with Ableton and the ESX8MD? if so, how'd you do it? Ive used a midi loop program to get midi out of a patch editor, but I'm not sure how to route this to sw plugin, since Ableton doesn't pass the sysex to it.
I'm using windows, in case that wasn't apparent from my struggles :)
Return to “Expert Sleepers”
