disting mk3 firmware announcement thread
Moderators: Kent, os
bemushroomed
Post by bemushroomed » Tue Jun 14, 2016 7:16 am
os wrote:14th June 2016 - version 3.4:
* SD playback modes now (de)selectable as normal algorithms.
* Added playlist & settings for SD playback, including one-shot mode.
* Added octave switch parameter in V/Oct SD playback mode.
* Reduced latency when retriggering SD playback.
* Added MIDI file playback modes.
* Added Euro<->Buchla converter algorithms.
* Fixed a bug with storing parameters.
http://expert-sleepers.co.uk/distingfir ... dates.html
:yay: :love: :hail: :party:
tromasom
Post by tromasom » Tue Jun 14, 2016 7:20 am
Yay, MIDI! I've been getting a lot of use out of the built-in sequencers on MI Edges and wishing that other units had that feature. Now, they can!
:banana:
debolish
Post by debolish » Tue Jun 14, 2016 9:40 am
Nice one. Looking forward to playing with the MIDI playback modes. Looks like it's finally time to get an SD card extender cable.
mpl
Post by mpl » Tue Jun 14, 2016 12:16 pm
Is there any info about playlist creation/format both for sd and midi playback
Post by os » Tue Jun 14, 2016 12:16 pm
It's fully documented in the manual.
mpl
Post by mpl » Tue Jun 14, 2016 1:28 pm
Found it, thank you
phutureboy
Post by phutureboy » Tue Jun 14, 2016 2:45 pm
:party: :bananaguitar: :tu:
FS: EMS Analyse Filterbank B1-II | EMS AKS | RSF Expander I & II | PEARL Syncussion SY-1 | KORG MS-20 | KORG SQ-10
twinesound
After 3.4 update can't select banks
Post by twinesound » Tue Jun 14, 2016 7:26 pm
The S knob does not function as expected with the mini sd inserted. I want to run my midi files, but I press 'S' and when I move to '2' to change banks the LED goes dark.
Bug or am I doing something wrong?
Post by os » Wed Jun 15, 2016 2:24 am
From the manual:
When not in an SD playback mode (i.e. when using banks 1-a to 1-d), but with an SD card still in the slot, the following apply:
* LEDs 2 & b will not light.
stingray
Post by stingray » Wed Jun 15, 2016 4:53 pm
Edit. Another case of D3 not liking a card. Bought a new one and it worked. I guess best practice would be to buy a fresh card with your Disting Mk3!!
bemushroomed
Post by bemushroomed » Wed Jun 15, 2016 6:25 pm
os, would it be possible to make the sample player to work like this:
A sample is only played if no sample is currently playing (and a trigger is also received - obviously we want the next sample to play in sync).
I have (had) the Ladik ROM-player and it works like this, with a jumper you can make it either play the whole sample or "stops playing at gate ends (jumper set)" (Ladik's description)
I think a mode like this would be far more optimal for drums than to have samples who are often cut off (when for example using CV to the "Z" input to randomly change samples).
Post by os » Thu Jun 16, 2016 3:09 am
That would be a good addition, indeed.
Post by os » Thu Jun 23, 2016 5:28 am
23rd June 2016 - version 3.5:
* Fixed hangs when entering SD playback modes with no valid media on the card.
* Added '-retriggerOnSampleChange' setting.
* Added Bit Crusher.
bemushroomed
Post by bemushroomed » Thu Jun 30, 2016 12:08 pm
Another thing i was thinking, would it be possible to make the playlist for samples to be longer than 32? Just the playlist itself? Would be nice to be able to do variations in it that extends over 32.
E.g first you would have samples 0-32 like normal, 33-65 is a variation with the samples in a completely different order, or with all snares removed and replaced with instances of hihats (or whatever). This way you would have even more ways to experiment with beats.
albedo0point39
Post by albedo0point39 » Fri Jul 08, 2016 9:32 am
Os... do you take suggestions for features?
I'd love to see a CV controlled stereo panner!
Post by os » Fri Jul 08, 2016 9:38 am
Post by os » Thu Jul 14, 2016 7:34 am
14th July 2016 - version 3.6:
* Added support for mono WAV files.
* Increased maximum number of WAV files per playlist to 64.
* Added an input attenuation parameter to the quantizer algorithm.
* Increased octave shift range in VCO algorithms.
* Added a y offset (waveshape) parameter to the VCO with waveshaping algorithm.
* Fixed a hang if a playlist file ended with multiple blank lines.
ArguZ
Post by ArguZ » Sun Jul 17, 2016 4:09 am
The gift that keeps on giving :)
adam
Post by adam » Sun Jul 17, 2016 4:28 am
os, can you clarify if disting needs recalibration after firmware update or not?
Post by os » Sun Jul 17, 2016 6:13 am
adam wrote:os, can you clarify if disting needs recalibration after firmware update or not?
It does not.
adam
Post by adam » Mon Jul 18, 2016 12:57 pm
thanks
pisrecords
Post by pisrecords » Sun Aug 21, 2016 5:25 pm
i have 2 disting . must havemodule ! :hail:
ADMIN in latin eurorack group . https://www.facebook.com/groups/906628619403191/
sorry 4 my poor English words.
corey r
Post by corey r » Sat Sep 24, 2016 11:21 am
os, if you're planning any more firmware updates, would it be possible to include wav playback with selectable start and end points on x and y instead of start and retrig? or start on x end on y and speed on x? that way it could work similar to a bastl grandpa.
Thanks for making such an amazing module, i've got two and want more!
Post by os » Sat Sep 24, 2016 11:23 am
Yes, it's high on the list.
Post by os » Thu Oct 27, 2016 9:26 am
27th October 2016 - version 3.7:
* Added ES-1 and ES-2 emulation algorithms.
* Added Audio Playback With End CV algorithm.
* Added the favourites mechanism.
* Added an option for pre-scale transpose in the Quantizer algorithm.
* Added a parameter for Y offset in the Resonator algorithm.
* Added the -fixedPitch, -ramp and -triggers options in audio playlists.
* Fixed a bug in the display of parameters in the Quantizer algrithm.
* Fixed a bug in the playback of one-shot audio samples where the playback would stop at slightly the wrong position (possibly resulting in clicks).
Return to “Expert Sleepers”
