disting mk3 firmware announcement thread
Moderators: Kent, os
ElCampesino
Post by ElCampesino » Thu Oct 27, 2016 2:31 pm
:nana: Awesome.
Edit: especially pre scale transpose
pisrecords
Post by pisrecords » Thu Nov 10, 2016 10:37 pm
i am trying to set my favourites . i can't
this is mi txt >
disting favourites v1
1/a 1-d delay
1/b 1-b delay line
1/b 1-c pingpong
1/b 3-b tapedelay
1/b 2-a resonator
1/b 2-b vocoder
1/b 2-c phaser
1/b 2-d crusher
1/b 3-d filter variable
1/b 4-a LP HP
1/a 2-d waveshaper
1/c 1-d advca puch
1/c c-4 rndm trig
1/a 1-c rectif
1/a 2-c comparator
1/a 4-b lfoclok
:hmm: :bang:
ADMIN in latin eurorack group . https://www.facebook.com/groups/906628619403191/
sorry 4 my poor English words.
Post by os » Fri Nov 11, 2016 3:44 am
How about you post the file itself?
pisrecords
Post by pisrecords » Fri Nov 11, 2016 3:29 pm
os wrote:How about you post the file itself?
Post by os » Fri Nov 11, 2016 3:41 pm
That file is in Rich Text format. It has to be plain text.
pisrecords
Post by pisrecords » Sat Nov 12, 2016 10:41 am
os wrote:That file is in Rich Text format. It has to be plain text.
thanks!!!!!! :hail: :hail: :hail:
zengomi
Post by zengomi » Thu Dec 01, 2016 2:45 pm
Hello
Need some advice on checking the firmware version of a newly purchased Disting mk3.
I've tried this:
Turn on the disting with the S knob pressed. It will go through the first stage of its startup sequence, showing the bootloader version number.
but I can't interpret what the lights indicate.
I don't have a Micro SD card yet, so simply loading the laster firmware isn't an option.
Any help would greatly appreciated.
Post by os » Thu Dec 01, 2016 2:52 pm
If it's newly purchased the firmware number will be printed on a sticker on the box.
If you like, post a video of the boot up sequence (without any knobs pressed).
zengomi
Post by zengomi » Thu Dec 01, 2016 2:56 pm
Thanks for responding so quickly.
In the few minutes between our posts, I made a video. Before trying to make that available here, I'll try to find the box.
zengomi
Post by zengomi » Thu Dec 01, 2016 3:07 pm
Found the box. 3.6
Time to get a Micro SD and extension cable.
Cheers.
corey r
mk4!
Post by corey r » Sun Jan 29, 2017 9:02 pm
The display screen is looking great!
dumbledog
Post by dumbledog » Sat Feb 04, 2017 9:45 pm
The X input attenuator for the quantizer goes from -1 to 31. What's happening when it's -1?
Post by os » Sun Feb 05, 2017 3:55 am
Same as e.g. the LFO.
the manual wrote:The scale factor is (1+parameter value)/32, so at the minimum parameter value of -1 there is no output at all.
dumbledog
Post by dumbledog » Sun Feb 05, 2017 10:47 am
Ah, thanks.
Post by os » Fri Feb 17, 2017 7:21 am
17th February 2017: v3.8
* Added Crossfade/Pan algorithm.
* Added Clocked Audio Playback algorithm.
* Added Key parameter to the Quantizer algorithm.
pisrecords
Post by pisrecords » Sat Feb 18, 2017 1:02 pm
os wrote:17th February 2017: v3.8
thanks a lot :yay: :hail:
sihiL
Post by sihiL » Tue Feb 21, 2017 4:32 pm
Thank you so much! Love the clocked sample playback! I don't know if my case is fringe, but I hardly ever use stereo samples. Could it be possible to have the the B-output putting out an envelope follower signal based on the selected sample or a trigger on the loop resetting?
Maybe pseudo-stereo weirdness with inverted pitch on the other output? Dual radio music with X and Y as resets? Reversed playback on output B? I really don't know how much muscle is available, but these could be cool for mono stuff.
Post by os » Tue Feb 21, 2017 4:46 pm
Ramps or triggers on output B are already a feature - see the manual.
thack
Post by thack » Fri Mar 03, 2017 10:55 am
Hi there,
I'm having an issue with updating the new v3.8 firmware. After inserting the SD card with the update, I proceed to turn the module on (with the S encoder pressed down). But instead of getting led's 4, A and B to light up, I am getting A then B then A then B, and so forth. This continues even after I release the S encoder. If there's any further information that you may need to diagnose what the issue is, please let me know!
Post by os » Fri Mar 03, 2017 10:56 am
Have you used this SD card before for firmware updates?
Have you checked the file is correctly named "image.hex" and in the root of the card?
geremyf
Post by geremyf » Mon Mar 20, 2017 1:24 pm
While messing around with my Disting mk3 yesterday in phaser mode (via a favorites file, don't know if that is important) I was not able to switch paramaters by pressing the z button. I could only modify parameter 0 with the S knob. This is a one time thing, and it has worked correctly before. I had the modular on for many hours (>10), much more than usual, and thought maybe that had something to do with it. I turned it off for the evening and didn't restart to make sure it was working again (but I sort of assume that it will).
geremyf
Post by geremyf » Tue Mar 21, 2017 12:09 pm
After the restart it works fine again, and I didn't change modes or anything. Might be a bug.
machine desirante
Post by machine desirante » Tue Apr 11, 2017 6:12 am
I'm getting some strange behaviour from my disting on the sample playback functionality after updating the firmware to 3.8 from 3.6 (with which it shipped).
Samples seem to only play back at very high speed in every mode and no control over it seems available. I went back to 3.6 and samples played just fine, attempted a second update only to get the same aberrant behaviour (also in evidence with 3.7).
I'm not sure if this a known problem or if I'm missing something really obvious... I can upload a recording of the behaviour if it helps.
Post by os » Wed Jun 07, 2017 8:43 am
7th June 2017 - version 3.9:
Added Audio Recorder algorithm.
Added Dual Quantizer algorithm.
Added Dual Euclidean Patterns algorithm.
Added Dual Delayed Pulse Generator algorithm.
Added Dual Sample and Hold algorithm.
Added a Track and Hold mode to the Sample and Hold algorithm.
Added multiplier parameter to the Clockable Delay algorithm.
Added speed parameter to the Tape Delay algorithm.
Fixed the behaviour of the Phaser algorithm at extreme feedback settings.
http://expert-sleepers.co.uk/distingmk3 ... dates.html
Oblivion
Post by Oblivion » Wed Jun 07, 2017 12:15 pm
:hail:
I'm overwhelmed just reading the list. Thanks for the backports.
:omg:
Perpetual n00b.
Budding Phonogeneticist.
Return to “Expert Sleepers”
