disting mk4 firmware announcement thread
Moderators: Kent, os
BarneyRubble
Post by BarneyRubble » Thu Jun 06, 2019 6:59 am
v4.11
Parameters on K2 & K4 are not selectable?
Just the default 0 folder parameter available
K1 is ok parameter wise so not sure if there is a problem with the update or something my end.
Post by os » Thu Jun 06, 2019 7:20 am
Those algorithms use Z for tap tempo so parameter selection is only available via S. Refer to the manual.
BarneyRubble
Post by BarneyRubble » Thu Jun 06, 2019 7:31 am
os wrote:Those algorithms use Z for tap tempo so parameter selection is only available via S. Refer to the manual.
Got it! Hold in the S knob turn slowly - knew it was me all along - Great update.
thanks OS
mahler007
Post by mahler007 » Thu Jun 06, 2019 9:35 am
os wrote:June 6th 2019 - v4.11:
* Added a parameter to the MIDI File Playback (Clocked) algorithm to select the MIDI file directly, not using the Z knob/CV.
Awesome — thank you so much!
Andrew
azrrik
Post by azrrik » Thu Jun 06, 2019 10:44 am
The Clocked Audio Playback algorithm now has an option to use Z to control sample start position.
Fixed a problem where non-looped WAV files might play with a click at the end of the sample.
:hail:
javes777
Post by javes777 » Fri Jun 07, 2019 7:52 am
* Added the Clockable Wavetable Envelope algorithm.
My suggestion made it! Thanks very much Os. :)
The Grump
Post by The Grump » Fri Jun 07, 2019 2:13 pm
Os, this update is pretty awesome, even without a step sequencer. Well done, geez!
Anghel
Post by Anghel » Wed Jun 12, 2019 5:43 pm
Great update!
Post by os » Wed Jul 10, 2019 5:50 am
10th July 2019 - v4.12:
* Added the Half-wave Rectifier algorithm.
* Added the Multisample 2 Audio Playback algorithm.
* Added support for loop markers in WAV files.
* In all Audio Playback algorithms, added a small delay between choosing the folder and the disting loading it, to make it easier to scroll through many folders.
* In the Audio Playback with Crossfade algorithm, added display of the file chosen to fade in at the next crossfade.
* Fixed a problem when using 'Envelope time' in the dual audio playback algorithms and both voices were playing the same sample.
* Greatly increased performance when using 'Envelope time' in dual audio playback algorithms.
* In the Dual Euclidean Patterns algorithm, added independent Rotation control of the two patterns, and added a Repeat parameter, allowing the repeat count to be different from the number of steps in the pattern.
The Grump
Post by The Grump » Wed Jul 10, 2019 6:57 am
As always, you fucking rock, Os.
Howling Terror
Post by Howling Terror » Wed Jul 10, 2019 7:06 am
Thank you.
adaris
Post by adaris » Wed Jul 10, 2019 10:00 am
Cool, thanks!
Phitar
Post by Phitar » Wed Jul 10, 2019 11:10 am
os wrote:10th July 2019 - v4.12:
Oh! Just realized that I'm not feeling well.
I should probably leave work early because it might be infectious.... Yep I heard about it on TV this morning.... Wiggler's Syndrome they called it....
Thanks Os :hail:
Waiting for the electrician... or someone like him. - Firesign
Alliex
Post by Alliex » Wed Jul 10, 2019 12:11 pm
Wow, I've been slacking on exploring 4.11 and now this :D :D
mrerdat
Post by mrerdat » Wed Jul 10, 2019 6:12 pm
:hail: os :hail:
Post by os » Thu Jul 11, 2019 10:26 am
11th July 2019 - v4.12.1:
* Fixed an issue with the formatting of WAV files written by the Audio Recorder algorithms.
* Fixed an issue where a disting running firmware 4.12 would hang when attempting to play WAV files recorded by the disting itself.
laneo
Post by laneo » Fri Aug 09, 2019 6:56 am
Since 4.11 pressing the Z button on a reverb Algorithm freezes the reverb.
So how can I cycle between Parameters without pressing the Z?
Post by os » Tue Aug 13, 2019 3:24 am
Push and turn S, as it says in the manual.
eblomquist
TRYING TO UPDATE TO 4.12, BUT IT STILL READS 4.11
Post by eblomquist » Thu Aug 15, 2019 7:28 pm
Strange behavior. Twice I have downloaded the 4.12 firmware and moved it to the SD card, and twice when Disting 4 boots, it reads 4.11.
Any suggestions?
Post by os » Fri Aug 16, 2019 2:15 am
The update clearly hasn't worked. Check the card format and the file name on the card. The update should look like it does in the video on the firmware download page.
Post by os » Thu Sep 05, 2019 10:35 am
5th September 2019 - v4.13:
* Added the Stereo Filter algorithm.
* Added the Stereo Tape Delay algorithm.
* Overhauled the Stereo Chorus and Mono Chorus algorithms, adding parameters for delay time, chorus stages, and feedback saturation.
* Added the Sum Mode parameter to the Precision Adder (fractional offsets) algorithm.
* Added a further mode to the Half-wave Rectifier algorithm offering dual independent rectifiers.
* Added parameters to the Sample and Hold and Dual Sample and Hold algorithms to add noise into the inputs.
* Added the '-retriggerOnSampleChange' playlist option for MIDI playback.
* Fixed a problem where the Audio Playback with Scrub algorithm would stop playback if the playback position went off the end of the sample.
* Fixed a problem where specifying an empty folder in an audio playlist and then selecting that folder would then cause the folder parameter to revert to zero.
Howling Terror
Post by Howling Terror » Fri Sep 06, 2019 4:54 am
Loving the improved chorus.
Thanks Os.
Now I just need some kindly nerd to update the cheatsheet.
Post by os » Tue Oct 29, 2019 7:06 am
29th October 2019 - v4.14:
* Added the Pulsar VCO algorithm.
* Added the Switch algorithm.
* Added slew parameters to the Dual Sample and Hold algorithm.
* The MIDI Clock algorithm can now output clocks up to 24ppqn (1/96th note).
* The VCO with linear FM, VCO with waveshaping, and Wavetable VCO algorithms now respond to incoming MIDI note messages.
* The Quantizer 2 algorithm can now take its quantisation pattern from incoming MIDI note messages.
* Added a setting for the maximum delay time of the SD Delay algorithms.
* Fixed some problems where incoming MIDI would stop working when saving a preset or switching to certain algorithms.
* Fixed a problem where audio files with loop markers would not loop properly if the loop was not near the end of the file.
* Fixed a problem with the knob recorder in the Stereo Filter algorithm.
solipsvs
Post by solipsvs » Thu Oct 31, 2019 10:07 am
kick arse mate
juvation
Post by juvation » Mon Nov 04, 2019 3:34 pm
Thanks so much for the Switch algo and the slew on the dual S&H. Appreciated.
Jason Proctor
Return to “Expert Sleepers”
