disting mk4 firmware announcement thread
Moderators: Kent, os
Post by os » Tue Oct 24, 2017 8:04 am
yeatsvisitslincoln wrote:What happened to the algorithms descriptions webpage? I know all of it's in the .pdf manual, but I found the webpage to be an easy reference. Or would it be possible to add clickable references in the manual to jump to algorithm explanations?
You can click in the contents:
@s.l.o.w It's on the list.
yeatsvisitslincoln
Post by yeatsvisitslincoln » Fri Oct 27, 2017 8:12 am
Should have checked that. Thanks!
Post by os » Thu Nov 30, 2017 9:42 am
November 30th 2017 - v4.4:
* Added preset save & recall.
* Added Programmable Quantizer algorithm (using Scala).
* Added Scala support to the MIDI/CV algorithm.
* Added direct control of output voltage from MIDI CCs to the MIDI/CV algorithm.
* Added an 'Offset' parameter to the Quantizer algorithm.
* Added settings for MIDI in & out channel.
* Added option for (soft) MIDI thru.
* Added support for changing algorithm via MIDI CC or program change, and for changing preset via MIDI program change.
http://expert-sleepers.co.uk/distingfir ... dates.html
adam
Post by adam » Thu Nov 30, 2017 10:21 am
blimey, you've been busy :)
Post by os » Fri Dec 01, 2017 5:53 am
December 1st 2017 - v4.4.1:
* Fixed a crash when turning S if the algorithm has no parameters.
seanrieger
Post by seanrieger » Sun Dec 10, 2017 6:30 am
os wrote:November 30th 2017 - v4.4:
Great work and thank you! My collection of these just keeps growing.
Chickenbone
Post by Chickenbone » Tue Jan 16, 2018 3:34 am
can I update the firmware for my mk3 with these?
If you ever come to a fork in the road, pick it up.
Modular Grid
SoundCloud
Shledge
Post by Shledge » Tue Jan 16, 2018 10:17 am
Nope
Post by os » Mon Feb 19, 2018 8:00 am
February 19th 2018 - v4.5:
* Added Audio Playback with Reverse, Audio Playback with Scrub, Dual Audio Playback, and Dual Audio Playback with Z Speed algorithms.
* Audio playback algorithms now support up to 100 files per algorithm.
* The Wavetable VCO algorithm now supports up to 100 wavetables.
* Improved UI responsiveness when in audio playback modes.
* Algorithm selection can now loop from P-8 to A-1 and vice versa.
* Fixed a problem where the disting might stop receiving MIDI if MIDI was being sent into the module while it was powering up.
* Fixed a problem where the B-8 VCO mode might change pitch unexpectedly while adjusting parameters.
mpl
Post by mpl » Tue Feb 20, 2018 7:01 am
thank you.
**the dual sample play back is great**
Tubefund
Post by Tubefund » Wed Feb 21, 2018 10:54 am
was thinking about buying a second Disting or a Pico drums. With this update my choice is easy. Another Disting! more samples to store and dual trigger mono or stereo samples and the choice of seperate outs! You rule!
Shledge
Post by Shledge » Wed Feb 21, 2018 11:56 am
Looping algo changing is a godsend - no more endless scrolling to get to the later ones. 8-)
pisrecords
Post by pisrecords » Fri Mar 02, 2018 9:54 pm
I update to the latest firmware and I'm having problems, every time I load a new algorithm, my Disting emits short digital harsh noise.
zynths rack : https://www.modulargrid.net/e/racks/view/267278
Drumz rack :
https://www.modulargrid.net/e/racks/view/220723
ADMIN in latin eurorack group . https://www.facebook.com/groups/906628619403191/
sorry 4 my poor English words.
Post by os » Sat Mar 03, 2018 7:12 am
Do the algorithms work normally once this noise is done?
VampyreLegion
Post by VampyreLegion » Tue Mar 06, 2018 4:36 pm
Thank you for the updates
My two Disting MK4's are happy!
Looking forward to more in the future!
:party:
shoottofill
Post by shoottofill » Tue Mar 13, 2018 9:33 pm
Trying to upgrade to 4.5 (from 4.3) and pressing the encoder it just says success, no confirm.
Tried going from 4.4 first and even without the card in it, it just says success, never confirm.
Firmware has not changed from 4.3
any suggestions?
shoottofill
Post by shoottofill » Tue Mar 13, 2018 9:39 pm
shoottofill wrote:Trying to upgrade to 4.5 (from 4.3) and pressing the encoder it just says success, no confirm.
any suggestions?
posted too soon, saw it answered elsewhere. Needed to format the micro sd as FAT format not mac OS.
solved!
NONMIMETICFORM
NOOB ALERT! How the ***** do I update the firmware on mac
Post by NONMIMETICFORM » Fri Mar 16, 2018 8:56 am
So, I go around and around trying to unzip a .HEX file on my macbook with no luck. :doh: What the heck am I not understanding here??? I have used several programs, looked for simple answers but everything I have read skips the basics. EZ7Z worked for me in the past but not this time. Please, can someone break it down for me so I can move on with my life... :bang:
Without music, life would be a mistake.
Friedrich Nietzsche
Post by os » Fri Mar 16, 2018 9:20 am
Just double click it. macOS unzips files in the Finder just with a double click.
NONMIMETICFORM
Post by NONMIMETICFORM » Fri Mar 16, 2018 9:41 am
on my mac i get a window that says, "There is no application set to open the document". Which is where the vicious cycle begins.
Friedrich Nietzsche
Post by os » Fri Mar 16, 2018 9:43 am
Has it already been unzipped for you? (Safari has an option to do that.)
If the file you have is called 'image.hex' then it's already unzipped.
NONMIMETICFORM
Post by NONMIMETICFORM » Fri Mar 16, 2018 9:47 am
yes. Thats the file. However, I can't load it onto the SD card. It bounces back every time.
Friedrich Nietzsche
Post by os » Fri Mar 16, 2018 9:48 am
Have you got the SD card write-protected?
NONMIMETICFORM
Post by NONMIMETICFORM » Fri Mar 16, 2018 9:55 am
BINGO!! That was the issue. Thanks for your help. On with the show!
Friedrich Nietzsche
NONMIMETICFORM
Post by NONMIMETICFORM » Fri Mar 16, 2018 10:29 am
ok. Round 2 and I apologize for my lack of knowledge on this subject. I have the firmware installed in the root folder on the SD card. Disting cycles through once and reads SUCCESS. But it's still version 4.2.2.
I have tried several times with no luck. Any suggestions?
Friedrich Nietzsche
Return to “Expert Sleepers”
