Dead ES-3mk4. Service manual/schematic or test points to check?
Moderators: Kent, os
DJMaytag
Post by DJMaytag » Tue Dec 31, 2019 9:33 am
I took my Expert Sleepers modules out of my case recently to stick them into a case that would be a “home only” case. I went to hook them up again for the first time in a while, and now it seems sorta dead.
Even before I took it out of my main case, I noticed that output 3 was always lit up slightly, even with nothing happening on the DAW side. It would be like that upon power up.
Now I get no blinking lights at all upon power up, but now output 3 is dimly lit red (was blue before) and 4-8 are all VERY dimly lit blue.
I took it out of the rack and brought it over to my bench to check some voltages. Everything seems fine at the power input, and the voltages labelled on the header that connects to the LED/ADAT input board all seem fine. Are there any other test points to check to see what could have died on this thing? Any schematic available?
EDIT: title said ES-5mk4, changed to ES-3mk4.
os
Re: Dead ES-5mk4. Service manual/schematic or test points to check?
Post by os » Mon Jan 06, 2020 10:32 am
Are we talking about an ES-3?
DJMaytag
Post by DJMaytag » Mon Jan 06, 2020 11:19 am
Oops. Yeah, that’s supposed to be ES-3mk4 in the title.
os
Re: Dead ES-3mk4. Service manual/schematic or test points to check?
Post by os » Mon Jan 06, 2020 11:31 am
Are you getting the ADAT sync LED when the ADAT is connected?
DJMaytag
Post by DJMaytag » Mon Jan 06, 2020 2:12 pm
No.
os
Post by os » Tue Jan 07, 2020 3:54 am
Sounds pretty dead then.
DJMaytag
Post by DJMaytag » Tue Jan 07, 2020 11:16 am
Would it be unusual for the 78M33 regulator to be crazy hot to the touch?
DJMaytag
Post by DJMaytag » Tue Jan 07, 2020 11:27 am
os wrote:
Tue Jan 07, 2020 11:18 am
Yes.
Would this be a suitable replacement part?
https://www.mouser.com/ProductDetail/Te ... oaa0LIk%3D
I’m only measuring 0.25V on the output of that regulator.
os
Post by os » Wed Jan 08, 2020 5:49 am
That's the exact part used.
DJMaytag
Post by DJMaytag » Wed Jan 08, 2020 8:49 am
Awesome. Thanks!
DJMaytag
Post by DJMaytag » Fri Jan 17, 2020 1:47 pm
New IC2 VR is still getting hot. Following down the path... I see this cap (C8) looks bad, and I’m getting a short between them leads when checking for continuity. Is this expected, and is there anything else I should be checking for potential problems downstream of the VR and/or this cap?
os
Post by os » Fri Jan 17, 2020 2:06 pm
You shouldn't get a short between power rails. Try removing the cap.
No need to replace until you've found the short.
DJMaytag
Post by DJMaytag » Fri Jan 17, 2020 2:24 pm
Just to be clear... I’m getting a short between the caps leads, as well as between each side and the ground pins on the power header.
Removing the cap will determine if the cap is shorted, or tell me if there’s a short somewhere else down the line?
DJMaytag
Post by DJMaytag » Fri Jan 17, 2020 6:58 pm
Removed that cap, but there’s still a short between the pads. What value cap was that that I removed? I broke a lead off while removing it.
os
Post by os » Sat Jan 18, 2020 6:36 am
10uF, part number EXV106M025A9BAA.
Return to “Expert Sleepers”
