ES-9 clock crackle
Moderators: Kent, infradead, os
squank
ES-9 clock crackle
Post by squank » Fri Jan 03, 2020 8:21 pm
On a Mac 10.14.6 running DP I am getting a crackle recording thru the ES-9 after 45 seconds?!?!?
quit the app, run again, records fine for 45 seconds, then crackle.....
Is there a way I can't find to edit the clock settings for the es-9?
I am aggregating a MOTU 16A and the ES-9.....
Re: ES-9 clock crackle
Post by os » Mon Jan 06, 2020 10:18 am
Have you enable Drift Correction on the one that is not the clock master?
squank
Post by squank » Wed Jan 15, 2020 12:39 am
where is that found on Mac OS?
squank
Post by squank » Wed Jan 15, 2020 1:15 am
OMG ok now I get it....
Expert Sleepers ES-9 audio setup with multiple interfaces
Plug everyone in
open Audio Midi set-up from Utilities Menu
hit (+) at the bottom of the Devices window
Add an Aggregate Device
In the configuration window, select the desires interfaces
Set the ES-9 to Drift Correction........
Have a great time without crackle!!
Return to “Expert Sleepers”
