ES-9 & MIDI
Moderators: Kent, os
bennytom
ES-9 & MIDI
Post by bennytom » Tue Jan 07, 2020 3:30 pm
Is it possible to send midi data from Ableton to my Eurorack setup with the ES-9? I want to be able to key in notes on Ableton and have them play from my Eurorack modules, just as you would with a standard midi hardware synth or a VST.
If it's not possible, how could I do it? what modules would I need etc?
Forgive me if this is a dumb q, I'm pretty new to Eurorack!
Cheers!
bennytom
Re: ES-9 & MIDI
Post by bennytom » Tue Jan 07, 2020 3:37 pm
I should also add that midi wouldn't matter to me if I was somehow able to send note data from Ableton over CV to my Eurorack with the ES-9, enabling me to key in chords/notes on Ableton in standard midi clips and have them play on eurorack. I don't know if that's possible or not but yeah....
Re: ES-9 & MIDI
Post by os » Wed Jan 08, 2020 4:41 am
Yes, that's one of the primary purposes of the module. Used in conjunction with Silent Way, or Live's CV Tools, you can do exactly that.
Switchzik
Re: ES-9 & MIDI
Post by Switchzik » Mon Mar 09, 2020 10:53 am
Hello,
Back to the original topic, I would like to use the ES-9 with my ipad.
Use the es-9 input as an audio interface - and do the mix on the ipad - and use the midi breakout for sequencing with midi.
What I don't understand is, can I use the ES-9 output for CV (from midi note) out or do I need to plug the midi out from the breakout to another midi to cv module ?
in short, do I need another module than the ES-9 + midi breakout to do midi to cv sequencing.
Thanks !
Re: ES-9 & MIDI
Post by os » Mon Mar 09, 2020 11:10 am
You don't need another module, but you do need software on the iPad to convert MIDI to CV.
Switchzik
Re: ES-9 & MIDI
Post by Switchzik » Mon Mar 09, 2020 11:49 am
Ok, but what is the midi breakout for ?
if I plug a midi cable in the midi in and run a sequencer with a midi app on the iPad, do I get CV out on the es-9 ? Do it a t as a midi to CV converter ?
Re: ES-9 & MIDI
Post by os » Mon Mar 09, 2020 11:55 am
No, the ES-9 is not a MIDI/CV converter. The MIDI breakout is to provide MIDI i/o to your DAW.
Switchzik
Re: ES-9 & MIDI
Post by Switchzik » Mon Mar 09, 2020 12:04 pm
Ok thanks !
So if I understood correctly. I can plug the midi out from the breakout to another midi to CV module and run the midi sequence by plugging the USB to the es-9.
The midi will be pass to the breakout to the midi to CV module.
Sounds great !
Re: ES-9 & MIDI
Post by os » Mon Mar 09, 2020 12:46 pm
That will work, yes, but as I say if you do the MIDI/CV in software you can avoid having to have an additional module.
Switchzik
Re: ES-9 & MIDI
Post by Switchzik » Mon Mar 09, 2020 2:09 pm
Thanks for taking time to explain :tu:
The problem is that there is almost no CV sequencer on iOS, mostly midi. That's why.
Return to “Expert Sleepers”
