ES FH2 Keith McMillen Bop Pad
Moderators: Kent, os
youwe9
Post by youwe9 » Fri Jan 10, 2020 8:57 am
Hi,
does someone know, if I can connect the Keith McMillen Bop Pad to the FH and get CV and triggers out?
os
Re: ES FH2 Keith McMillen Bop Pad
Post by os » Fri Jan 10, 2020 9:03 am
Should work fine.
youwe9
Post by youwe9 » Fri Jan 10, 2020 9:07 am
Should work fine.
Great!
Thank you for your fast reply....
muhimnested
Post by muhimnested » Tue Jan 14, 2020 10:06 am
Let me how you get on with the BopPad and modular integration. I’ve found the mapping with the Bop quite confusing
mojopin
Post by mojopin » Tue Jan 14, 2020 7:32 pm
I was pleasantly surprised to have mine setup in minutes but the ES side of things was already sorted. I use one SW trigger plugin instance per drum voice. Setup each with the one midi note you want to trigger the gate, envelope, etc. Then in the boppad software just map to the same midi note. Boppad midi in to SW trigger midi-in in the daw. I'm surprised how different the feel and velocity you get between sticks and fingers. I def get different timbres from the modular. I just got mine last week btw 8-)
Return to “Expert Sleepers”
