Disting Mk4 wavetables question
Moderators: Kent, os
bemushroomed
Post by bemushroomed » Tue Jan 21, 2020 7:05 pm
Os, you said in a post that Disting only has 60kb of RAM so the wavetables needs to match that to fit within RAM.
So let's say i have a folder with 100 wavetables, does this whole folder need to fit within RAM or does it mean that it can have 100 files and each is 60kb (or less) and it will work? I don't mean concatenated wavetables.
To get the wavetables to play in tune, which pitch should i sample my synths at, C or something else?
Thanks. I'll be sure to share them later.
os
Re: Disting Mk4 wavetables question
Post by os » Wed Jan 22, 2020 3:30 am
The whole folder needs to fit in RAM.
It doesn't matter what pitch you sample, so long as the wave file contains exactly one cycle of the waveform.
bemushroomed
Post by bemushroomed » Wed Jan 22, 2020 3:36 am
Thanks os.
Seems like most libraries that are shared for it are way too big for it then. I guess it will only play the first 3-4 files for these.
bcomnes
Post by bcomnes » Thu Jan 23, 2020 11:54 am
I use Adventure Kids free wave tables (1400+), each one is only 1354 bytes, single cycle
I preview them and select a couple dozen to load on the sd card, 60k is quite a lot of room
Too Loud?
Too Bad
bemushroomed
Post by bemushroomed » Thu Jan 23, 2020 3:28 pm
Yeah, they're quite good. I can also recommend to just download WaveEdit and you have a giant library to choose from Online.
https://synthtech.com/waveedit/
kind of funny that Disting can handle twice the file size of an E352... a library of single cycle wav's can max be around 30KB for the E352.
Return to “Expert Sleepers”
