5-pin DIN MIDI
Moderators: Kent, os
micdrop11
5-pin DIN MIDI
Post by micdrop11 » Sat Feb 01, 2020 9:41 pm
For the FH-2 expansion to 5-pin DIN MIDI, what is the default output number? I'm trying to output basic start/stop and clock information from the MIDI Out to an analog drum machine.
I've tested the 5-pin DIN MIDI module and it appears to be working. I've sent MIDI information to the IN socket and the FH-2 acknowledges the incoming MIDI information on its screen.
Appreciate any help.
Thanks,
Mike
Re: 5-pin DIN MIDI
Post by os » Sun Feb 02, 2020 4:30 am
Not sure what you mean by that.
It may be relevant to point out that you have to enable the DIN MIDI output in the FH-2 settings.
micdrop11
Re: 5-pin DIN MIDI
Post by micdrop11 » Sun Feb 02, 2020 9:39 am
Thanks for the help. I didn't realize that I needed to enable the output in Settings.
However, after enabling that Setting, I'm still struggling to send MIDI information out over the 5-pin DIN MIDI expander... Any other thoughts?
(FYI, when I asked about a default output, I was wondering if I need to configure something in the "FH-2 Output Configurator" to send this MIDI information out.)
micdrop11
Re: 5-pin DIN MIDI
Post by micdrop11 » Sun Feb 02, 2020 9:50 am
Got it! I think I figured it out. I configured the MIDI Forwarding.
Kattefjaes
Re: 5-pin DIN MIDI
Post by Kattefjaes » Thu Feb 20, 2020 10:01 am
This tripped me up too.
Hey, os, would you consider adding a small reminder to the manual for this common use case? The manual has all the info, but having a little box with both of these snippets together in the section on MIDI might save you having to answer this question over and over.
(Also, lots of places in the manual refer to envelope settings explained elsewhere in the manual- but in the end, I gave up looking for them, after loads of scrolling and searching. Maybe consider mentioning exactly where they are, like a page or section number, for dumbasses like me, who only get time to use their stuff late at night when they're tired?)
Re: 5-pin DIN MIDI
Post by os » Thu Feb 20, 2020 10:10 am
Could you give me an example of where it refers to "envelope settings explained elsewhere in the manual"?
Kattefjaes
Re: 5-pin DIN MIDI
Post by Kattefjaes » Thu Feb 20, 2020 10:35 am
Let me check, I might have totally mis-remembered.
Edit:
In this case, I suppose the Distring docs are a better example- clearly you should never trust my memory. Sorry for dragging you off-topic.
The actual phrasing is variants of
Parameters 0 & 2 are the standard sample folder and envelope time parameters, described above.
I'm sure there is a section that explains it too, not a criticism. However, I had trouble finding it- if it could say "on page xx", that'd be easier, even if it's a pain because you need to either update it or use some sort of TOC function when you change the document.
hru
Re: 5-pin DIN MIDI
Post by hru » Thu Feb 20, 2020 3:13 pm
Hello,
What is pls the smallest setting for 5 Pol Midi-Sync?
FH-2 - Settings - General - Enable Din Midi out + Enable Midi Clock out
Drumcomputer (Yamaha ry30) - Sync Clock Midi (extern)
is it? try many other Hard and Software settings the last days
the FH-2 Displays shows a outgoing Din-Clock but it don't run
Maybe is the Midi Breakout Module broken or old Midi-Hardware need a always running Midi-Clock?
https://forum.mutable-instruments.net/t ... -app/13288
Thanks for any suggestion
Re: 5-pin DIN MIDI
Post by os » Fri Feb 21, 2020 3:33 am
@Kattefjaes Have you tried clicking on 'above'?
@hru I would double check that the MIDI breakout is connected correctly. Try sending MIDI into the FH-2 and see if it is received.
hru
Re: 5-pin DIN MIDI
Post by hru » Fri Feb 21, 2020 7:10 pm
Thanks for the fast reply
FH-2 GT3 (Pin1 red) - Midi Breakout GT1 (Pin1 red)
Yamaha Ry30, Midi out - Midi Breakout, Midi in
Tested your help, Ry30 Midi out to FH2 Midi in with several Cables and Midi-Hardware sadly the FH-2 Nothing received on Display
Re: 5-pin DIN MIDI
Post by os » Sat Feb 22, 2020 6:35 am
Are you using the same row of connectors on the ribbon cable at both ends?
Kattefjaes
Re: 5-pin DIN MIDI
Post by Kattefjaes » Sat Feb 22, 2020 8:04 am
Bloody hell, thank you! Couldn't see that it was a link at all.
hru
Re: 5-pin DIN MIDI
Post by hru » Sat Feb 22, 2020 5:38 pm
yes, i checked again
Return to “Expert Sleepers”
